试图在我的基于 imx8mm 的板上添加一个键盘。
我将其添加到我的设备树中:
gpio-keys {
compa
tible = "gpio-keys";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_keys>;
col0_btn {
label = "COL0_BTN";
gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
gpio-key,wakeup;
linux,code = ;
&iomuxc {
pinctrl_gpio_keys: keys0grp {
fsl,pins = <
MX8MM_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x1d6 /* KEY_C0 */
在 Linux 中使用“gpioinfo”命令进行检查:
root@asdf:~# gpioinfo 0
gpiochip0 - 32 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed "interrupt" input active-high [used]
line 4: unnamed unused input active-high
line 5: unnamed "COL0_BTN" input active-low [used]
看起来不错。
检查 evtest /dev/input/event0
root@asdf:/# evtest /dev/input/event0
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "gpio-keys"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 256 (BTN_0)
Properties:
Testing ... (interrupt to exit)
但是,从未注册过按钮的按下。我想知道之间是否以某种方式映射
gpios = <&gpio1 5 GPIO_ACTIVE_LOW> 和 MX8MM_IOMUXC_GPIO1_IO05_GPIO1_IO5 不正确,是不是看起来很明显?
