CH32V003使用ADC八通道转换注意事项 - RISC-V MCU技术社区 - 电子技术论坛 - 广受欢迎的专业电子论坛
分享 收藏 返回
[文章]
文章来源:https://www.cnblogs.com/wchmcu/p/17535947.html
本文以CH32V003_F4P6(20Pin)为模板
1、PA1、PA2为外部晶振输入引脚,同时也是ADC的CH1与CH0,所以需要先在system_ch32v00x.c文件中更改为内部48M的宏即可。
注:CH32V003的ADC数据寄存器为10,通道转换值为[0-1024],精度为VCC/1024,VCC与外部参考电压相同[2.8-5.5]
2、ADC初始化与通道配置。
  1. void ADC_Function_Init(void)
  2. {
  3. ADC_InitTypeDef ADC_InitStructure = {0};
  4. GPIO_InitTypeDef GPIO_InitStructure = {0};
  5. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOC |RCC_APB2Periph_GPIOD, ENABLE);
  6. RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  7. RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  8. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2;//ch0 ch1
  9. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  10. GPIO_Init(GPIOA, &GPIO_InitStructure);
  11. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//ch2
  12. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  13. GPIO_Init(GPIOC, &GPIO_InitStructure);
  14. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3 | GPIO_Pin_5 |GPIO_Pin_6|GPIO_Pin_4;//ch3 ch4 ch5 ch6 ch7
  15. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  16. GPIO_Init(GPIOD, &GPIO_InitStructure);
  17. ADC_DeInit(ADC1);
  18. ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  19. ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  20. ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  21. ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  22. ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  23. ADC_InitStructure.ADC_NbrOfChannel = 8;//此处为8个待转换的ADC规则组通道
  24. ADC_Init(ADC1, &ADC_InitStructure);
  25. ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_241Cycles);
  26. ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_241Cycles);
  27. ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_241Cycles);
  28. ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_241Cycles);
  29. ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_241Cycles);
  30. ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_241Cycles);
  31. ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_241Cycles);
  32. ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_241Cycles);
  33. ADC_DMACmd(ADC1, ENABLE);
  34. ADC_Cmd(ADC1, ENABLE);
  35. ADC_ResetCalibration(ADC1);
  36. while(ADC_GetResetCalibrationStatus(ADC1));
  37. ADC_StartCalibration(ADC1);
  38. while(ADC_GetCalibrationStatus(ADC1));
  39. }
3、DMA配置
  1. void DMA_Tx_Init(DMA_Channel_TypeDef *DMA_CHx, u32 ppadr, u32 memadr, u16 bufsize)
  2. {
  3. DMA_InitTypeDef DMA_InitStructure = {0};
  4. RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  5. DMA_DeInit(DMA_CHx);
  6. DMA_InitStructure.DMA_PeripheralBaseAddr = ppadr;
  7. DMA_InitStructure.DMA_MemoryBaseAddr = memadr;
  8. DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  9. DMA_InitStructure.DMA_BufferSize = bufsize;
  10. DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  11. DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  12. DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  13. DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  14. DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//单次扫描转换,可以开启DMA中断,此处改为循环模式
  15. DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  16. DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  17. DMA_Init(DMA_CHx, &DMA_InitStructure);
  18. }
4、mian函数中需要在开启ADC开始转换之前调用DMA通道初始化与使能,否则ADC_ValueBuf中的数据与通道会不对应(ADC_ValueBuf[0]-ADC_ValueBuf[7]对应ADC通道的0-7的采样值)
  1. int main(void)
  2. {
  3. u16 i;
  4. Delay_Init();
  5. USART_Printf_Init(115200);
  6. printf("SystemClk:%drn", SystemCoreClock);
  7. ADC_Function_Init();
  8. DMA_Tx_Init(DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)ADC_ValueBuf, 8);
  9. DMA_Cmd(DMA1_Channel1, ENABLE);
  10. ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  11. Delay_Ms(50);
  12. ADC_SoftwareStartConvCmd(ADC1, DISABLE);//若DMA工作在循环模式,此处不需要关闭触发。
  13. for(i = 0; i < 8; i++){
  14. printf("%04drn", ADC_ValueBuf[i]);
  15. Delay_Ms(10);
  16. }
  17. while(1);
  18. }
更多回帖
