我正在努力将 SJA1105Q 以太网交换机添加到 Renesas SOC。将 sja1105.ko 文件加载到内核后,观察到内核崩溃。步骤和内核崩溃日志如下所示。
- 先添加依赖模块。
- dsa_core.ko
- ptp.ko
- tag_8021q.ko
- 加载 sja1105q.ko 模块并检查 dmesg 日志是否有错误。
- 观察到内核崩溃
[ 1.585783] systemd-modules-load[207]: Inserted module 'phylink'
[ 1.590334] systemd-modules-load[207]: Inserted module 'dsa_core'
[ 1.592509] PTP clock support registered
[ 1.592587] systemd-modules-load[207]: Inserted module 'ptp'
[ 1.594032] systemd-modules-load[207]: Inserted module 'tag_8021q'
[ 1.595539] systemd-modules-load[207]: Inserted module 'tag_sja1105'
[ 1.599692] sja1105 spi3.1: calling sja1105_probe...
[ 1.621283] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000028
[ 1.630106] Mem abort info:
[ 1.632900] ESR = 0x96000005
[ 1.636001] EC = 0x25: DABT (current EL), IL = 32 bits
[ 1.641328] SET = 0, FnV = 0
[ 1.644381] EA = 0, S1PTW = 0
[ 1.647530] Data abort info:
[ 1.650417] ISV = 0, ISS = 0x00000005
[ 1.654262] CM = 0, WnR = 0
[ 1.657231] user pgtable: 4k pages, 39-bit VAs, pgdp=00000004d69f4000
[ 1.663702] [0000000000000028] pgd=0000000000000000, pud=0000000000000000
[ 1.670515] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 1.676095] Modules linked in: sja1105(+) tag_sja1105 tag_8021q ptp dsa_core phylink cp210x pl2303 ftdi_sio usbserial can_isotp(O) mcp25xxfd sd_mod usb_f_ncm u_ether libcomposite renesas_usbhs udc_core extcon_core xhci_plat_hcd xhci_hcd cdc_ncm hid_generic usbhid usb_storage scsi_mod asix ax88179_178a usbnet mii ehset spidev configfs
[ 1.705731] CPU: 1 PID: 207 Comm: systemd-modules Tainted: G O 5.4.26-work #2
[ 1.714179] Hardware name: PCC VBOX (ZR3-Based) board (DT)
[ 1.719671] pstate: 40000005 (nZcv daif -PAN -UAO)
[ 1.724483] pc : sja1105_probe+0x130/0x2b8 [sja1105]
[ 1.729456] lr : sja1105_probe+0x120/0x2b8 [sja1105]
[ 1.734424] sp : ffffffc010c1b900
[ 1.737738] x29: ffffffc010c1b900 x28: 0000000000000001
[ 1.743056] x27: ffffff849565bec8 x26: 0000000000000001
[ 1.748373] x25: ffffffc008845110 x24: 0000000000000010
[ 1.753691] x23: 0000000000000000 x22: ffffffc010928000
[ 1.759007] x21: 0000000000000000 x20: ffffff8497de7800
[ 1.764324] x19: ffffff8495659080 x18: 000000000000000a
[ 1.769641] x17: 0000000000000000 x16: 0000000000000000
[ 1.774958] x15: ffffffc48f087000 x14: 00000000000002e7
[ 1.780274] x13: 0000000000000231 x12: 0000000000000038
[ 1.785591] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 1.790908] x9 : 03fefeff01fefeff x8 : 7f7f7f7f7f7f7f7f
[ 1.796226] x7 : ff342f3030606972 x6 : 0000000000000080
[ 1.801542] x5 : 8000000000000000 x4 : 0000000000000004
[ 1.806859] x3 : ffffffc010c1b940 x2 : 0035303131616a73
[ 1.812176] x1 : ffffff84960c0fc0 x0 : 0000000000000000
[ 1.817493] Call trace:
[ 1.819945] sja1105_probe+0x130/0x2b8 [sja1105]
[ 1.824576] spi_drv_probe+0x88/0xb0
[ 1.828156] really_probe+0x1e8/0x2ec
[ 1.831821] driver_probe_device+0xd8/0xe8
