乐鑫技术交流
直播中
胡秋阳
14年用户 1664经验值
私信 关注
[问答]
ESP32尝试运行AT+GSLP命令时出现卡死怎么解决?
本人尝试用ESP32 PICO D4的开发板进行AT指令的测试,直接烧录的是ESP32-PICO-D4 AT Bin V2.0里面的内容。上电之后可以正常进行WiFi的操作,但尝试进入深度睡眠时发生错误。
ready
WIFI CONNECTED
WIFI GOT IP
AT
OK
AT+GSLP=1000
OK
ready
Code: Select all
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6352
ho 0 tail 12 room 4
load:0x40078000,len:11332
load:0x40080400,len:6564
entry 0x40080760
I (32) boot: ESP-IDF v3.3 2nd stage bootloader
I (32) boot: compile time 06:10:38
I (32) boot: Enabling RNG early entropy source...
I (36) boot: SPI Speed      : 40MHz
I (40) boot: SPI Mode       : DIO
I (44) boot: SPI Flash Size : 4MB
I (48) boot: Partition Table:
I (52) boot: ## Label            Usage          Type ST Offset   Length
I (59) boot:  0 phy_init         RF data          01 01 0000f000 00001000
I (67) boot:  1 otadata          OTA data         01 00 00010000 00002000
I (74) boot:  2 nvs              WiFi data        01 02 00012000 0000e000
I (81) boot:  3 at_customize     unknown          40 00 00020000 000e0000
I (89) boot:  4 ota_0            OTA app          00 10 00100000 00180000
I (96) boot:  5 ota_1            OTA app          00 11 00280000 00180000
I (104) boot: End of partition table
I (108) boot: No factory image, trying OTA 0
I (113) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x247c4 (149444) map
I (175) esp_image: segment 1: paddr=0x001247ec vaddr=0x3ffbdb60 size=0x03028 ( 12328) load
I (180) esp_image: segment 2: paddr=0x0012781c vaddr=0x40080000 size=0x00400 (  1024) load
I (182) esp_image: segment 3: paddr=0x00127c24 vaddr=0x40080400 size=0x083ec ( 33772) load
I (204) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xee128 (975144) map
I (547) esp_image: segment 5: paddr=0x0021e148 vaddr=0x400887ec size=0x0f108 ( 61704) load
I (573) esp_image: segment 6: paddr=0x0022d258 vaddr=0x400c0000 size=0x00064 (   100) load
I (587) boot: Loaded app from partition at offset 0x100000
I (606) boot: Set actual ota_seq=1 in otadata[0]
I (606) boot: Disabling RNG early entropy source...
2.0.0
max tx power=78,ret=0
Guru Meditation Error: Core  0 panic'ed (Interrupt wdt timeout on CPU0)
Core 0 register dump:
PC      : 0x40085766  PS      : 0x00060e34  A0      : 0x8010d4d3  A1      : 0x3ffd7ed0
A2      : 0x00000011  A3      : 0x00000000  A4      : 0x000000ff  A5      : 0x0000ff00
A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x3ff49050  A9      : 0x00002900
A10     : 0x00000011  A11     : 0x00000006  A12     : 0x00060020  A13     : 0x3ffd3956
A14     : 0x0000000a  A15     : 0x3ffd9a10  SAR     : 0x00000000  EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
ELF file SHA256: ets Jun  8 2016 00:22:57
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x40080760
W (63) boot: PRO CPU has been reset by WDT.
W (63) boot: WDT reset info: PRO CPU PC=0x40080f64
W (63) boot: WDT reset info: APP CPU PC=0xd3cdd024
I (69) boot: ESP-IDF v3.3 2nd stage bootloader
I (74) boot: compile time 06:10:38
I (78) boot: Enabling RNG early entropy source...
I (84) boot: SPI Speed      : 40MHz
I (88) boot: SPI Mode       : DIO
I (92) boot: SPI Flash Size : 4MB
I (96) boot: Partition Table:
I (99) boot: ## Label            Usage          Type ST Offset   Length
I (107) boot:  0 phy_init         RF data          01 01 0000f000 00001000
I (114) boot:  1 otadata          OTA data         01 00 00010000 00002000
I (122) boot:  2 nvs              WiFi data        01 02 00012000 0000e000
I (129) boot:  3 at_customize     unknown          40 00 00020000 000e0000
I (137) boot:  4 ota_0            OTA app          00 10 00100000 00180000
I (145) boot:  5 ota_1            OTA app          00 11 00280000 00180000
I (152) boot: End of partition table
I (156) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x247c4 (149444) map
I (218) esp_image: segment 1: paddr=0x001247ec vaddr=0x3ffbdb60 size=0x03028 ( 12328) load
I (223) esp_image: segment 2: paddr=0x0012781c vaddr=0x40080000 size=0x00400 (  1024) load
I (225) esp_image: segment 3: paddr=0x00127c24 vaddr=0x40080400 size=0x083ec ( 33772) load
I (248) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xee128 (975144) map
I (590) esp_image: segment 5: paddr=0x0021e148 vaddr=0x400887ec size=0x0f108 ( 61704) load
I (616) esp_image: segment 6: paddr=0x0022d258 vaddr=0x400c0000 size=0x00064 (   100) load
I (630) boot: Loaded app from partition at offset 0x100000
I (630) boot: Disabling RNG early entropy source...
2.0.0
请问使用AT指令进入深度睡眠的话,是否有其他需要设置的地方,参考《ESP32 AT指令集与使用示例》并未发现需要设置的地方,还望解惑,谢谢!
更多回帖
