在学习“Nuclei™ N100 系列处理器内核快速集成手册”时,在第6章进行实验出错warning
Warning-[STASKW_RMIEAFL] Illegal entry
/home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_mem_init.v, 28
Illegal entry found at file
/home/xiaotu/riscv/n101_cct/vsim/demo_irqc/demo_irqc.verilog line 1 while
execu
ting $readmem.
Please ensure that the file has proper entries.
ILM 0x00: xxxxxxxx
ILM 0x01: xxxxxxxx
ILM 0x02: xxxxxxxx
ILM 0x03: xxxxxxxx
ILM 0x04: xxxxxxxx
ILM 0x05: xxxxxxxx
ILM 0x06: xxxxxxxx
ILM 0x07: xxxxxxxx
ILM 0x16: xxxxxxxx
ILM 0x20: xxxxxxxx
SEED = 20210812225456
FORCE_DELAY= 0
*Verdi3* Loading libsscore_vcs201606.so
*Verdi3* : FSDB_GATE is set.
*Verdi3* : FSDB_RTL is set.
*Verdi3* : Enable Parallel Dumping.
FSDB Dumper for VCS, Release Verdi3_L-2016.06-1, Linux x86_64/64bit, 07/10/2016
(C) 1996 - 2016 by Synopsys, Inc.
*Verdi3* : Create FSDB file 'tb_top.fsdb'
*Verdi3* : Begin traversing the scope (tb_top), layer (0).
*Verdi3* : Enable +mda dumping.
*Verdi3* : End of traversing.
TESTCASE= /home/xiaotu/riscv/n101_cct/vsim/demo_irqc/demo_irqc
FORCE_IRQ= 0
FORCE_RESP_ERR= 0
WFI_FORCE_IRQ= 1
/home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_mem_init.v, 70
executing $readmem.
executing $readmem.
Time Out !!!
$finish called from file "/home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_top.v", line 145.
$finish at simulation time 20000000000
V C S S i m u l a t i o n R e p o r t
Time: 200000000000 ps
CPU Time: 12.950 seconds; Data structure size: 2.8Mb
Thu Aug 12 22:55:12 2021
make[1]: Leaving directory `/home/xiaotu/riscv/n101_cct/vsim/run'
步骤一二三均可正确执行,但到第四步make run_test TESTCASE=$PWD/demo_irqc/demo_irqc,就出warning。
运行case=rv32ui-p-add就没有问题显示PASS,“demo_irqc.verilog”与“rv32ui-p-add.verilog”文件里面的16进制格式写法一样,但是一个行,一个不行。
是在不清楚问题出在哪里?!
