全志科技
直播中
文小二
3年用户 902经验值
擅长:嵌入式技术 处理器/DSP 控制/MCU
私信 关注
[经验]
在全志V851S开发板上使用SSH配置步骤分析
在Tina板子上面开启SSH SERVER
在Tina配置界面的以下目录中
> Network > SSH
勾选的项目
《》openssh-keygen… OpenSSH keygen
<> openssh-server… OpenSSH server
1.配置 sshd_config
rm -rf /etc/ssh/sshd_config;touch /etc/ssh/sshd_config;vi /etc/ssh/sshd_config;
sshd_config 配置文件
Port 22
# Logging
SyslogFacility AUTH
LogLevel INFO
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_ed25519_key
# Authentication:
LoginGraceTime 2m
PermitRootLogin yes
PermitEmptyPasswords yes
StrictModes yes
MaxAuthTries 6
MaxSessions 10
AuthorizedKeysFile      .ssh/authorized_keys
TCPKeepAlive yes
Subsystem       sftp    /usr/lib/sftp-server
2.启动SSH SERVER
etc/init.d/sshd start
3.处理报错
报错Privilege separation user sshd does not exist
执行:
vi /etc/passwd
添加一行代码
sshd:x:109:65534::/var/run/sshd:/usr/sbin/nologin
3.报错procd_add_mdns
执行:
vi /etc/init.d/sshd
注释掉 #procd_add_mdns “ssh” “tcp” “$lport”
4.启动SSH SERVER
  • TIP:
    启动SSH 之前最好先连上wifi
    建议用MobaXterm 可以做到SSH 和 文件传输,两个功能同时使用。
  • 注意:
    SSH 登录账户 root
    SSH 登录密码 tina
上述操作如何在编译前配置好OPENSSH
修改4个地方:
1,设置开机启动wifi
启动 wifi, opensshserver
nano /root/tina-v853-docker/openwrt/target/v851s/v851s-lizard/busybox-init-base-files/etc/init.d/S50wifideamon
修改 S50wifideamon作为开机启动项配置文件:
#!/bin/sh
# Start wifi_daemon....
start() {
        wifi_daemon
        sleep 2
        wifi -o sta
        sleep 2
        wifi -c d1
//sleeep for 4seconds
        sleep 4
        ifconfig wlan0 192.168.0.105
        /etc/init.d/sshd start
stop() {
        printf "Stopping wifi_daemon: "
case "$1" in
    start)
        start
    stop)
        stop
    restart|reload)
        stop
        start
        echo "Usage: $0 {start|stop|restart}"
        exit 1
esac
exit $?
2,通过Makefile配置sshd_config
nano /root/tina-v853-docker/openwrt/package/feeds/net/openssh/Makefile
完整文件代码
# Copyright (C) 2006-2014 OpenWrt.org
# This is free software, licensed under the GNU General Public License v2.
# See /LICENSE for more information.
include $(TOPDIR)/rules.mk
PKG_NAME:=openssh
PKG_VERSION:=8.4p1
PKG_RELEASE:=4
PKG_SOURCE:=$(PKG_NAME)-$(PKG_VERSION).tar.gz
PKG_SOURCE_URL:=https://ftp.openbsd.org/pub/OpenBSD/OpenSSH/portable/ \
  https://ftp.spline.de/pub/OpenBSD/OpenSSH/portable/
PKG_HASH:=5a01d22e407eb1c05ba8a8f7c654d388a13e9f226e4ed33bd38748dafa1d2b24
PKG_LICENSE:=BSD ISC
PKG_LICENSE_FILES:=LICENCE
PKG_CPE_ID:=cpe:/a:openssh:openssh
PKG_REMOVE_FILES:=
PKG_CONFIG_DEPENDS := \
 CONFIG_OPENSSH_LIBFIDO2
PKG_BUILD_DEPENDS += OPENSSH_LIBFIDO2:libfido2
include $(INCLUDE_DIR)/package.mk
define Package/openssh/Default
 SECTION:=net
 CATEGORY:=Network
 DEPENDS:=+libopenssl +zlib
 TITLE:=OpenSSH
 MAINTAINER:=Peter Wagner <tripolar@gmx.at>
 URL:=http://www.openssh.com/
 SUBMENU:=SSH
 VARIANT:=without-pam
endef
define Package/openssh-moduli
 $(call Package/openssh/Default)
 DEPENDS+= +openssh-keygen
 TITLE+= moduli file
endef
define Package/openssh-moduli/description
OpenSSH server moduli file.
