单片机/MCU论坛
直播中
goodmbby
9年用户 1259经验值
擅长:处理器/DSP
私信 关注
[问答]
求助,关于数码管闪烁的问题
用数码管做了数字钟,运行没有什么问题,但是加了流水灯之后,数码管会闪烁,这是怎么回事?应该怎么解决?求大佬指教!
代码如下:#include
#define uint unsigned int
#define uchar unsigned char
sbit s1 = P3^2;//闹钟开关
sbit s2 = P3^3;//设置
sbit s3 = P3^4;//小时键
sbit s4 = P3^5;//分
sbit s5 = P3^6;//退出键
sbit fs = P3^0;//蜂鸣器
sbit d = P3^1;//小灯
unsigned char mfsw;//秒,分,时,计数器
uchar f_naos_nao;//闹钟分,时
bit flag_nao;//闹钟标志
void zuo();
void you();
void delay(uint i);
//void ledscan(uchar huchar muchar s);
void alarm();
void tiaojie();
void delay(uint i)
         while(i--);
void zuo()
{unsigned char d;
         unsigned char a = 0x01;
         for(d = 0;d<8;d++)
                 P0 = ~a;
                 delay(1);
           a = a<<1;
                 if(a == 0)
                         a = 0x01;
void ledscan(uchar huchar muchar s) reentrant
         uchar LED[]={0x3f0x060x5b0x4f0x660x6d0x7d0x070x7f0x6f};
uint j;
P1 = LED[s%10];
P2 = 0x7f;
for(j = 0;j<100;j++);
P2 = 0xff;
P1 = LED[s/10];
P2 = 0xbf;
P2 = 0xff;
P1 = 0x40;
P2 = 0Xdf;
P2 = 0xff;
P1 = LED[m%10];
P2 = 0xef;
P2 = 0xff;
P1 = LED[m/10];
P2 = 0xf7;
P2 = 0xff;
P1 = 0x40;
P2 = 0xfb;
P2 = 0xff;
P1 = LED[h%10];
P2 = 0xfd;
P2 = 0xff;
P1 = LED[h/10];
P2 = 0xfe;
P2 = 0xff;
void tiaojie()
         if(s3 == 0)
                 ledscan(sfm);
                 if(s3 == 0)
                         if(s == 23)
                                 s = 0;
                                 else
                                         s++;
                                         while(!s3)ledscan(sfm);
         else if(s4 == 0)
                 ledscan(sfm);
                 if(s4 == 0)
                         if(f == 59)
                                 f = 0;
                                 else
                                         f++;
                                         while(!s4)ledscan(sfm);
}void alarm()
         //uchar a;
         if(flag_nao)
                 if(f==f_nao  s==s_nao)
                         while(m<=5  flag_nao)
                                 fs = ~fs;
                                 ledscan(sfm);}
void t0() interrupt 1
         TH0 = (65536-50000)/256;
         TL0 = (65536-50000)%256;
         w++;
         if(w == 20)
                 w = 0;
                 m++;
                 if(m == 60)
                         f++;
                         m = 0;
                         if(f == 60)
                         {s++;
                                 f = 0;
                                 if(s == 24)
                                         s = 0;}
         }zuo();
void guan_naozhong() interrupt 0
         flag_nao = ~flag_nao;
         d = ~d;
         while(!s1)ledscan(sfm);
void naozhong()interrupt 2
         f_nao = f;
         s_nao = s;
         while(s5)
                 ledscan(s_naof_nao0);
                 if(s3 == 0)
                         if(s3 == 0)
                                 if(s_nao == 24)s_nao =0;
                                 else s_nao++;
                         while(!s3) ledscan(s_naof_nao0);
                 else if(s4 == 0)
                         if(s4 == 0)
                                 if(f_nao == 59)f_nao =0;
                                         else f_nao++;
                         while(!s4)
void main()
         TMOD = 0X01;
         TH0 =(65536 - 50000)/256;
         TL0 =(65536 - 50000)%256;
         TR0 = 1;
         ET0 = 1;
         IT1 = 1;
         IT0 = 0;
         EX1 = 1;
         EX0 = 1;
         PT0 = 1;
         EA = 1;
         f = 0;
         m = 0;
         fs = 0;
         flag_nao = 0;
         while(1)
                 ledscan(sfm);
                 tiaojie();
                 alarm();
                 //zuo();
回帖(1)
康沧鹤
2023-9-27 09:56:39
刷新率不够,或者置位方式不恰当,造成数据位都是先清除后置位。可以看看具体显示函数处理方式是否可以调整。
举报
更多回帖
