ST意法半导体
直播中
哈哈哈
11年用户 963经验值
擅长:可编程逻辑 电源/新能源
私信 关注
[问答]
smt32MP157D optee完成后没有进入u-boot,系统重启是为什么?
使用最新V5版源码及SDK,分立电源
使用STM32CubeProgrammer烧写。
NOtiCE:  CPU: STM32MP157DAA Rev.Z
NOTICE:  Model: 2:HDIT TF-A 1 STM32MP157D eval daughter
NOTICE:  get_otp_index board_id:59
NOTICE:  stm32_get_otp_value 0
NOTICE:  boardinfo over
NOTICE:  get_otp_index cfg0_otp:0
NOTICE:  fixed reg init
NOTICE:  register fixed reg regulator-vddcore!
NOTICE:  register fixed reg regulator-3p3v!
NOTICE:  register fixed reg regulator-vdd!
NOTICE:  register fixed reg regulator-vdd-usb!
NOTICE:  get_otp_index hw2_tp:18
NOTICE:  get_otp_index hw2_otp:18
INFO:    Reset reason (0x15):
INFO:      Power-on Reset (rst_por)
INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO:    FCONF: Reading firmware configuration information for: stm32mp_io
INFO:    Using USB
INFO:      Instance 2
INFO:    Boot used partition fsbl1
NOTICE:  BL2: v2.8-stm32mp1-r1.0(debug))
NOTICE:  BL2: Built : 22:20:23, Jul 21 2023
INFO:    BL2: Doing platform setup
INFO:    RAM: DDR3-DDR3L 32bits 533000kHz
INFO:    Memory size = 0x40000000 (1024 MB)
INFO:    DFU USB START...
INFO:    phase ID :3, Manifestation 3 at c71577fe
INFO:    Send detach request
INFO:    Receive DFU Detach
INFO:    DFU USB STOP...
INFO:    BL2: Loading image id 1
INFO:    Loading image id=1 at address 0x2ffff000
INFO:    Image id=1 loaded: 0x2ffff000 - 0x2ffff1ea
INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000
INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
INFO:    FCONF: Reading firmware configuration information for: stm32mp1_firewall
INFO:    BL2: Loading image id 4
INFO:    Loading image id=4 at address 0xfe000000
INFO:    Image id=4 loaded: 0xfe000000 - 0xfe00001c
INFO:    OPTEE ep=0xfe000000
INFO:    OPTEE header info:
INFO:          magic=0x4554504f
INFO:          version=0x2
INFO:          arch=0x0
INFO:          flags=0x0
INFO:          nb_images=0x1
INFO:    BL2: Loading image id 8
INFO:    Loading image id=8 at address 0xfe000000
INFO:    Image id=8 loaded: 0xfe000000 - 0xfe03ab68
INFO:    BL2: Skip loading image id 9
INFO:    BL2: Loading image id 2
INFO:    Loading image id=2 at address 0xc0500000
INFO:    Image id=2 loaded: 0xc0500000 - 0xc051d350
INFO:    BL2: Skip loading image id 16
INFO:    BL2: Loading image id 5
INFO:    Loading image id=5 at address 0xc0100000
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01ff618
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0xfe000000
INFO:    SPSR = 0x1d3
I/TC: Early console on UART#4
D/TC:0   add_phys_mem:662 MCUSRAM_BASE type IO_SEC 0x30000000 size 0x00060000
D/TC:0   add_phys_mem:662 RETRAM_BASE type IO_SEC 0x38000000 size 0x00010000
D/TC:0   add_phys_mem:662 TEE_RAM_START type ROM_SEC 0xfe000000 size 0x00200000
D/TC:0   add_phys_mem:662 DDR_BASE type RAM_NSEC 0xc0000000 size 0x00001000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0xa0021000ul, CORE_MMU_PGDIR_SIZE) type IO_SEC 0xa0000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x54000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x54000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x50000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x50000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x48000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x48000000 size 0x01200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x5c000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x5c000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x5a000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x5a000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x50020000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x50000000 size 0x00200000
D/TC:0   add_phys_mem:676 Physical mem map overlaps 0x50000000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x54000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x54000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x50000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x50000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x5c000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x5c000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x5a000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x5a000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x50020000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x50000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x44000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x44000000 size 0x00200000