endef
define Package/openssh-client
 TITLE+= client
 ALTERNATIVES:=\
  200:/usr/bin/ssh:/usr/libexec/ssh-openssh \
  200:/usr/bin/scp:/usr/libexec/scp-openssh
endef
define Package/openssh-client/description
OpenSSH client.
endef
define Package/openssh-client/conffiles
/etc/ssh/ssh_config
endef
define Package/openssh-client-utils
 DEPENDS+= +openssh-client +openssh-keygen
 TITLE+= client utilities
endef
define Package/openssh-client-utils/description
OpenSSH client utilities.
endef
define Package/openssh-keygen
 TITLE+= keygen
endef
define Package/openssh-keygen/description
OpenSSH keygen.
endef
define Package/openssh-server
 DEPENDS+= +openssh-keygen +OPENSSH_LIBFIDO2:libfido2
 TITLE+= server
 USERID:=sshd=22:sshd=22
endef
define Package/openssh-server/config
 source "$(SOURCE)/Config.in"
endef
define Package/openssh-server/description
OpenSSH server.
endef
define Package/openssh-server/conffiles
/etc/ssh/ssh_host_ed25519_key.pub
/etc/ssh/ssh_host_rsa_key.pub
endef
define Package/openssh-server-pam
 DEPENDS+= +libpthread +openssh-keygen +libpam
 TITLE+= server (with PAM support)
 VARIANT:=with-pam
endef
define Package/openssh-server-pam/description
OpenSSH server (with PAM support).
endef
define Package/openssh-server-pam/conffiles
/etc/pam.d/sshd
/etc/security/access-sshd-local.conf
endef
define Package/openssh-sftp-client
 TITLE+= SFTP client
endef
define Package/openssh-sftp-client/description
OpenSSH SFTP client.
endef
define Package/openssh-sftp-server
 TITLE+= SFTP server
endef
define Package/openssh-sftp-server/description
OpenSSH SFTP server.
endef
define Package/openssh-sftp-avahi-service
 TITLE+= (SFTP Avahi service)
 DEPENDS:=+openssh-sftp-server +avahi-daemon
endef
define Package/openssh-sftp-avahi-service/description
 This package contains the service definition for announcing
 SFTP support via mDNS/DNS-SD.
endef
define Package/openssh-sftp-avahi-service/conffiles
/etc/avahi/services/sftp-ssh.service
endef
CONFIGURE_ARGS += \
 --sysconfdir=/etc/ssh \
 --with-privsep-user=sshd \
 --with-privsep-path=/var/empty \
 --disable-strip \
 --disable-etc-default-login \
 --disable-lastlog \
 --disable-utmp \
 --disable-utmpx \
 --disable-wtmp \
 --disable-wtmpx \
 --without-bsd-auth \
 --without-kerberos5 \
 --with-stackprotect \
 --with$(if $(CONFIG_OPENSSL_ENGINE),,out)-ssl-engine \
 --with$(if $(CONFIG_OPENSSH_LIBFIDO2),,out)-security-key-builtin
ifeq ($(BUILD_VARIANT),with-pam)
CONFIGURE_ARGS += \
 --with-pam
else
CONFIGURE_ARGS += \
 --without-pam
endif
CONFIGURE_VARS += LD="$(TARGET_CC)"
TARGET_LDFLAGS += -lpthread
endif
define Build/Compile
 $(MAKE) -C $(PKG_BUILD_DIR) \
  DESTDIR="$(PKG_INSTALL_DIR)" \
  STRIP_OPT="" \
  all install
endef
define Package/openssh-moduli/install
 $(INSTALL_DIR) $(1)/etc/ssh
 $(INSTALL_DATA) $(PKG_INSTALL_DIR)/etc/ssh/moduli $(1)/etc/ssh/
endef
define Package/openssh-client/install
 chmod 0700 $(1)/etc/ssh
 $(CP) $(PKG_INSTALL_DIR)/etc/ssh/ssh_config $(1)/etc/ssh/
 $(INSTALL_DIR) $(1)/usr/libexec
 $(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/bin/ssh $(1)/usr/libexec/ssh-openssh
 $(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/bin/scp $(1)/usr/libexec/scp-openssh
endef
define Package/openssh-client-utils/install
 $(INSTALL_DIR) $(1)/usr/bin
 $(INSTALL_BIN) $(foreach bin,add agent keyscan keysign,$(PKG_BUILD_DIR)/ssh-$(bin)) $(1)/usr/bin/
endef
define Package/openssh-keygen/install
 $(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/bin/ssh-keygen $(1)/usr/bin/
endef
define Package/openssh-server/install
 $(INSTALL_DATA) $(PKG_INSTALL_DIR)/etc/ssh/sshd_config $(1)/etc/ssh/
