尝试过各种img,包括debian Image 55/69,sdcard.img。
通过tftp升级SPL/UBOOT,但是SD卡boot依然报错:
dwmci_d: DATA ERROR!mmc_bre: Failed to read blocksdwmci_s:
timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklendwmci_s: Timeout.mmc_bre: Failed to set blocklenBOOT fail,Error is 0xffffffffUART下,执行mmc info
Card did not respond to voltage select! : -110TF卡是SanDisk Ultra 64GB Class 10 UHS Class A-1。
是否应该考虑换一个卡?
更新:
换了一个maxell的class 10 HC卡,同样还是无法找到SD卡。
--------EEPROM INFO--------In: serial@10000000Out: serial@10000000Err: serial@10000000Model: StarFive VisionFive V2Net: eth0: ethernet@16030000, eth1: ethernet@16040000unable to select a modeCard did not respond to voltage select! : -110bootmode flash device 0Card did not respond to voltage select! : -110Hit any key to stop autoboot: 0Card did not respond to voltage select! : -110Couldn't find partition mmc 0:3Can't set block deviceImporting environment from mmc0 ...## Warning: Input data exceeds 1048576 bytes - truncated## Info: input data size = 1048578 = 0x100002## Error: "boot2" not definedCard did not respond to voltage select! : -110产品信息:
Product full SN: VF7110A1-2250-D008E000-00001054
data version: 0x2
PCB revision: 0xa1
BOM revision: A
