NXP MCU 技术论坛
直播中
李秀兰
7年用户 1437经验值
私信 关注
[问答]
SAI5 I2S不工作是为什么?
我正在尝试将数字麦克风连接到我的 i.mx 8m mini evk 上的 SAI5 扩展引脚。这是我的设备树:
codec_dummy: codec_dummy {
                compatible = \"asoc,snd-soc-dummy\";
                #sound-dai-cells = <0>;
                pinctrl-names = \"default\";
                pinctrl-0 = <&pinctrl_gpio_wlf>;
                frame-master;
                bitclock-master;
                status = \"okay\";
sound-sai5 {
                compatible = \"simple-audio-card\";
                simple-audio-card,name=\"sound | sai5\";
                simple-audio-card,format=\"i2s\";
                simple-audio-card,frame-master=<&sai5>;
                simple-audio-card,bitclock-master=<&sai5>;
                status=\"okay\";
                cpu_dai:simple-audio-card,cpu{
                        sound-dai=<&sai5>;
                        system-clock-frequency=<&clk IMX8MM_CLK_SAI5_ROOT>;
                codec_dai: simple-audio-card,codec{
                        sound-dai=<&codec_dummy>;
&sai5 {
        compatible=\"fsl,imx8mm-sai\";
        pinctrl-0 = <&pinctrl_sai5>;
        assigned-clocks=<&clk IMX8MM_CLK_SAI5>;
        assigned-clocks-parents=<&clk IMX8MM_AUDIO_PLL1_OUT>;
        assigned-clock-rates = <4096000>;
        fsl,sai-mclk-direction-output;
        fsl,txmasterflag = <0>;
        fsl,mode=\"i2s-master\";
        status=\"okay\";
当我运行 arecord -l 命令时,我可以看到界面,当我运行 pactrl list 时,在无限循环中打印出以下错误:
fsl-sai 30050000.sai: ASoC: error at snd_soc_dai_hw_params on 30050000.sai: -22
[ 1875.936608]  30050000.sai-snd-soc-dummy-dai: ASoC: soc_pcm_hw_params() failed (-22)
[ 1875.944756] fsl-sai 30050000.sai: failed to derive required Rx rate: 1411200
更多回帖
