NXP MCU 技术论坛
直播中
山中老虎
9年用户 1014经验值
擅长:制造/封装
私信 关注
[问答]
Windows10 IoT Enterprise iMX8MP驱动程序注入失败的原因?怎么解决?
将驱动程序注入 Windows 映像时,将安装除 galcore 驱动程序之外的所有驱动程序。请参阅下面的日志。请告知如何安装 galcore 驱动程序。现在我试图在没有 galcore 驱动程序的情况下继续构建(通过从 IoTEntOnNXP/drivers 目录中删除 galcore 目录)并重新运行 make-winpe-enterprise.cmd
PS C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP> .\\make-winpe-enterprise.cmd /disable_updates /disable_transparency /test_signing
Selected: \"install.wim\"
OPtiONS SUMMARY:
Source image:                          install.wim
Test signing:                          yes
Windows debug over ethernet:           no, IP:
Windows PE debug over ethernet:        no, IP:
KD_NET file (for debug over net):      no
Windows debug over serial:             no
Windows PE debug over serial:          no
Unattended install answer file:        no
Disable updates:                       yes
Disable transparency:                  yes
Split wim:                             no
Cumulative update:                     no, path:
Skip updates from kbpatch\\:            no
*** Step 1 Creating i.MX Windows IoT Enterprise image: out\\imx_win_iot_install.wim
*** Step 1.1 Copying Windows Enterprise image install.wim to out\\imx_win_iot_install.wim
copy \"install.wim\" \"out\\imx_win_iot_install.wim\"
        1 file(s) copied.
*** Step 1.2 Mounting i.MX Windows IoT Enterprise image at out\\mount_enterprise
dism /mount-wim /wimfile:\"out\\imx_win_iot_install.wim\" /mountdir:\"out\\mount_enterprise\" /index:2
Deployment Image Servicing and Management tool
Version: 10.0.22621.1
Mounting image
[==========================100.0%==========================]
The operation completed successfully.
*** Step 1.3 Injecting drivers from C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers into the i.MX Windows IoT Enterprise image
dism /Image:\"out\\mount_enterprise\" /Add-Driver /Driver:\"C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\" /Recurse /ForceUnsigned
Image Version: 10.0.19044.1288
Searching for driver packages to install...
Found 36 driver package(s) to install.
Installing 1 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\ALS\\imxals.inf: The driver package was successfully installed.
Installing 2 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Audio\\imxaud.inf: The driver package was successfully installed.
Installing 3 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Audio\\imxaudsc.inf: The driver package was successfully installed.
Installing 4 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\CAN_MC\\imxcan_mc.inf: The driver package was successfully installed.
Installing 5 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\CAN_NMC\\imxcan_nmc.inf: The driver package was successfully installed.
Installing 6 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\ECOMPASS\\imxecompass.inf: The driver package was successfully installed.
Installing 7 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Galcore\\galcore.inf: Error - An error occurred. The driver package could not be installed.
For more information, check for log files in the \\inf folder of the target image.
Installing 8 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\GPIO\\imxgpio.inf: The driver package was successfully installed.
Installing 9 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\GPIO_8X\\imxgpio_8x.inf: The driver package was successfully installed.
Installing 10 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Gyro\\imxgyro_fxas21002.inf: The driver package was successfully installed.
Installing 11 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\HalExtDma\\HalExtiMXDma.inf: The driver package was successfully installed.
Installing 12 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\I2C\\imxi2c.inf: The driver package was successfully installed.
Installing 13 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\IMU\\imximu.inf: The driver package was successfully installed.
Installing 14 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\ImxCamera\\imxcamera_package.inf: The driver package was successfully installed.
Installing 15 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\LPI2C\\imxlpi2c.inf: The driver package was successfully installed.
Installing 16 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\LPUART\\imxlpuart.inf: The driver package was successfully installed.
Installing 17 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Net\\imxnetmini.inf: The driver package was successfully installed.
Installing 18 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Net\\imxqosmini.inf: The driver package was successfully installed.
Installing 19 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\OPTEE\\OpteeTrEE.inf: The driver package was successfully installed.
Installing 20 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\PEP\\imxpep.inf: The driver package was successfully installed.
Installing 21 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\PWM\\imxpwm.inf: The driver package was successfully installed.
Installing 22 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\PWM_TPM\\imxpwm_tpm.inf: The driver package was successfully installed.
Installing 23 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\RGPIO\\imxrgpio.inf: The driver package was successfully installed.
Installing 24 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\SCFW\\imxscfw.inf: The driver package was successfully installed.
Installing 25 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\SPI\\imxecspi.inf: The driver package was successfully installed.
Installing 26 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\SPI\\imxlpspi.inf: The driver package was successfully installed.
Installing 27 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\ThermalClient\\imxthermalclient.inf: The driver package was successfully installed.
Installing 28 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\ThermalSensor\\imxtmu.inf: The driver package was successfully installed.
Installing 29 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\UART\\imxuart.inf: The driver package was successfully installed.
Installing 30 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\USB\\imxUcmTcpciCxClient.inf: The driver package was successfully installed.
Installing 31 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\USDHC\\imxusdhc.inf: The driver package was successfully installed.
Installing 32 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\VPU\\imxvpukm.inf: The driver package was successfully installed.
Installing 33 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\VPUMalone\\malonekm.inf: The driver package was successfully installed.
Installing 34 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Wifi_mrvlpcie8897\\mrvlpcie8897.inf: The driver package was successfully installed.
Installing 35 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Wm8960codec\\wm8960codec.inf: The driver package was successfully installed.
Installing 36 of 36 - C:\\Users\\omar.wolfe-hussein\\Documents\\Apollo\\NXP-WIN-IMX8\\IoTEntOnNXP\\drivers\\Wm8962codec\\wm8962codec.inf: The driver package was successfully installed.
Error: 2
The command completed with errors. For more information, refer to the log file.
The DISM log file can be found at C:\\Windows\\Logs\\DISM\\dism.log
更多回帖