D/TC:0   add_phys_mem:662 ROUNDDOWN(0x40000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x40000000 size 0x00200000
D/TC:0   add_phys_mem:662 TA_RAM_START type TA_RAM 0xfe200000 size 0x01e00000
D/TC:0   add_phys_mem:662 VCORE_UNPG_RW_PA type TEE_RAM_RW 0xfe03a000 size 0x001c6000
D/TC:0   add_phys_mem:662 VCORE_UNPG_RX_PA type TEE_RAM_RX 0xfe000000 size 0x0003a000
D/TC:0   add_va_space:702 type RES_VASPACE size 0x00a00000
D/TC:0   add_va_space:702 type SHM_VASPACE size 0x02000000
D/TC:0   dump_mmap_table:829 type TA_RAM       va 0xf6400000..0xf81fffff pa 0xfe200000..0xffffffff size 0x01e00000 (pgdir)
D/TC:0   dump_mmap_table:829 type ROM_SEC      va 0xf8400000..0xf85fffff pa 0xfe000000..0xfe1fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xf8600000..0xf87fffff pa 0xa0000000..0xa01fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xf8800000..0xf89fffff pa 0x5c000000..0x5c1fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_NSEC      va 0xf8a00000..0xf8bfffff pa 0x5c000000..0x5c1fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_NSEC      va 0xf8c00000..0xf8dfffff pa 0x5a000000..0x5a1fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xf8e00000..0xf8ffffff pa 0x5a000000..0x5a1fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xf9000000..0xf91fffff pa 0x54000000..0x541fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_NSEC      va 0xf9200000..0xf93fffff pa 0x54000000..0x541fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_NSEC      va 0xf9400000..0xf95fffff pa 0x50000000..0x501fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xf9600000..0xf97fffff pa 0x50000000..0x501fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xf9800000..0xfa9fffff pa 0x48000000..0x491fffff size 0x01200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_NSEC      va 0xfac00000..0xfadfffff pa 0x44000000..0x441fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type IO_NSEC      va 0xfae00000..0xfaffffff pa 0x40000000..0x401fffff size 0x00200000 (pgdir)
D/TC:0   dump_mmap_table:829 type RES_VASPACE  va 0xfb000000..0xfb9fffff pa 0x00000000..0x009fffff size 0x00a00000 (pgdir)
D/TC:0   dump_mmap_table:829 type SHM_VASPACE  va 0xfbc00000..0xfdbfffff pa 0x00000000..0x01ffffff size 0x02000000 (pgdir)
D/TC:0   dump_mmap_table:829 type RAM_NSEC     va 0xfdf8f000..0xfdf8ffff pa 0xc0000000..0xc0000fff size 0x00001000 (smallpg)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xfdf90000..0xfdf9ffff pa 0x38000000..0x3800ffff size 0x00010000 (smallpg)
D/TC:0   dump_mmap_table:829 type IO_SEC       va 0xfdfa0000..0xfdffffff pa 0x30000000..0x3005ffff size 0x00060000 (smallpg)
D/TC:0   dump_mmap_table:829 type TEE_RAM_RX   va 0xfe000000..0xfe039fff pa 0xfe000000..0xfe039fff size 0x0003a000 (smallpg)
D/TC:0   dump_mmap_table:829 type TEE_RAM_RW   va 0xfe03a000..0xfe1fffff pa 0xfe03a000..0xfe1fffff size 0x001c6000 (smallpg)
D/TC:0   core_mmu_xlat_table_alloc:526 xlat tables used 1 / 10
D/TC:0   core_mmu_xlat_table_alloc:526 xlat tables used 2 / 10
D/TC:0   core_mmu_xlat_table_alloc:526 xlat tables used 3 / 10
I/TC:
I/TC: Embedded DTB found
I/TC: OP-TEE version: Unknown_3.19 () #19 Tue Jul 25 06:34:18 UTC 2023 arm
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/ ... ing_guidelines.html
I/TC: Primary CPU initializing
I/TC: main_init_gic over
I/TC: init_vfp_nsec over
D/TC:0 0 call_preinitcalls:21 level 2 mobj_mapped_shm_init()
D/TC:0 0 mobj_mapped_shm_init:463 Shared memory address range: fbc00000, fdc00000
D/TC:0 0 call_initcalls:40 level 1 register_time_source()
D/TC:0 0 call_initcalls:40 level 1 initialize_bsec()
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[1] = cfg0_otp 0bit offset: 0, length: 8
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[2] = part_number_otp 1bit offset: 0, length: 8
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[3] = monotonic_otp 4bit offset: 0, length: 32
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[4] = nand_otp 9bit offset: 0, length: 32
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[5] = uid_otp 13bit offset: 0, length: 96
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[6] = package_otp 16bit offset: 0, length: 32
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[7] = hw2_otp 18bit offset: 0, length: 32
