单片机学习小组
直播中
云达贞
8年用户 957经验值
私信 关注
N76E616 Watch_Dog例程WDT没复位的原因?
void main (void)
    /* Note
       MCU power on system clock is HIRC (11.0592MHz), so Fsys = 11.0592MHz
    Set_All_GPIO_Quasi_Mode();                   //in Common.c
    #if DEBUG_PORT == 0
        InitialUART0_Timer1_Type1(115200);            /* 9600 Baud Rate*/
    #elif DEBUG_PORT == 1
        InitialUART1_Timer3(115200);                  /* 9600 Baud Rate*/
    #endif
    Show_FW_Version_Number_To_PC();
    printf ("\n*===================================================================");
    printf ("\n*  Name: N76E616 Watch Dog Timer Demo Code.");
    printf ("\n*===================================================================\n");
    /* Change system closk source */
    #if SYS_CLK_EN == 1
        #if   SYS_SEL == 0
            System_Clock_Select(E_HXTEN);   //Fosc = 2~16MHz XTAL
        #elif SYS_SEL == 1
            System_Clock_Select(E_LXTEN);   //Fosc = 32.768KHz XTAL
        #elif SYS_SEL == 2
            System_Clock_Select(E_HIRCEN);  //Fosc = 11.0592MHz Internal RC
        #elif SYS_SEL == 3
            System_Clock_Select(E_LIRCEN);  //Fosc = 10KHz Internal RC
        #elif SYS_SEL == 4
            System_Clock_Select(E_OSCEN);   //Fosc = OSC-In External OSC
        #endif
    #endif
    #if SYS_DIV_EN == 1
        CKDIV = SYS_DIV;                        //Fsys = Fosc / (2* CLKDIV) = Fcpu
    #endif
        TA = 0x0AA;
        TA = 0x055;
    #if   PRE_SCALAR == 0
        WDCON = 0x00;
    #elif PRE_SCALAR == 1
        WDCON = 0x01;
    #elif PRE_SCALAR == 2
        WDCON = 0x02;
    #elif PRE_SCALAR == 3
        WDCON = 0x03;
    #elif PRE_SCALAR == 4
        WDCON = 0x04;
    #elif PRE_SCALAR == 5
        WDCON = 0x05;
    #elif PRE_SCALAR == 6
        WDCON = 0x06;
    #elif PRE_SCALAR == 7
        WDCON = 0x07;
    #endif
    set_WDTEN;                                  //WDT run
    while(1);
更多回帖
