乐鑫技术交流
直播中
王婷
8年用户 1079经验值
私信 关注
[问答]
Arduino IDE在mac OS更新后无法编译的原因?怎么处理?
MAC OS 昨晚更新到 macOS 10.15 Beta (19A471t)
今天,Arduino IDE 不会编译草图,即使
再次下载并安装最新的 ARDUINO 1.8.9。
“错误编译板 NodeMCU 1.0(ESP-12E 模块)”
昨天工作。
Arduino:1.8.9 (Mac OS X),开发板:“NodeMCU 1.0(ESP-12E 模块),80 MHz,闪存,禁用,所有 SSL 密码(最兼容),4M (1M SPIFFS),v2 低内存,禁用,无,仅草图,230400\"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/gregbaker/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/gregbaker/Library/Arduino15/packages -内置库/Applications/Arduino.app/Contents/Java/libraries-libraries/Users/gregbaker/Desktop/Arduino/libraries-fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz =4M1M,ip=lm2f,dbg=禁用,lvl=无____,wipe=无,波特=230400 -vid-pid=10C4_EA60 -ide-version=10809 -build-path /var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378 -warnings=none -build-cache /var/folders/jp/j5yxgdcj2k5d qfw8lp3hrfzc0000gp/T/ arduino_cache_554397 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5 .0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106- elf-gcc/2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs=runtime .tools.mkspiffs-2.5.0-3-20ed2b9.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs=runtime.tools.python。path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/python/3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=/Users/gregbaker/Library/Arduino15/ packages/esp8266/tools/python/3.7.2-post1 -verbose /Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/esp8266/examples/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/gregbaker/Library/Arduino15/packages -tools /Applications /Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/gregbaker/Library/Arduino15/packages -built-in-libraries /Applications /Arduino.app/Contents/Java/libraries-libraries/Users/gregbaker/Desktop/Arduino/libraries-fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M ,ip=lm2f,dbg=禁用,lvl=无____,wipe=无,波特=230400 -vid-pid=10C4_EA60 -ide-version=10809 -build-path /var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378 -warnings=none -build-cache /var/folders/jp/j5yxgdcj2k5d qfw8lp3hrfzc0000gp/T/ arduino_cache_554397 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5 .0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106- elf-gcc/2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs=runtime .tools.mkspiffs-2.5.0-3-20ed2b9.path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs=runtime.tools.python。path=/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/python/3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=/Users/gregbaker/Library/Arduino15/ packages/esp8266/tools/python/3.7.2-post1 -verbose /Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/libraries/esp8266/examples/Blink/Blink.ino
使用文件夹中平台的“nodemcuv2”板:/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2
使用文件夹中平台的核心“esp8266”:/Users/gregbaker/Library/Arduino15/packages /esp8266/hardware/esp8266/2.5.2
正在检测使用的库...
/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users /gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/sdk/include -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/sdk /lwip2/include -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5。2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno- rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 - DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 \"-DARDUINO_BOARD=\\\"ESP8266_NODEMCU\\\"\" -DFLASHMODE_DIO -DESP8266 -I/Users/gregbaker/Library/Ar duino15/packages/esp8266/hardware/esp8266/2.5. 2/cores/esp8266-I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/variants/nodemcu/var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/sk蚀刻/Blink.ino。 cpp -o /dev/nullESP8266_NODEMCU\\\"\" -DFLASHMODE_DIO -DESP8266 -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266 -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware /esp8266/2.5.2/variants/nodemcu /var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/sketch/Blink.ino.cpp -o /dev/nullESP8266_NODEMCU\\\"\" -DFLASHMODE_DIO -DESP8266 -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266 -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware /esp8266/2.5.2/variants/nodemcu /var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/sketch/Blink.ino.cpp -o /dev/null
正在生成函数原型...
/Users/gregbaker/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users /gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/sdk/include -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/sdk /lwip2/include -I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5。2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno- rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 - DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 \"-DARDUINO_BOARD=\\\"ESP8266_NODEMCU\\\"\" -DFLASHMODE_DIO -DESP8266 -I/Users/gregbaker/Library/Ar duino15/packages/esp8266/hardware/esp8266/2.5. 2/cores/esp8266-I/Users/gregbaker/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/variants/nodemcu/var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/sk蚀刻/Blink.ino。cpp -o /var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-指令/var/folders/jp/j5yxgdcj2k5dqfw8lp3hrfzc0000gp/T/arduino_build_124378/preproc/ctags_target_for_gcc_minus_e.cpp
fork/exec/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags : 可执行文件中错误的 CPU 类型
板 NodeMCU 1.0(ESP-12E 模块)编译错误。
除了关闭自动更新之外,
还有什么想法和/或建议吗?
更多回帖