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[8] = calib 23bit offset: 0, length: 16
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[9] = calib 23bit offset: 16, length: 16
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[10] = pkh_otp 24bit offset: 0, length: 256
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[11] = mac 57bit offset: 0, length: 64
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[12] = board_id 59bit offset: 0, length: 32
D/TC:0 0 save_dt_nvmem_layout:900 nvmem[13] = huk-otp 60bit offset: 0, length: 128
D/TC:0 0 call_initcalls:40 level 1 clk_dt_probe()
D/TC:0 0 clk_dt_probe:202 Probing clocks from devicetree
F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-hse
D/TC:0 0 clk_register:126 Registered clock clk-hse, freq 24000000
D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-hse initialized
F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-hsi
D/TC:0 0 clk_register:126 Registered clock clk-hsi, freq 64000000
D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-hsi initialized
F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-lse
D/TC:0 0 clk_register:126 Registered clock clk-lse, freq 32768
D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-lse initialized
F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-lsi
D/TC:0 0 clk_register:126 Registered clock clk-lsi, freq 32000
D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-lsi initialized
F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-csi
D/TC:0 0 clk_register:126 Registered clock clk-csi, freq 4000000
D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-csi initialized
F/TC:0 0 probe_driver_node:391 Probing stm32mp1_clock on node rcc@50000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000
D/TC:0 0 clk_register:126 Registered clock (null), freq 533000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 133250000
D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000
D/TC:0 0 clk_register:126 Registered clock (null), freq 24000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 4000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 32768
D/TC:0 0 clk_register:126 Registered clock (null), freq 0
D/TC:0 0 clk_register:126 Registered clock (null), freq 208877928
D/TC:0 0 clk_register:126 Registered clock (null), freq 32000
D/TC:0 0 clk_register:126 Registered clock (null), freq 12000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 650000000
D/TC:0 0 clk_register:126 Registered clock (null), freq 208877929
D/TC:0 0 clk_register:126 Registered clock (null), freq 24573874
D/TC:0 0 clk_register:126 Registered clock (null), freq 11290698
F/TC:0 0 __clk_enable:1174 Clock 220 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 221 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 222 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 223 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 224 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 225 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 226 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 228 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 229 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 230 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 67 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 66 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 113 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 128 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 69 has been enabled
F/TC:0 0 __clk_enable:1174 Clock 65 has been enabled
D/TC:0 0 probe_driver_node:398 element: stm32mp1_clock on node rcc@50000000 initialized
D/TC:0 0 call_initcalls:40 level 2 probe_dt_drivers_early()
D/TC:0 0 add_node_to_probe:596 element: cpu0-opp-table on node stm32mp1-cpu-opp
D/TC:0 0 print_probe_list:352 Probe list: 1 elements
D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table
D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end
D/TC:0 0 add_node_to_probe:596 element: soc on node simple-bus
D/TC:0 0 print_probe_list:352 Probe list: 2 elements
D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc
D/TC:0 0 add_node_to_probe:596 element: ahb on node simple-bus
D/TC:0 0 print_probe_list:352 Probe list: 3 elements
D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb
D/TC:0 0 add_node_to_probe:596 element: regulator-vddcore on node fixed-regulator
D/TC:0 0 print_probe_list:352 Probe list: 4 elements
