嵌入式学习小组
直播中
王斌
7年用户 1323经验值
私信 关注
空函数无法通过指针切换回来的原因?
#include
#include "NuMicro.h"
void SYS_Init(void)
    /* Set PF multi-function pins for XT1_OUT(PF.2) and XT1_IN(PF.3) */
    SYS->GPF_MFPL = (SYS->GPF_MFPL & (~SYS_GPF_MFPL_PF2MFP_Msk)) | SYS_GPF_MFPL_PF2MFP_XT1_OUT;
    SYS->GPF_MFPL = (SYS->GPF_MFPL & (~SYS_GPF_MFPL_PF3MFP_Msk)) | SYS_GPF_MFPL_PF3MFP_XT1_IN;
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Enable PLL */
    CLK->PLLCTL = CLK_PLLCTL_128MHz_HIRC;
    /* Waiting for PLL stable */
    CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
    /* Select HCLK clock source as PLL and HCLK source divider as 2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HIRC and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & (~(UART0_RXD_PB12_Msk | UART0_TXD_PB13_Msk))) | UART0_RXD_PB12 | UART0_TXD_PB13;
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
void blink1(void)
                static int i=0;
          i++;
        CLK_SysTickDelay(1000000);
        printf("%d\n",i);
void blink2(void)
                CLK_SysTickDelay(500000);
                GPIO_TOGGLE(PB10);
void blink3(void)
                CLK_SysTickDelay(100000);
                GPIO_TOGGLE(PB10);
/*  Main Function        */
int32_t main(void)
                void (*blink)(void);
                blink=blink1;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
    printf("+-------------------------------------------------+\n");
    printf("|    PB.10(Output) and PG.4(Input) Sample Code     |\n");
    printf("+-------------------------------------------------+\n\n");
    /* GPIO Basic Mode Test --- Use Pin Data Input/Output to control GPIO pin                              */
    printf("  >> LED at PB.10 ; Button1 at PG.4 \n");
    /* Configure PB.10 as Output mode and PG.4 as Input mode then close it */
    GPIO_SetMode(PB, BIT10, GPIO_MODE_OUTPUT);
    GPIO_SetMode(PG, BIT4,  GPIO_MODE_INPUT);
    PB10 = 1;
    printf("GPIO PB.10(output mode) and PD.7(input mode) ......");
        while(1)
                blink();
                if(PG4==0)
                                CLK_SysTickDelay(50);
                                while(PG4==0){}
                                                if (blink==blink1) blink=blink2;
                                                else if(blink==blink2) blink=blink3;
                                                else if(blink==blink3) blink=blink1;
初始化的时候我让blink指向了blink1,但是如果我删除blink1中的内容,那么按键操作后发现无法切换回什么都不做的blink1,如果我给blink1填充一些内容,比如上面代码中打印一些编号。
回帖(1)
时见栖鸦
2024-1-2 16:28:23
空函数无法通过指针切换回来的原因是因为空函数不具有任何实际的操作,只是一个空的函数定义,无法在函数内部做出任何的修改操作。因此,在执行指针切换时,无法通过空函数来改变指针所指向的函数,从而导致失败。
举报
更多回帖
