NXP MCU 技术论坛
直播中
飞毛腿452
9年用户 996经验值
擅长:电源/新能源
私信 关注
[问答]
使用示例sysview_tracing_heap_log跟踪ESP32s3 devkit上的堆使用报错是为什么?
我正在尝试使用示例 sysview_tracing_heap_log 跟踪 ESP32s3 devkit 上的堆使用情况
此错误意味着什么:
代码:全选
Not enough args! Need 2 trace data destinations!
Failed to init cmd ctx (-4)!
gdb 的完整输出:
代码:全选
kaspernyhus@HP-ZBook:~/esp/sysview_tracing_heap_log$ xtensa-esp32s3-elf-gdb -x gdbinit build/sysview_tracing_heap_log.elf
GNU gdb (esp-gdb) 11.2_20220823
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "--host=x86_64-linux-gnu --target=xtensa-esp-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
Find the GDB manual and other documentation resources online at:
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/sysview_tracing_heap_log.elf...
0x42016392 in esp_pm_impl_waiti () at /home/kaspernyhus/esp/esp-idf/components/esp_pm/pm_impl.c:839
839        }
JTAG tap: esp32s3.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
JTAG tap: esp32s3.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
[esp32s3.cpu0] requesting target halt and executing a soft reset
[esp32s3.cpu0] Debug controller was reset.
[esp32s3.cpu0] Core was reset.
[esp32s3.cpu0] Target halted, PC=0x500000EF, debug_reason=00000000
[esp32s3.cpu0] Reset cause (3) - (Software core reset)
[esp32s3.cpu1] requesting target halt and executing a soft reset
[esp32s3.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
[esp32s3.cpu1] Debug controller was reset.
[esp32s3.cpu1] Core was reset.
[esp32s3.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
[esp32s3.cpu1] Reset cause (3) - (Software core reset)
Warning: 'flushregs', an alias for the command 'maintenance flush register-cache', is deprecated.
Use 'maintenance flush register-cache'.
Temporary breakpoint 1 at 0x42005258: file /home/kaspernyhus/esp/esp-idf/components/app_trace/heap_trace_tohost.c, line 36.
Note: automatically using hardware breakpoints for read-only addresses.
Temporary breakpoint 2 at 0x42005270: file /home/kaspernyhus/esp/esp-idf/components/app_trace/heap_trace_tohost.c, line 48.
[esp32s3.cpu0] Target halted, PC=0x42005258, debug_reason=00000001
Set GDB target to 'esp32s3.cpu0'
[esp32s3.cpu1] Target halted, PC=0x40043A40, debug_reason=00000000
[New Thread 1070541728]
[New Thread 1070543616]
[New Thread 1070537156]
[Switching to Thread 1070541728]
Thread 2 "main" hit Temporary breakpoint 1, heap_trace_start (mode_param=HEAP_TRACE_ALL) at /home/kaspernyhus/esp/esp-idf/components/app_trace/heap_trace_tohost.c:36
36        {
Total trace memory: 16384 bytes
更多回帖