 sed -r -i 's,^#(HostKey /etc/ssh/ssh_host_(rsa|ed25519)_key)$$$$,\1,' $(1)/etc/ssh/sshd_config
 $(INSTALL_DIR) $(1)/etc/init.d
 $(INSTALL_BIN) ./files/sshd.init $(1)/etc/init.d/sshd
 $(INSTALL_DIR) $(1)/lib/preinit
 $(INSTALL_BIN) ./files/sshd.failsafe $(1)/lib/preinit/99_10_failsafe_sshd
 $(INSTALL_DIR) $(1)/usr/sbin
 $(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/sbin/sshd $(1)/usr/sbin/
endef
define Package/openssh-server-pam/install
 $(call Package/openssh-server/install,$(1))
 sed -i 's,#Port 22,Port 22,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#SyslogFacility AUTH,SyslogFacility AUTH,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#LogLevel INFO,LogLevel INFO,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#LoginGraceTime 2m,LoginGraceTime 2m,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#StrictModes yes,StrictModes yes,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#MaxAuthTries 6,MaxAuthTries 6,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#MaxSessions 10,MaxSessions 10,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#TCPKeepAlive yes,TCPKeepAlive yes,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#PermitRootLogin prohibit-password,PermitRootLogin yes,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#UsePAM no,UsePAM yes,g' $(1)/etc/ssh/sshd_config
 sed -i 's,#PermitEmptyPasswords yes,PermitEmptyPasswords yes,g' $(1)/etc/ssh/sshd_config
 $(INSTALL_DIR) $(1)/etc/pam.d
 $(INSTALL_DATA) ./files/sshd.pam $(1)/etc/pam.d/sshd
 $(INSTALL_DIR) $(1)/etc/security
 $(INSTALL_DATA) ./files/sshd.pam-access $(1)/etc/security/access-sshd-local.conf
endef
define Package/openssh-sftp-client/install
 $(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/bin/sftp $(1)/usr/bin/
endef
define Package/openssh-sftp-server/install
 $(CP) $(PKG_INSTALL_DIR)/usr/lib/sftp-server $(1)/usr/lib/
 ln -sf ../lib/sftp-server $(1)/usr/libexec/sftp-server
endef
define Package/openssh-sftp-avahi-service/install
 $(INSTALL_DIR) $(1)/etc/avahi/services
 $(INSTALL_DATA) ./files/sftp-ssh.service $(1)/etc/avahi/services/
endef
$(eval $(call BuildPackage,openssh-client))
$(eval $(call BuildPackage,openssh-moduli))
$(eval $(call BuildPackage,openssh-client-utils))
$(eval $(call BuildPackage,openssh-keygen))
$(eval $(call BuildPackage,openssh-server))
$(eval $(call BuildPackage,openssh-server-pam))
$(eval $(call BuildPackage,openssh-sftp-client))
$(eval $(call BuildPackage,openssh-sftp-server))
$(eval $(call BuildPackage,openssh-sftp-avahi-service))
3,配置passwd
nano /root/tina-v853-docker/openwrt/package/allwinner/system/busybox-init-base-files/files/etc/passwd
添加一行代码
4,ssh开机脚本
nano /root/tina-v853-docker/openwrt/package/feeds/net/openssh/files/sshd.init
注释掉 procd…
配置文件
#!/bin/sh /etc/rc.common
# Copyright (C) 2006-2011 OpenWrt.org
START=50
STOP=50
USE_PROCD=1
PROG=/usr/sbin/sshd
start_service() {
 for type in rsa ed25519
 do
  # check for keys
  key=/etc/ssh/ssh_host_${type}_key
  [ ! -f $key ] && {
   # generate missing keys
   [ -x /usr/bin/ssh-keygen ] && {
    /usr/bin/ssh-keygen -N '' -t $type -f $key 2>&- >&-
 done
 mkdir -m 0700 -p /var/empty
 local lport=$(awk '/^Port / { print $2; exit }' /etc/ssh/sshd_config)
 [ -z "$lport" ] && lport=22
 procd_open_instance
 #procd_add_mdns "ssh" "tcp" "$lport"
 procd_set_param command $PROG -D
 procd_close_instance
shutdown() {
 local pid
 stop
 # kill active clients
 for pid in $(pidof sshd)
 do
  [ "$pid" = "$$" ] && continue
  [ -e "/proc/$pid/stat" ] && kill $pid
 done
5.勾选编译项目 (3个)如下图(要选准哦,否则会报错)
在这里插入图片描述
更多回帖
