NXP MCU 技术论坛
直播中
世态薄凉
8年用户 1173经验值
私信 关注
[问答]
rsdk-1.4.8-r0 do_compile:oe_runmake失败的原因?怎么处理?
错误:rsdk-1.4.8-r0 do_compile:oe_runmake 失败
错误:rsdk-1.4.8-r0 do_compile:执行'/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64- poky-linux/rsdk/1.4.8-r0/temp/run.do_compile.14546' 失败,退出代码为 1:
[Target ... rsdk_linux]
make[1]:警告:jobserver 不可用:使用 -j1。将“+”添加到父 make 规则。
make[1]: 进入目录'/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os /linux/user'
**** Building CONFIG_CINT ****
CONFIG_SGMII_PHY = 1
CONFIG_CINT = 1
make[2]: 进入目录'/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/ aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os/osal/linux'
[编译 ... sal_file.
/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/ext-toolchains/gcc-linaro-aarch64-linux-gnu-4.9-2014.09_linux/bin/../libexec/gcc/aarch64-linux -gnu/4.9.2/cc1: 加载共享库时出错: libz.so.1: 无法打开共享对象文件: 没有这样的文件或目录
make[2]: *** [/home/hmecd001523/yocto-bsp/ orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/make/Make.depend:4:/home/hmecd001523/yocto-bsp/orion -yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/build/rsdk_linux/os/osal/linux/./sal_file.o] 错误 1
​​make [2]: 离开目录 '/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os/ osal/linux'
make[1]: *** [Makefile:50: osal] 错误 2
make[1]: 离开目录'/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/rsdk-1.4.8/os /linux/user'
make: *** [Makefile:84: rsdk_linux] 错误 2
警告:从 shell 命令退出代码 1。
错误:故障日志文件存储在:/home/hmecd001523/yocto-bsp/orion-yocto-bsp/build/tmp/work/aarch64-poky-linux/rsdk/1.4.8-r0/temp/log.do_compile.14546
更多回帖