D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vddcore
D/TC:0 0 add_node_to_probe:596 element: regulator-3p3v on node fixed-regulator
D/TC:0 0 print_probe_list:352 Probe list: 5 elements
D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-3p3v
D/TC:0 0 add_node_to_probe:596 element: regulator-vdd on node fixed-regulator
D/TC:0 0 print_probe_list:352 Probe list: 6 elements
D/TC:0 0 add_node_to_probe:596 element: regulator-vdd-usb on node fixed-regulator
D/TC:0 0 print_probe_list:352 Probe list: 7 elements
D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vdd-usb
F/TC:0 0 process_probe_list:505 Probe loop 1 after 0 for deferral(s)
F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-vdd-usb
F/TC:0 0 regulator_register:739 register regulator-vdd-usb
F/TC:0 0 parse_dt:664 regulator-vdd-usb: parse embedded DTB
F/TC:0 0 parse_dt:677 regulator-vdd-usb: min_mv=3300
F/TC:0 0 parse_dt:691 regulator-vdd-usb: max_mv=3300
F/TC:0 0 parse_properties:552 regulator-vdd-usb: 0x1
D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-vdd-usb initialized
F/TC:0 0 parse_dt:664 regulator-vdd: parse embedded DTB
F/TC:0 0 parse_dt:677 regulator-vdd: min_mv=3300
F/TC:0 0 parse_dt:691 regulator-vdd: max_mv=3300
F/TC:0 0 parse_properties:552 regulator-vdd: 0x1
D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-vdd initialized
F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-3p3v
F/TC:0 0 regulator_register:739 register regulator-3p3v
F/TC:0 0 parse_dt:664 regulator-3p3v: parse embedded DTB
F/TC:0 0 parse_dt:677 regulator-3p3v: min_mv=3300
F/TC:0 0 parse_dt:691 regulator-3p3v: max_mv=3300
F/TC:0 0 parse_properties:552 regulator-3p3v: 0x1
D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-3p3v initialized
F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-vddcore
F/TC:0 0 regulator_register:739 register regulator-vddcore
F/TC:0 0 parse_dt:664 regulator-vddcore: parse embedded DTB
F/TC:0 0 parse_dt:677 regulator-vddcore: min_mv=1200
F/TC:0 0 parse_dt:691 regulator-vddcore: max_mv=1350
F/TC:0 0 parse_properties:552 regulator-vddcore: 0x1
D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-vddcore initialized
F/TC:0 0 probe_driver_node:391 Probing simple-bus on node ahb
D/TC:0 0 probe_driver_node:398 element: simple-bus on node ahb initialized
F/TC:0 0 probe_driver_node:391 Probing simple-bus on node soc
D/TC:0 0 add_node_to_probe:596 element: timer@44006000 on node stm32-timer
D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000
D/TC:0 0 add_node_to_probe:596 element: rcc@50000000 on node stm32mp15_rstctrl
D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000
D/TC:0 0 add_node_to_probe:596 element: pwr@50001000 on node stm32mp1-pwr-regu
D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000
D/TC:0 0 add_node_to_probe:596 element: rtc@5c004000 on node stm32-rtc
D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000
D/TC:0 0 add_node_to_probe:596 element: tzc@5c006000 on node stm32mp1-tzc400
D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000
D/TC:0 0 add_node_to_probe:596 element: tamp@5c00a000 on node stm32-tamp
D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000
D/TC:0 0 add_node_to_probe:596 element: pin-controller@50002000 on node stm32_gpio
D/TC:0 0 print_probe_list:352 Probe list: 8 elements
D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000
D/TC:0 0 add_node_to_probe:596 element: pin-controller-z@54004000 on node stm32_gpio
D/TC:0 0 print_probe_list:352 Probe list: 9 elements
D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000
D/TC:0 0 add_node_to_probe:596 element: etzpc@5c007000 on node stm32-etzpc
D/TC:0 0 print_probe_list:352 Probe list: 10 elements
D/TC:0 0 print_probe_list:354 |- Driver stm32-etzpc probes on node etzpc@5c007000
D/TC:0 0 probe_driver_node:398 element: simple-bus on node soc initialized
F/TC:0 0 probe_driver_node:391 Probing stm32mp1-cpu-opp on node cpu0-opp-table
F/TC:0 0 get_supply_phandle:114 cpu: supplied by 4
E/TC:0 0 stm32mp1_cpu_opp_init:363 stm32mp1_cpu_opp_init 0
D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem part_number_otp = 1: 1 bit offset: 0, length: 8
D/TC:0 0 stm32mp1_cpu_opp_get_dt_subnode:292 Found OPP 0 (800000kHz/1350mV) from DT
F/TC:0 0 regulator_set_voltage:299 regulator-vddcore 1350mV
E/TC:0 0 opp_set_voltage:68 opp_set_voltage 1350mV rst 4294901769
E/TC:0 0 opp_set_voltage:80 get voltage 1200mV
