环境:hpm6300evk
SDK: v1.0.0
结论:
步骤一:根据DS手册,调高核心电压至 1.2v
void board_init( void )
pcfg_dcdc_set_voltage(HPM_PCFG, 1100);
改为
pcfg_dcdc_set_voltage(HPM_PCFG, 1200);
步骤二:调整CPU时钟源和AXI、AHB分频系数
void board_init_clock( void )
clock_set_source_divider(clock_cpu0, clk_src_pll1_clk0, 1);
/* Configure PLL1_CLK0 Post Divider to 1.2 */
pllctlv2_set_postdiv(HPM_PLLCTLV2, 1, 0, 1);
/* Configure PLL1 clock frequencey to 576MHz, the PLL1_CLK0 frequency =- 576MHz / 1.2 = 480MHz */
pllctlv2_init_pll_with_freq(HPM_PLLCTLV2, 1, 576000000);
改为
#if 0
#else
#define BUS_FREQ_MAX (166000000UL)
#define CORE0_FREQ_HZ (816000000UL)
pllctlv2_set_postdiv(HPM_PLLCTLV2, 1, 0, 0);
uint32_t expected_freq = CORE0_FREQ_HZ;
uint32_t axi_sub_div = (expected_freq + BUS_FREQ_MAX - 1U) / BUS_FREQ_MAX;
uint32_t ahb_sub_div = (expected_freq + BUS_FREQ_MAX - 1U) / BUS_FREQ_MAX;
sysctl_config_cpu0_domain_clock(HPM_SYSCTL, clk_src_pll1_clk0, 1, axi_sub_div, ahb_sub_div);
pllctlv2_init_pll_with_freq(HPM_PLLCTLV2, 1, CORE0_FREQ_HZ);
#undef BUS_FREQ_MAX
#undef CORE0_FREQ_HZ
#endif
注意点,AXI和AHB主频不超166MHz,详见DS手册(下图)
超频变砖解决办法:
更多回帖
