N9H30F61IEC+GM7150硬件已经做好, 软件始终没调通采用CCIR656格式,始终没接收到任何数据,iic
通信正常,示波器测试 plck dat 均正常输出 ,大神们望指点下, 代码如下
pCAP->EnableInt(eCAP_VINTF);
//Frame End interrupt
pCAP->InstallCallback(eCAP_VINTF, (PFN_CAP_CALLBACK)CAP_InterruptHandler,&pfnOldCallback);
//Configure packet frame buffer to use CAP_PKTBA0 register.
pCAP->SetPacketFrameBufferControl(0);
//Set data format and order
pCAP->SetDataFormatAndOrder(eCAP_IN_VYUY,eCAP_IN_YUV422,eCAP_OUT_RGB565);
//Set cropping window start address
pCAP->SetCropWinStartAddr(0,0);
//standard CCIR656 mode
pCAP->SetStandardCCIR656(TRUE);
//Set sensor polarity
pCAP->SetSensorPolarity(FALSE,FALSE,TRUE);
//Set Cropping window size
pCAP->SetCropWinSize(OPT_PACKET_HEIGHT,OPT_PACKET_WIDTH);
//Set Packet/ Planar Stride.
pCAP->SetStride(OPT_PACKET_STRIDE, OPT_PLANAR_STRIDE);
//Packet buffer address.
pCAP->SetBaseStartAddress(eCAP_PACKET,(E_CAP_BUFFER)0,(UINT32)pu8PlanarFrameBuffer);
//Planar buffer Y addrress
pCAP->SetBaseStartAddress(eCAP_PLANAR,(E_CAP_BUFFER)0,(UINT32)u8PlanarFrameBuffer);
//Planar buffer U addrress
pCAP->SetBaseStartAddress(eCAP_PLANAR,(E_CAP_BUFFER)1,(UINT32)u8PlanarFrameBuffer+OPT_PLANAR_WIDTH*OPT_PLANAR_HEIGHT);
//Planar buffer V addrress
pCAP->SetBaseStartAddress(eCAP_PLANAR,(E_CAP_BUFFER)2,(UINT32)u8PlanarFrameBuffer+OPT_PLANAR_WIDTH*OPT_PLANAR_HEIGHT+OPT_PLANAR_WIDTH*OPT_PLANAR_HEIGHT/2);
//Planar YUV422/420/macro
pCAP->SetPlanarFormat(eCAP_PLANAR_YUV422);
//Enable Packet/Planar pipe
pCAP->SetPipeEnable(TRUE,eCAP_BOTH_PIPE_ENABLE);
sysSetLocalInterrupt(ENABLE_IRQ);