D/TC:0 0 stm32mp1_cpu_opp_get_dt_subnode:304 clk_cpu 650000000 Hz,res 4294901760
E/TC:0 0 stm32mp1_cpu_opp_init:377 stm32mp1_cpu_opp_get_dt_subnode 4294901760
E/TC:0 0 probe_driver_node:413 Failed to probe stm32mp1-cpu-opp on node cpu0-opp-table: 0xffff0000
F/TC:0 0 process_probe_list:505 Probe loop 2 after 0 for deferral(s)
D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end
F/TC:0 0 probe_driver_node:391 Probing stm32-etzpc on node etzpc@5c007000
D/TC:0 0 stm32_etzpc_set_driverdata:517 ETZPC revision 0x32, per_sec 96, ahb_sec 0, tzma 2
F/TC:0 0 etzpc_configure_decprot:148 ID : 3, CONF 3
F/TC:0 0 etzpc_configure_decprot:148 ID : 4, CONF 3
F/TC:0 0 etzpc_configure_decprot:148 ID : 5, CONF 3
F/TC:0 0 etzpc_configure_decprot:148 ID : 12, CONF 3
F/TC:0 0 etzpc_configure_decprot:148 ID : 7, CONF 0
F/TC:0 0 etzpc_configure_decprot:148 ID : 8, CONF 3
F/TC:0 0 etzpc_configure_decprot:148 ID : 10, CONF 1
F/TC:0 0 etzpc_configure_decprot:148 ID : 11, CONF 1
F/TC:0 0 etzpc_configure_decprot:148 ID : 0, CONF 0
F/TC:0 0 etzpc_configure_decprot:148 ID : 1, CONF 0
F/TC:0 0 etzpc_configure_decprot:148 ID : 2, CONF 0
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 7 - attr 0 - requested 0
D/TC:0 0 add_node_to_probe:596 element: rng@54003000 on node stm32_rng
D/TC:0 0 print_probe_list:354 |- Driver stm32_rng probes on node rng@54003000
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 5 - attr 3 - requested 0
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 5 - attr 3 - requested 3
D/TC:0 0 add_node_to_probe:596 element: i2c@5c002000 on node stm32_i2c
D/TC:0 0 print_probe_list:354 |- Driver stm32_i2c probes on node i2c@5c002000
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 2 - attr 0 - requested 0
D/TC:0 0 add_node_to_probe:596 element: watchdog@5c003000 on node stm32-iwdg
D/TC:0 0 print_probe_list:352 Probe list: 11 elements
D/TC:0 0 print_probe_list:354 |- Driver stm32-iwdg probes on node watchdog@5c003000
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 0 - attr 0 - requested 0
D/TC:0 0 probe_driver_node:398 element: stm32-etzpc on node etzpc@5c007000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32_gpio on node pin-controller-z@54004000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@54004000
D/TC:0 0 _fdt_stm32_gpio_controller:721 GPIO bank Z assigned to non-secure
F/TC:0 0 __clk_enable:1174 Clock 95 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank Z (8 pins) @f9004000
D/TC:0 0 probe_driver_node:398 element: stm32_gpio on node pin-controller-z@54004000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32_gpio on node pin-controller@50002000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50002000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50003000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50004000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50005000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50006000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50007000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50008000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50009000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@5000a000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@5000b000
D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@5000c000
F/TC:0 0 __clk_enable:1174 Clock 84 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank A (16 pins) @f9402000
F/TC:0 0 __clk_enable:1174 Clock 85 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank B (16 pins) @f9403000
F/TC:0 0 __clk_enable:1174 Clock 86 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank C (16 pins) @f9404000
F/TC:0 0 __clk_enable:1174 Clock 87 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank D (16 pins) @f9405000
F/TC:0 0 __clk_enable:1174 Clock 88 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank E (16 pins) @f9406000
F/TC:0 0 __clk_enable:1174 Clock 89 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank F (16 pins) @f9407000
F/TC:0 0 __clk_enable:1174 Clock 90 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank G (16 pins) @f9408000
F/TC:0 0 __clk_enable:1174 Clock 91 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank H (16 pins) @f9409000
F/TC:0 0 __clk_enable:1174 Clock 92 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank I (16 pins) @f940a000
