NXP MCU 技术论坛
直播中
陈勇
8年用户 1341经验值
私信 关注
[问答]
IMX8QM-MEK尝试cmake我的程序报错的原因?
硬件:IMX8QM-MEK
视觉:LF5.10.72_2.2.0
我正在尝试 cmake 我的程序,但出现错误。
$. /opt/fsl-imx-xwayland/5.10-hardknott/environment-setup-cortexa72-cortexa53-crypto-poky-linux
$ cmake ../tensorflow/lite/examples/yolov5/
终端显示“Unrecognized XNNPACK_TARGET_PROCESSOR = cortexa72-cortexa53-crypto”,不过应该是可以识别的吧?
终端:
soc123@jimdeway:~/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build$ cmake ../tensorflow/lite/examples/yolov5/
-- Toolchain file defaulted to \'/opt/fsl-imx-xwayland/5.10-hardknott/sysroots/x86_64-pokysdk-linux/usr/share/cmake/OEToolchainConfig.cmake\'
-- The C compiler identification is GNU 10.2.0
-- The CXX compiler identification is GNU 10.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /opt/fsl-imx-xwayland/5.10-hardknott/sysroots/x86_64-pokysdk-linux/usr/bin/aarch64-poky-linux/aarch64-poky-linux-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /opt/fsl-imx-xwayland/5.10-hardknott/sysroots/x86_64-pokysdk-linux/usr/bin/aarch64-poky-linux/aarch64-poky-linux-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Setting build type to Release, for debug builds use\'-DCMAKE_BUILD_TYPE=Debug\'.
CMake Warning at /home/soc123/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build/abseil-cpp/absl/copts/AbseilConfigureCopts.cmake:30 (message):
  Value of CMAKE_SYSTEM_PROCESSOR (cortexa72-cortexa53-crypto) is unknown and
  cannot be used to set ABSL_RANDOM_RANDEN_COPTS
Call Stack (most recent call first):
  /home/soc123/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build/abseil-cpp/CMake/AbseilHelpers.cmake:18 (include)
  /home/soc123/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build/abseil-cpp/CMakeLists.txt:73 (include)
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Performing Test EIGEN_COMPILER_SUPPORT_CPP11
-- Performing Test EIGEN_COMPILER_SUPPORT_CPP11 - Success
-- Performing Test COMPILER_SUPPORT_std=cpp03
-- Performing Test COMPILER_SUPPORT_std=cpp03 - Success
-- Performing Test standard_math_library_linked_to_automatically
-- Performing Test standard_math_library_linked_to_automatically - Success
-- Standard libraries to link to explicitly: none
-- Performing Test COMPILER_SUPPORT_WERROR
-- Performing Test COMPILER_SUPPORT_WERROR - Success
-- Performing Test COMPILER_SUPPORT_pedantic
-- Performing Test COMPILER_SUPPORT_pedantic - Success
-- Performing Test COMPILER_SUPPORT_Wall
-- Performing Test COMPILER_SUPPORT_Wall - Success
-- Performing Test COMPILER_SUPPORT_Wextra
-- Performing Test COMPILER_SUPPORT_Wextra - Success
-- Performing Test COMPILER_SUPPORT_Wundef
-- Performing Test COMPILER_SUPPORT_Wundef - Success
-- Performing Test COMPILER_SUPPORT_Wcastalign
-- Performing Test COMPILER_SUPPORT_Wcastalign - Success
-- Performing Test COMPILER_SUPPORT_Wcharsubscripts
-- Performing Test COMPILER_SUPPORT_Wcharsubscripts - Success
-- Performing Test COMPILER_SUPPORT_Wnonvirtualdtor
-- Performing Test COMPILER_SUPPORT_Wnonvirtualdtor - Success
-- Performing Test COMPILER_SUPPORT_Wunusedlocaltypedefs
-- Performing Test COMPILER_SUPPORT_Wunusedlocaltypedefs - Success
-- Performing Test COMPILER_SUPPORT_Wpointerarith
-- Performing Test COMPILER_SUPPORT_Wpointerarith - Success
-- Performing Test COMPILER_SUPPORT_Wwritestrings
-- Performing Test COMPILER_SUPPORT_Wwritestrings - Success
-- Performing Test COMPILER_SUPPORT_Wformatsecurity
-- Performing Test COMPILER_SUPPORT_Wformatsecurity - Success
-- Performing Test COMPILER_SUPPORT_Wshorten64to32
-- Performing Test COMPILER_SUPPORT_Wshorten64to32 - Failed
-- Performing Test COMPILER_SUPPORT_Wlogicalop
-- Performing Test COMPILER_SUPPORT_Wlogicalop - Success
-- Performing Test COMPILER_SUPPORT_Wenumconversion
-- Performing Test COMPILER_SUPPORT_Wenumconversion - Failed
-- Performing Test COMPILER_SUPPORT_Wcpp11extensions
-- Performing Test COMPILER_SUPPORT_Wcpp11extensions - Failed
-- Performing Test COMPILER_SUPPORT_Wdoublepromotion
-- Performing Test COMPILER_SUPPORT_Wdoublepromotion - Success
-- Performing Test COMPILER_SUPPORT_Wshadow
-- Performing Test COMPILER_SUPPORT_Wshadow - Success
-- Performing Test COMPILER_SUPPORT_Wnopsabi
-- Performing Test COMPILER_SUPPORT_Wnopsabi - Success
-- Performing Test COMPILER_SUPPORT_Wnovariadicmacros
-- Performing Test COMPILER_SUPPORT_Wnovariadicmacros - Success
-- Performing Test COMPILER_SUPPORT_Wnolonglong
