@file main.c
@version V3.00
* $Revision: 2 $
* $Date: 16/10/25 4:30p $
@brief Show how to use
timer0 to create various delay time.
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include
#include "NUC029xGE.h"
#define PLL_CLOCK 72000000
void SYS_Init(void)
/* Init System Clock */
/* Enable HIRC clock */
CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
/* Waiting for HIRC clock ready */
CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
/* Switch HCLK clock source to HIRC */
CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
/* Enable HXT */
CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
/* Waiting for clock ready */
CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
/* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
CLK_SetCoreClock(PLL_CLOCK);
CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
/* Enable peripheral clock */
CLK_EnableModuleClock(UART0_MODULE);
CLK_EnableModuleClock(TMR0_MODULE);
CLK_EnableModuleClock(TMR1_MODULE);
/* Peripheral clock source */
CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_PLL, CLK_CLKDIV0_UART(1));
CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_PCLK0, 0);
CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HXT, 0);
/* Init I/O Multi-function */
/* Set multi-function pins for UART0 RXD and TXD */
SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
void UART0_Init(void)
/* Init UART */
/* Reset UART module */
SYS_ResetModule(UART0_RST);
/* Configure UART0 and set UART0 Baudrate */
UART_Open(UART0, 115200);
/* MAIN function */
int main(void)
volatile uint32_t u32DelayTime;
/* Unlock protected registers */
SYS_UnlockReg();
/* Init System, peripheral clock and multi-function I/O */
SYS_Init();
/* Lock protected registers */
SYS_LockReg();
/* Init UART0 for printf */
UART0_Init();
printf("\n\nCPU
@ %d Hz\n", SystemCoreClock);
printf("+-----------------------------------+\n");
printf("| Timer Delay API Sample Code |\n");
printf("+-----------------------------------+\n\n");
printf("# This sample code is using Timer1 to check Timer0 TIMER_Delay API delay time is reasonable or not.\n");
printf("# Delay time includes 100 ms, 200 ms, 300 ms, 400 ms and 500 ms.\n\n");
/* Start Timer1 to measure delay period of TIMER_Delay API is reasonable or not */
TIMER1->CTL = TIMER_PERIODIC_MODE | (12 - 1);
TIMER_ResetCounter(TIMER1);
TIMER_Start(TIMER1);
TIMER_Delay(TIMER0, 100000);
u32DelayTime = TIMER_GetCounter(TIMER1) / 1000;
printf(" Check DelayTime-1 is %d ms .... ", u32DelayTime);
if(u32DelayTime == 100)
printf("PASS.\n");
else
printf("FAIL.\n");
TIMER_Delay(TIMER0, 200000);
printf(" Check DelayTime-2 is %d ms .... ", u32DelayTime);
if(u32DelayTime == 200)
printf("PASS.\n");
else
printf("FAIL.\n");
TIMER_Delay(TIMER0, 300000);
printf(" Check DelayTime-3 is %d ms .... ", u32DelayTime);
if(u32DelayTime == 300)
printf("PASS.\n");
else
printf("FAIL.\n");
TIMER_Delay(TIMER0, 400000);
printf(" Check DelayTime-4 is %d ms .... ", u32DelayTime);
if(u32DelayTime == 400)
printf("PASS.\n");
else
printf("FAIL.\n");
TIMER_Delay(TIMER0, 500000);
printf(" Check DelayTime-5 is %d ms .... ", u32DelayTime);
if(u32DelayTime == 500)
printf("PASS.\n");
else
printf("FAIL.\n");
printf("\n*** Check TIMER_Delay API delay time done ***\n");
while(1);
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