F/TC:0 0 __clk_enable:1174 Clock 93 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank J (16 pins) @f940b000
F/TC:0 0 __clk_enable:1174 Clock 94 has been enabled
D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank K (8 pins) @f940c000
D/TC:0 0 probe_driver_node:398 element: stm32_gpio on node pin-controller@50002000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32-tamp on node tamp@5c00a000
D/TC:0 0 stm32_tamp_parse_passive_conf:1088 Passive conf from dt: precharge=0, nb_sample=0, clk_div=32768
D/TC:0 0 stm32_tamp_parse_active_conf:1204 Active conf from dt: no filter clk_div=1
F/TC:0 0 stm32_tamp_probe:1350 STM32 TAMPER V1.2
D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0xff00 to 0xf86218e4
D/TC:0 0 gic_it_set_cpu_mask:352 cpu_mask: 0x300
D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf86214e5
D/TC:0 0 probe_driver_node:398 element: stm32-tamp on node tamp@5c00a000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32mp1-tzc400 on node tzc@5c006000
D/TC:0 0 tzc_set_driverdata:124 TZC400 Filters 2 Regions 8
D/TC:0 0 add_carved_out_nsec:382 0xc0000000 - 0xfdffffff : Sec access 0 NS access 0x87fb87fb
D/TC:0 0 tzc_dump_state:473 region 0
D/TC:0 0 tzc_dump_state:476 region_base: 0x0000000000000000
D/TC:0 0 tzc_dump_state:479 region_top: 0x00000000ffffffff
D/TC:0 0 tzc_dump_state:481 secure rw: TZC_REGION_S_NONE
D/TC:0 0 tzc_dump_state:486 filter 0 enable
D/TC:0 0 tzc_dump_state:486 filter 1 enable
D/TC:0 0 tzc_dump_state:473 region 1
D/TC:0 0 tzc_dump_state:476 region_base: 0x00000000fe000000
D/TC:0 0 tzc_dump_state:481 secure rw: TZC_REGION_S_RDWR
D/TC:0 0 tzc_dump_state:473 region 2
D/TC:0 0 tzc_dump_state:476 region_base: 0x00000000c0000000
D/TC:0 0 tzc_dump_state:479 region_top: 0x00000000fdffffff
D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0xff to 0xf8621824
D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf8621424
D/TC:0 0 probe_driver_node:398 element: stm32mp1-tzc400 on node tzc@5c006000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32-rtc on node rtc@5c004000
F/TC:0 0 __clk_enable:1174 Clock 192 has been enabled
D/TC:0 0 probe_driver_node:398 element: stm32-rtc on node rtc@5c004000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32mp1-pwr-regu on node pwr@50001000
F/TC:0 0 regulator_register:739 register reg11
F/TC:0 0 parse_dt:664 reg11: parse embedded DTB
F/TC:0 0 parse_dt:677 reg11: min_mv=1100
F/TC:0 0 parse_dt:691 reg11: max_mv=1100
F/TC:0 0 regulator_list_voltages:440 min_mv=1100 max_mv=1100
F/TC:0 0 get_supply_phandle:114 vdd: supplied by 25
F/TC:0 0 regulator_register:739 register reg18
F/TC:0 0 parse_dt:664 reg18: parse embedded DTB
F/TC:0 0 parse_dt:677 reg18: min_mv=1800
F/TC:0 0 parse_dt:691 reg18: max_mv=1800
F/TC:0 0 regulator_list_voltages:440 min_mv=1800 max_mv=1800
F/TC:0 0 regulator_register:739 register usb33
F/TC:0 0 parse_dt:664 usb33: parse embedded DTB
F/TC:0 0 parse_dt:677 usb33: min_mv=3300
F/TC:0 0 parse_dt:691 usb33: max_mv=3300
F/TC:0 0 regulator_list_voltages:440 min_mv=3300 max_mv=3300
F/TC:0 0 get_supply_phandle:114 vdd_3v3_usbfs: supplied by 26
D/TC:0 0 probe_driver_node:398 element: stm32mp1-pwr-regu on node pwr@50001000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32mp15_rstctrl on node rcc@50000000
D/TC:0 0 probe_driver_node:398 element: stm32mp15_rstctrl on node rcc@50000000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32-timer on node timer@44006000
D/TC:0 0 probe_driver_node:398 element: stm32-timer on node timer@44006000 initialized
F/TC:0 0 process_probe_list:505 Probe loop 3 after 0 for deferral(s)
F/TC:0 0 probe_driver_node:391 Probing stm32-iwdg on node watchdog@5c003000
F/TC:0 0 __clk_enable:1174 Clock 68 has been enabled
F/TC:0 0 __clk_disable:1187 Clock 68 has been disabled
D/TC:0 0 register_periph:104 Register IWDG1 as secure
D/TC:0 0 probe_driver_node:398 element: stm32-iwdg on node watchdog@5c003000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32_i2c on node i2c@5c002000
D/TC:0 0 i2c_compute_timing:454 I2C SDADEL(min/max): 18/519, SCLDEL(Min): 285
D/TC:0 0 i2c_compute_timing:552 I2C TIMINGR (PRESC/SCLDEL/SDADEL): 1/8/1
D/TC:0 0 i2c_compute_timing:554 I2C TIMINGR (SCLH/SCLL): 27/38
D/TC:0 0 i2c_compute_timing:556 I2C TIMINGR: 0x10811b26
D/TC:0 0 i2c_setup_timing:643 I2C Freq(400000Hz), Clk Source(64000000)
D/TC:0 0 i2c_setup_timing:645 I2C Rise(185) and Fall(20) Time
D/TC:0 0 i2c_setup_timing:647 I2C Analog Filter(On), DNF(0)