[ 1.835920] device_driver_attach+0x48/0x70
[ 1.840106] __driver_attach+0xc4/0xc8
[ 1.843858] bus_for_each_dev+0x8c/0xd4
[ 1.847696] driver_attach+0x30/0x3c
[ 1.851273] bus_add_driver+0x17c/0x1c0
[ 1.855112] driver_register+0xb0/0xe8
[ 1.858862] __spi_register_driver+0x6c/0x78
[ 1.863142] sja1105_driver_init+0x28/0x1000 [sja1105]
[ 1.868290] do_one_initcall+0xc4/0x21c
[ 1.872130] do_init_module+0x60/0x1f8
[ 1.875880] load_module+0x1dd8/0x1e84
[ 1.879630] __do_sys_finit_module+0xa4/0xc0
[ 1.883902] __arm64_sys_finit_module+0x28/0x34
[ 1.888438] el0_svc_common.constprop.2+0xec/0x158
[ 1.893233] el0_svc_handler+0x58/0x88
[ 1.896984] el0_svc+0x8/0xc
[ 1.899869] Code: f900b660 d2800084 b90057bf 910103a3 (f9401418)
[ 1.905971] ---[ end trace ff0846ac68861238 ]---
设备连接和 DTS 详细信息如下所示。
设备连接:
设备树配置:
/* SPI_ETH */
&msiof3 {
pinctrl-0 = <&msiof3_pins>;
pinctrl-names = "default";
status = "okay";
cs-gpios = <0>, <&gpio1 5 GPIO_AC
tiVE_LOW>;
num-cs = <2>;
/*renesas,dtdl = <50>;*/
/*renesas,syncdl = <50>;*/
/* SPI3 CS2-SJA1105 mode 1 */
sja1105@1 {
/*compatible = "renesas,sh-msiof";*/
compatible = "nxp,sja1105t";
reg = <1>;
spi-max-frequency = <4000000>;
spi-cpha;
/*spi-cpol;*/
renesas,dtdl = <200>;
renesas,syncdl = <300>;
reset-gpios = <&gpio4 7 GPIO_ACTIVE_LOW>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
/* Internal port connected to ethernet port of m3 */
ethernet = <&avb>;
phy-handle = <&phy0>;
phy-mode = "rgmii";
reg = <0>;
sja1105,role-phy;
fixed-link {
speed = <1000>;
full-duplex;
port@1 {
/* ETH3 (goes to backplane) */
label = "swp1";
phy-handle = <&mii_eth_phy3>;
phy-mode = "mii";
reg = <1>;
/* Implicit "sja1105,role-mac;" */
port@2 {
/* brr phy 1 (goes to backplane) */
label = "swp2";
phy-handle = <&mii_brr_phy1>;
phy-mode = "mii";
reg = <2>;
port@3 {
/* brr phy 2 (goes to backplane) */
phy-handle = <&mii_brr_phy2>;
label = "swp3";
phy-mode = "mii";
reg = <3>;
port@4 {
/* brr phy 3 (goes to backplane) */
label = "swp4";
phy-handle = <&mii_brr_phy3>;
phy-mode = "mii";
reg = <0>;
&avb {
pinctrl-0 = <&avb_pins>;
renesas,no-ether-link;
status = "okay";
phy-mode = "rgmii-id";
phy0: dummy_phy {
compatible = "ethernet-phy-idFFFF.FFFE";
reg = <8>;
fixed-link {
speed = <1000>;
full-duplex;
mii_eth_phy3: ksz9031@0 {
compatible = "microchip,ksz9031";
reg = <0>;
interrupt-parent = <&gpio4>;
interrupts = <17 IRQ_TYPE_LEVEL_LOW>;
mii_brr_phy1: mv88q2112@1 {
compatible = "marvell,mv88q2112";
reg = <1>;
interrupt-parent = <&gpio2>;
interrupts = <10 IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&gpio4 13 GPIO_ACTIVE_LOW>;
mii_brr_phy2: mv88q2112@2 {
reg = <2>;
interrupts = <11 IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>;
mii_brr_phy3: mv88q2112@3 {
reg = <3>;
interrupts = <12 IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&gpio4 11 GPIO_ACTIVE_LOW>;
版本细节是。
请检查配置并帮助修复内核崩溃。
