运行 m kernel_menuconfig
勾选下列驱动
Device Drivers --->
<*> Multimedia support --->
[*] V4L platform devices --->
<*> Video Multiplexer
[*] SUNXI platform devices --->
<*> sunxi video input (camera csi/mipi isp vipp)driver
<M> v4l2 new driver for SUNXI
<*> use cci function
select cci or cci to twi (chenge cci to twi) --->
[*] use IOMMU for memery alloc
[*] ISP WDR module
[*] sensor same i2c addr
sensor driver select --->
<M> use ov5640 driver
[*] Memory-to-memory multimedia devices --->
<*> Deinterlace support
<*> SuperH VEU mem2mem video processing driver
路径:lichee/linux-5.4/arch/riscv/boot/dts/sunxi/sun20iw1p1.dtsi
vind0: vind@5800800 {
compatible = "allwinner,sunxi-vin-media", "simple-bus";
#address-cells = <2>;
#size-cells = <2>;
ranges;
device_id = <0>;
csi_top = <336000000>;
csi_isp = <327000000>;
reg = <0x0 0x05800800 0x0 0x200>,
<0x0 0x05800000 0x0 0x800>;
clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
clock-names = "csi_top", "csi_top_src",
"csi_mclk0", "csi_mclk0_24m", "csi_mclk0_pll",
"csi_bus", "csi_mbus";
resets = <&ccu RST_BUS_CSI>;
reset-names = "csi_ret";
pinctrl-names = "mclk0-default", "mclk0-sleep";
pinctrl-0 = <&csi_mclk0_pins_a>;
pinctrl-1 = <&csi_mclk0_pins_b>;
status = "okay";
csi0: csi@5801000{
compatible = "allwinner,sunxi-csi";
reg = <0x0 0x05801000 0x0 0x1000>;
interrupts-extended = <&plic0 116 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default","sleep";
pinctrl-0 = <&csi0_pins_a>;
pinctrl-1 = <&csi0_pins_b>;
device_id = <0>;
iommus = <&mmu_aw 1 1>;
status = "okay";
isp0: isp@5809410 {
compatible = "allwinner,sunxi-isp";
reg = <0x0 0x05809410 0x0 0x10>;
device_id = <0xfe>;
status = "okay";
isp1: isp@5809420 {
reg = <0x0 0x05809420 0x0 0x10>;
device_id = <0xff>;
status = "okay";
scaler0: scaler@5809430 {
compatible = "allwinner,sunxi-scaler";
reg = <0x0 0x05809430 0x0 0x10>;
device_id = <0xfe>;
status = "okay";
scaler1: scaler@5809440 {
reg = <0x0 0x05809440 0x0 0x10>;
device_id = <0xff>;
status = "okay";
actuator0: actuator@5809450 {
compatible = "allwinner,sunxi-actuator";
device_type = "actuator0";
reg = <0x0 0x05809450 0x0 0x10>;
actuator0_name = "ad5820_act";
actuator0_slave = <0x18>;
actuator0_af_pwdn = <>;
actuator0_afvdd = "afvcc-csi";
actuator0_afvdd_vol = <2800000>;
status = "okay";
flash0: flash@5809460 {
device_type = "flash0";
compatible = "allwinner,sunxi-flash";
reg = <0x0 0x05809460 0x0 0x10>;
flash0_type = <2>;
flash0_en = <>;
flash0_mode = <>;
flash0_flvdd = "";
flash0_flvdd_vol = <>;
device_id = <0>;
status = "okay";
sensor0: sensor@5809470 {
reg = <0x0 0x05809470 0x0 0x10>;
device_type = "sensor0";
compatible = "allwinner,sunxi-sensor";
sensor0_mname = "ov5640";
sensor0_twi_cci_id = <2>;
sensor0_twi_addr = <0x78>;
sensor0_mclk_id = <0>;
sensor0_pos = "rear";
sensor0_isp_used = <0>;
sensor0_fmt = <0>;
sensor0_stby_mode = <0>;
sensor0_vflip = <0>;
sensor0_hflip = <0>;
sensor0_iovdd-supply = <>;
sensor0_iovdd_vol = <>;
sensor0_avdd-supply = <>;
sensor0_avdd_vol = <>;
sensor0_dvdd-supply = <>;
sensor0_dvdd_vol = <>;
sensor0_power_en = <>;
sensor0_reset = <&pio PE 14 GPIO_ACTIVE_LOW>;
sensor0_pwdn = <&pio PE 15 GPIO_ACTIVE_LOW>;
sensor0_sm_vs = <>;
flash_handle = <&flash0>;
act_handle = <&actuator0>;
device_id = <0>;
status = "okay";
sensor1: sensor@5809480 {
reg = <0x0 0x05809480 0x0 0x10>;
device_type = "sensor1";
sensor1_mname = "ov5647";
sensor1_twi_cci_id = <3>;
sensor1_twi_addr = <0x6c>;
sensor1_mclk_id = <1>;
sensor1_pos = "front";
sensor1_isp_used = <0>;
sensor1_fmt = <0>;
sensor1_stby_mode = <0>;
sensor1_vflip = <0>;
sensor1_hflip = <0>;
sensor1_iovdd-supply = <>;
sensor1_iovdd_vol = <>;
sensor1_avdd-supply = <>;
sensor1_avdd_vol = <>;
sensor1_dvdd-supply = <>;
sensor1_dvdd_vol = <>;
sensor1_power_en = <>;
sensor1_reset = <&pio PE 7 GPIO_ACTIVE_LOW>;
sensor1_pwdn = <&pio PE 6 GPIO_ACTIVE_LOW>;
sensor1_sm_vs = <>;
flash_handle = <>;
act_handle = <>;
device_id = <1>;
status = "disabled";
vinc0: vinc@5809000 {
compatible = "allwinner,sunxi-vin-core";
device_type = "vinc0";
reg = <0x0 0x05809000 0x0 0x200>;
interrupts-extended = <&plic0 111 IRQ_TYPE_LEVEL_HIGH>;
vinc0_csi_sel = <0>;
vinc0_mipi_sel = <0xff>;
vinc0_isp_sel = <0>;
vinc0_tdm_rx_sel = <0xff>;
vinc0_rear_sensor_sel = <0>;
vinc0_front_sensor_sel = <0>;
vinc0_sensor_list = <0>;
device_id = <0>;
status = "okay";
vinc1: vinc@5809200 {
device_type = "vinc1";
reg = <0x0 0x05809200 0x0 0x200>;
interrupts-extended = <&plic0 112 IRQ_TYPE_LEVEL_HIGH>;
vinc1_csi_sel = <0>;
vinc1_mipi_sel = <0xff>;
vinc1_isp_sel = <1>;
vinc1_tdm_rx_sel = <0xff>;
vinc1_rear_sensor_sel = <0>;
vinc1_front_sensor_sel = <0>;
vinc1_sensor_list = <0>;
device_id = <1>;
运行 m menuconfig
,勾选 <*> kmod-sunxi-vin......................................... sunxi-vin support
驱动版本不匹配所致,目前SDK分支过多驱动版本过多,用下列驱动替换即可:
sunxi-vin.tar.gz
解压,覆盖到 tina-d1-h/lichee/linux-5.4/drivers/media/platform/sunxi-vin
文件夹
原贴链接:https://bbs.aw-ol.com/topic/4017/
资源获取、问题讨论可以到全志在线开发者社区进行:https://www.aw-ol.com
全志及开发者最新动态可以关注全志在线微信公众号
更多回帖