F/TC:0 0 __clk_enable:1174 Clock 140 has been enabled
F/TC:0 0 __clk_disable:1187 Clock 140 has been disabled
D/TC:0 0 probe_driver_node:398 element: stm32_i2c on node i2c@5c002000 initialized
F/TC:0 0 probe_driver_node:391 Probing stm32_rng on node rng@54003000
F/TC:0 0 __clk_enable:1174 Clock 124 has been enabled
F/TC:0 0 __clk_disable:1187 Clock 124 has been disabled
D/TC:0 0 register_periph:104 Register RNG1 as secure
D/TC:0 0 probe_driver_node:398 element: stm32_rng on node rng@54003000 initialized
F/TC:0 0 process_probe_list:505 Probe loop 4 after 0 for deferral(s)
D/TC:0 0 print_probe_list:352 Probe list: 0 elements
D/TC:0 0 call_initcalls:40 level 3 platform_banner()
I/TC: Platform stm32mp1: flavor PLATFORM_FLAVOR - DT stm32mp157d-hdit.dts
D/TC:0 0 call_initcalls:40 level 3 verify_pseudo_tas_conformance()
D/TC:0 0 call_initcalls:40 level 3 mobj_init()
D/TC:0 0 call_initcalls:40 level 3 default_mobj_init()
D/TC:0 0 call_initcalls:40 level 3 tee_cryp_init()
D/TC:0 0 call_initcalls:40 level 4 init_console_from_dt()
F/TC:0 0 __clk_enable:1174 Clock 151 has been enabled
D/TC:0 0 register_periph_iomem:203 IO for non-secure resource 0x40010000
I/TC: DTB enables console (non-secure)
D/TC:0 0 call_initcalls:40 level 4 tee_fs_init_key_manager()
D/TC:0 0 call_initcalls:40 level 5 stm32mp_syscfg_enable_io_compensation()
F/TC:0 0 __clk_enable:1174 Clock 51 has been enabled
D/TC:0 0 call_initcalls:40 level 5 init_pm_support()
F/TC:0 0 __clk_enable:1174 Clock 99 has been enabled
F/TC:0 0 __clk_disable:1187 Clock 99 has been disabled
D/TC:0 0 call_initcalls:40 level 5 probe_dt_drivers()
F/TC:0 0 process_probe_list:505 Probe loop 5 after 0 for deferral(s)
E/TC:0 0 probe_dt_drivers:750 Probe sequence result: 0
D/TC:0 0 call_initcalls:40 level 6 stm32_configure_tamp()
D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP1 enabled as a full tamper
D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP2 enabled as a full tamper
D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP3 enabled as a full tamper
D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP4 enabled as a full tamper
F/TC:0 0 stm32_tamp_set_int_config:398 INT_TAMP5 disabled
F/TC:0 0 stm32_tamp_set_int_config:398 INT_TAMP8 disabled
F/TC:0 0 stm32_tamp_set_ext_config:447 EXT_TAMP1 disabled
F/TC:0 0 stm32_tamp_set_ext_config:447 EXT_TAMP2 disabled
F/TC:0 0 stm32_tamp_set_ext_config:447 EXT_TAMP3 disabled
F/TC:0 0 stm32_tamp_set_config:659 Set passive conf 00000080
F/TC:0 0 stm32_tamp_set_config:664 Set active conf1 00000000
D/TC:0 0 call_initcalls:40 level 6 init_stm32mp1_drivers()
D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0x101ff01 to 0xf8621808
D/TC:0 0 gic_it_set_cpu_mask:352 cpu_mask: 0x1010101
D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf8621409
D/TC:0 0 call_initcalls:40 level 6 stm32mp1_init_scmi_server()
D/TC:0 0 call_initcalls:40 level 6 stm32mp1_init_final_shres()
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp IWDG1    ( 0): secure
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp USART1   ( 1): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp SPI6     ( 2): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp I2C4     ( 3): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp RNG1     ( 4): secure
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp HASH1    ( 5): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp CRYP1    ( 6): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp I2C6     ( 7): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp RTC      ( 8): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp MCU      ( 9): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp PLL3     (10): unregistered
D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp MDMA     (11): unregistered
D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem cfg0_otp = 0: 0 bit offset: 0, length: 8
D/TC:0 0 check_rcc_secure_configuration:347 RCC/PWR secure hardening: TZEN enable, MCKPROT enable
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 2 - attr 0 - requested 3
F/TC:0 0 stm32_etzpc_has_access:393 Check Access 7 - attr 0 - requested 3
D/TC:0 0 call_initcalls:40 level 6 init_stm32mp1_calib()
D/TC:0 0 init_stm32mp1_calib:536 Calibration csi-calibration enabled
F/TC:0 0 set_cal_counter:441 Counter freq is 208877928
F/TC:0 0 __clk_enable:1174 Clock 208 has been enabled
