从
GitHub - starfive-tech/Tools 下载的Tools中并没有create_sbl,按照readme,也能编译一个u-boot-spl.bin.normal.out文件,然后通过软件技术参考手册重新编译的visionfive2_fw_payload.img和u-boot-spl.bin.normal.out文件,通过“恢复Bootloader”的方式更新后,无法boot起来。
在
论坛上,找到一个官方提供的visionfive2_fw_payload.img和u-boot-spl.bin.normal.out文件,下载后,能正常boot起来。
我需要在M模式下配置寄存器,要改opensbi程序或者uboot程序,请问有谁遇到过吗?
Net: eth0: ethernet@16030000, eth1: ethernet@16040000
switch to par
titions #0, OK
mmc1 is current device
found device 1
bootmode flash device 1
Can’t set block device
Failed to load ‘/boot/uEnv.txt’
Hit any key to stop autoboot: 2 1 0
Importing environment from mmc1 …
Warning: Input data exceeds 1048576 bytes - truncated
Info: input data size = 1048578 = 0x100002
Error: “boot2” not defined
Warning: defaulting to text format
switch to partitions #0, OK
Scanning mmc 1:2…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
823 bytes read in 8 ms (99.6 KiB/s)
U-Boot menu
1: Debian GNU/Linux bookworm/sid 5.15.0-starfive
2: Debian GNU/Linux bookworm/sid 5.15.0-starfive (rescue target)
Enter choice: 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive
Retrieving file: /boot/initrd.img-5.15.0-starfive
9684953 bytes read in 425 ms (21.7 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.0-starfive
8015200 bytes read in 353 ms (21.7 MiB/s)
append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Retrieving file: /boot/dtbs/starfive/starfive_visionfive2.dtb
Failed to load ‘/boot/dtbs/starfive/starfive_visionfive2.dtb’
kernel_comp_addr_r or kernel_comp_size is not provided!
append: root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 single
SCRIPT FAILED: continuing…
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Card did not respond to voltage select! : -110
** Unable to read file ubootefi.var **
Failed to load EFI variables
Scanning mmc 1:3…
starfive_pcie pcie@2C000000: Starfive PCIe bus probed.
PCI: Failed autoconfig bar 10
ethernet@16030000 Waiting for PHY auto negotiation to complete… TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete… TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16030000 Waiting for PHY auto negotiation to complete…