-- Performing Test COMPILER_SUPPORT_Wnolonglong - Success
-- Performing Test COMPILER_SUPPORT_fnochecknew
-- Performing Test COMPILER_SUPPORT_fnochecknew - Success
-- Performing Test COMPILER_SUPPORT_fnocommon
-- Performing Test COMPILER_SUPPORT_fnocommon - Success
-- Performing Test COMPILER_SUPPORT_fstrictaliasing
-- Performing Test COMPILER_SUPPORT_fstrictaliasing - Success
-- Performing Test COMPILER_SUPPORT_wd981
-- Performing Test COMPILER_SUPPORT_wd981 - Failed
-- Performing Test COMPILER_SUPPORT_wd2304
-- Performing Test COMPILER_SUPPORT_wd2304 - Failed
-- Performing Test COMPILER_SUPPORT_STRICTANSI
-- Performing Test COMPILER_SUPPORT_STRICTANSI - Failed
-- Performing Test COMPILER_SUPPORT_Qunusedarguments
-- Performing Test COMPILER_SUPPORT_Qunusedarguments - Failed
-- Performing Test COMPILER_SUPPORT_ansi
-- Performing Test COMPILER_SUPPORT_ansi - Success
-- Performing Test COMPILER_SUPPORT_OPENMP
-- Performing Test COMPILER_SUPPORT_OPENMP - Success
-- Looking for a Fortran compiler
-- Looking for a Fortran compiler - /usr/bin/f95
-- The Fortran compiler identification is GNU 7.5.0
-- Detecting Fortran compiler ABI info
-- Detecting Fortran compiler ABI info - done
-- Check for working Fortran compiler: /usr/bin/f95 - skipped
-- Checking whether /usr/bin/f95 supports Fortran 90
-- Checking whether /usr/bin/f95 supports Fortran 90 - yes
-- Configured Eigen 3.3.90
-- Available targets (use: make TARGET):
-- Target   |   Description
-- install  | Install Eigen. Headers will be installed to:
--          |   Using the following values:
--          |     CMAKE_INSTALL_PREFIX: /usr/local
--          |     INCLUDE_INSTALL_DIR:  include/eigen3
--          |   Change the install location of Eigen headers using:
--          |     cmake . -DCMAKE_INSTALL_PREFIX=yourprefix
--          |   Or:
--          |     cmake . -DINCLUDE_INSTALL_DIR=yourdir
-- doc      | Generate the API documentation, requires Doxygen & LaTeX
-- blas     | Build BLAS library (not the same thing as Eigen)
-- uninstall| Remove files installed by the install target
-- Performing Test FARMHASH_HAS_BUILTIN_EXPECT
-- Performing Test FARMHASH_HAS_BUILTIN_EXPECT - Success
-- Looking for strtof_l
-- Looking for strtof_l - found
-- Looking for strtoull_l
-- Looking for strtoull_l - found
-- Using toolchain file: /opt/fsl-imx-xwayland/5.10-hardknott/sysroots/x86_64-pokysdk-linux/usr/share/cmake/OEToolchainConfig.cmake.
-- The ASM compiler identification is GNU
-- Found assembler: /opt/fsl-imx-xwayland/5.10-hardknott/sysroots/x86_64-pokysdk-linux/usr/bin/aarch64-poky-linux/aarch64-poky-linux-gcc
CMake Error at /home/soc123/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build/xnnpack/CMakeLists.txt:80 (MESSAGE):
-- Configuring incomplete, errors occurred!
See also \"/home/soc123/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build/CMakeFiles/CMakeOutput.log\".
See also \"/home/soc123/Desktop/tensorflow-imx-lf-5.10.72_2.2.0/build/CMakeFiles/CMakeError.log\".
CMakeLists.txt:
# Copyright 2020 The TensorFlow Authors. All Rights Reserved.
# Licensed under the Apache License, Version 2.0 (the \"License\");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#      https://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an \"AS IS\" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# Builds the minimal Tensorflow Lite example.
cmake_minimum_required(VERSION 3.16)
project(yolov5 C CXX)
set(TENSORFLOW_SOURCE_DIR \"\" CACHE PATH
  \"Directory that contains the TensorFlow project\"
if(NOT TENSORFLOW_SOURCE_DIR)
  get_filename_component(TENSORFLOW_SOURCE_DIR
    \"${CMAKE_CURRENT_LIST_DIR}/../../../../\"
    ABSOLUTE
endif()
add_subdirectory(
  \"${TENSORFLOW_SOURCE_DIR}/tensorflow/lite\"
  \"${CMAKE_CURRENT_BINARY_DIR}/tensorflow-lite\"
  EXCLUDE_FROM_ALL
find_package( OpenCV REQUIRED )
find_package(Threads REQUIRED)
include_directories( ${OpenCV_INCLUDE_DIRS} )
include_directories( include/ncnn2 )
set(CMAKE_CXX_FLAGS \"${CMAKE_CXX_FLAGS} -std=c++14 -fopenmp\")
set(CMAKE_CXX_FLAGS_RELEASE \"-O2 -DNDEBUG\")
set(CMAKE_CXX_FLAGS_DEBUG \"-g\")
set(CMAKE_CXX_STANDARD 14)
if (NOT CMAKE_BUILD_TYPE AND NOT CMAKE_CONFIGURATION_TYPES)
    message(STATUS \"No build type selected, default to Release\")
    set(CMAKE_BUILD_TYPE \"Release\" CACHE STRING \"Build type (default Debug)\" FORCE)
endif()
更多回帖