F/TC:0 0 get_freq:192 csi-calibration Freq is 4076800
F/TC:0 0 get_freq:192 csi-calibration Freq is 4111360
F/TC:0 0 get_freq:192 csi-calibration Freq is 4096256
F/TC:0 0 get_freq:192 csi-calibration Freq is 4081792
F/TC:0 0 get_freq:192 csi-calibration Freq is 4065664
F/TC:0 0 get_freq:192 csi-calibration Freq is 3889408
F/TC:0 0 get_freq:192 csi-calibration Freq is 3873152
F/TC:0 0 __clk_disable:1187 Clock 208 has been disabled
D/TC:0 0 init_stm32mp1_calib:536 Calibration hsi-calibration enabled
F/TC:0 0 set_cal_counter:441 Counter freq is 208877928F/TC:0 0 __clk_disable:1187 Clock 208 has been disabled
F/TC:0 0 get_freq:192 hsi-calibration Freq is 63847424
F/TC:0 0 get_freq:192 hsi-calibration Freq is 64135168
F/TC:0 0 get_freq:192 hsi-calibration Freq is 64000000
D/TC:0 0 osc_calibration:300 Calibration : Freq 63847424 , trim 292
F/TC:0 0 get_freq:192 csi-calibration Freq is 4001792
F/TC:0 0 get_freq:192 csi-calibration Freq is 3984512
F/TC:0 0 get_freq:192 csi-calibration Freq is 3985664
D/TC:0 0 osc_calibration:300 Calibration : Freq 3985664 , trim 120
F/TC:0 0 get_freq:192 csi-calibration Freq is 4002432
D/TC:0 0 call_initcalls:40 level 6 stm32mp_syscfg_set_hslv()
D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem hw2_otp = 6: 18 bit offset: 0, length: 32
D/TC:0 0 call_initcalls:40 level 6 init_low_power()
D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0xff00 to 0xf86218b0
D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf86214b1
D/TC:0 0 call_initcalls:40 level 6 stm32mp1_init_lp_states()
D/TC:0 0 stm32mp1_init_lp_states:236 Power configuration: shutdown to 6, suspend to 2
D/TC:0 0 call_initcalls:40 level 6 regulator_core_init()
F/TC:0 0 regulator_core_config:957
F/TC:0 0 regulator_core_config:963 usb33: connect supply
F/TC:0 0 regulator_core_config:963 reg18: connect supply
F/TC:0 0 regulator_core_config:963 reg11: connect supply
F/TC:0 0 _regulator_enable:150 regulator-vddcore
F/TC:0 0 _regulator_enable:188 regulator-vddcore refcount: 1
F/TC:0 0 _regulator_enable:150 regulator-3p3v
F/TC:0 0 _regulator_enable:188 regulator-3p3v refcount: 1
F/TC:0 0 _regulator_enable:188 regulator-vdd refcount: 1
F/TC:0 0 _regulator_enable:150 regulator-vdd-usb
F/TC:0 0 _regulator_enable:188 regulator-vdd-usb refcount: 1
F/TC:0 0 regulator_core_dump:920 Dump Regulators
F/TC:0 0 regulator_core_dump:921 reg      name     use  en      mV      min     max     flags   supply
F/TC:0 0 regulator_core_dump:941 usb33    usb33    0    0       3300    3300    3300    0       regulator-vdd-usb
F/TC:0 0 regulator_core_dump:941 reg18    reg18    0    1       1800    1800    1800    0       regulator-vdd
F/TC:0 0 regulator_core_dump:941 reg11    reg11    0    1       1100    1100    1100    0       regulator-vdd
F/TC:0 0 regulator_core_dump:941 vddcore  regulato 1    1       1200    1200    1350    0x1
F/TC:0 0 regulator_core_dump:941 v3v3     regulato 1    1       3300    3300    3300    0x1
F/TC:0 0 regulator_core_dump:941 vdd      regulato 1    1       3300    3300    3300    0x1
F/TC:0 0 regulator_core_dump:941 vdd_usb  regulato 1    1       3300    3300    3300    0x1
D/TC:0 0 call_initcalls:40 level 7 stm32_rng_release()
D/TC:0 0 call_initcalls:40 level 7 regulator_core_cleanup()
F/TC:0 0 regulator_core_cleanup:1008
D/TC:0 0 regulator_core_cleanup:1012 disable usb33
D/TC:0 0 regulator_core_cleanup:1012 disable reg18
D/TC:0 0 regulator_core_cleanup:1012 disable reg11
D/TC:0 0 call_initcalls:40 level 7 release_probe_lists()
I/TC: init_tee_runtime over
D/TC:0 0 call_finalcalls:59 level 1 release_external_dt()
I/TC: Primary CPU switching to normal world boot
D/TC:0   tee_entry_exchange_capabilities:101 Asynchronous notifications are disabled
D/TC:0   tee_entry_exchange_capabilities:110 Dynamic shared memory is enabled
D/TC:0 0 core_mmu_xlat_table_alloc:526 xlat tables used 4 / 10
D/TC:? 0 tee_ta_init_pseudo_ta_session:296 Lookup pseudo TA 7011a688-ddde-4053-a5a9-7b3c4ddf13b8
D/TC:? 0 tee_ta_init_pseudo_ta_session:309 Open device.pta
D/TC:? 0 tee_ta_init_pseudo_ta_session:326 device.pta : 7011a688-ddde-4053-a5a9-7b3c4ddf13b8
F/TC:? 0 plat_prng_add_jitter_entropy:72 0xAB02
NOTICE:  get_otp_index part_number_otp:1
NOTICE:  get_otp_index package_otp:16
NOTICE:  CPU: STM32MP157DAA Rev.Z
INFO:    Reset reason (0x54):
INFO:      System reset generated by MPU (MPSYSRST)
INFO:    Using USB
INFO:      Instance 2
更多回帖
