嗨,我正在寻找有关如何解决我正在处理的定制 LS1046A 板上的启动过程的建议。我正在使用 LSDK 21.08 平台,并启用了调试,并添加了代码来跟踪启动过程各个阶段的进度,但我无法进入 u-boot。
我的诊断终端的输出如下所示:
NO
tiCE: --------------------------------------------------------------
NOTICE: TFA BOOTLOADER STARTED
NOTICE: --------------------------------------------------------------
INFO: BL1: v2.4(debug):7d8a5dfde1-dirty
INFO: BL1: Built : 06:31:12, Oct 13 2022
INFO: soc_early_init()->soc_errata()
INFO: SoC workaround for Errata A008850 Early-Phase was applied
INFO: SoC workaround for Errata A010539 was applied
INFO: RCW BOOT SRC is QSPI
INFO: SoC workaround for DDR Errata A008511 was applied
INFO: SoC workaround for DDR Errata A009803 was applied
INFO: SoC workaround for DDR Errata A009942 was applied
INFO: SoC workaround for DDR Errata A010165 was applied
INFO: soc_early_init()->i2c_init()
INFO: init_ddr()
INFO: platform clock 600000000
INFO: DDR PLL1 1400000000
INFO: DDR PLL2 300000000
INFO: Calling: dram_init()
INFO: dram_init() - CONFIG_STATIC_DDR is SET
INFO: Getting STATIC register values for DDR
INFO: ------------------------------
NOTICE: FIRST MEMORY IN NOR FLASH...
NOTICE: 40000000: 55AA55AA
NOTICE: 40000004: 0001EE01
NOTICE: 40000008: 0E000E0C
NOTICE: 4000000C: 0000000E
NOTICE: 40000010: 00000000
NOTICE: 40000014: 00000000
NOTICE: 40000018: 88880000
NOTICE: 4000001C: 1200C000
NOTICE: 40000020: 00000040
NOTICE: 40000024: 000000C1
NOTICE: 40000028: 00000000
NOTICE: 4000002C: 00000000
NOTICE: 40000030: 00000000
NOTICE: 40000034: 00880300
NOTICE: 40000038: 00410420
NOTICE: 4000003C: 01310024
NOTICE: 40000040: 96000000
NOTICE: 40000044: 01000000
NOTICE: 40000048: 5C015709
NOTICE: 4000004C: 00001020
NOTICE: SOFTWARE BUILT WITH STATIC DDR VALUES FOR TARGET:
NOTICE: *** DEVELOPMENT BOARD ***
INFO: fixed static size = 0x100000000
INFO: Time before programming controller 107 ms
INFO: Program controller registers
INFO: Preparing to program registers
INFO: Some registers programmed, preparing for ERRATAs
INFO: Skipping: ERRATA_DDR_A009663
INFO: Finishing registers, preparing for more ERRATAs
INFO: Programming: ERRATA_DDR_A009803
INFO: Programming: ERRATA_DDR_A008511
INFO: Programming: ERRATA_DDR_A009942
WARNING: Warning: Optimal CPO value not set.
INFO: Programming: ERRATA_DDR_A010165
INFO: Controller released...
INFO: total size 4 GB
INFO: Need to wait up to 1520 ms
INFO: Waiting is over...
INFO: Reading debug[9] as 0x1c001b00
INFO: Reading debug[10] as 0x1d001d00
INFO: Reading debug[11] as 0x20002000
INFO: Reading debug[12] as 0x21002100
INFO: cpo_min 0x1b
INFO: cpo_max 0x21
INFO: debug[28] 0x70006f
WARNING: Warning: A009942 requires setting cpo_sample to 0x45
INFO: Controller Registers read-back
INFO: *0x1080000 = 0xff
INFO: *0x1080080 = 0x80040412
INFO: *0x1080100 = 0x2161100
INFO: *0x1080104 = 0xd1770004
INFO: *0x1080108 = 0xf3fc8265
INFO: *0x108010c = 0x5941a0
INFO: *0x1080110 = 0xe5000000
INFO: *0x1080114 = 0x401140
INFO: *0x1080118 = 0x1030631
INFO: *0x108011c = 0x100000
INFO: *0x1080120 = 0x600081f
INFO: *0x1080124 = 0x1ffe07ff
INFO: *0x1080128 = 0x4321dcba
INFO: *0x1080130 = 0x2800000
INFO: *0x1080160 = 0x220002
INFO: *0x1080164 = 0x5401400
INFO: *0x108016c = 0x26600000
INFO: *0x1080170 = 0x8a090705
INFO: *0x1080174 = 0xc675f606
INFO: *0x1080190 = 0x6070809
INFO: *0x1080194 = 0x90a0a08
INFO: *0x1080220 = 0x500
INFO: *0x1080224 = 0x8000000
INFO: *0x1080250 = 0x5447a00
INFO: *0x1080270 = 0xffff
INFO: *0x1080280 = 0xeeeedeee
INFO: *0x1080284 = 0xeeedeede
INFO: *0x1080288 = 0x11112111
INFO: *0x108028c = 0x11121121
INFO: *0x1080290 = 0x21de0001
INFO: *0x1080400 = 0x8
INFO: *0x1080404 = 0x9c00009c
INFO: *0x1080408 = 0x220c008
INFO: *0x108040c = 0x200000
INFO: *0x1080b20 = 0x8080
INFO: *0x1080b24 = 0x80000000
INFO: *0x1080b28 = 0x80080000
INFO: *0x1080b2c = 0x80
INFO: *0x1080bf8 = 0x20502
INFO: *0x1080bfc = 0x100
INFO: *0x1080f04 = 0x2
INFO: *0x1080f08 = 0xf
INFO: *0x1080f0c = 0x14000c20
INFO: *0x1080f24 = 0x1d001d00
INFO: *0x1080f28 = 0x1c001d00
INFO: *0x1080f2c = 0x1d001c00
INFO: *0x1080f30 = 0x1d001d00
INFO: *0x1080f34 = 0x1d004000
INFO: *0x1080f48 = 0x1
INFO: *0x1080f4c = 0x94000000
INFO: *0x1080f50 = 0xe000d00
INFO: *0x1080f54 = 0xe000d00
INFO: *0x1080f58 = 0xd000e00
INFO: *0x1080f5c = 0xd000d00
INFO: *0x1080f60 = 0xd000000
INFO: *0x1080f64 = 0x9000
INFO: *0x1080f68 = 0x20
INFO: *0x1080f70 = 0x70006f
INFO: *0x1080f94 = 0x80000000
INFO: *0x1080f9c = 0x36003600
INFO: *0x1080fa0 = 0x35003700
INFO: *0x1080fa4 = 0x35003400
INFO: *0x1080fa8 = 0x34003700
INFO: *0x1080fac = 0x35000000
INFO: *0x1080fb0 = 0x3
INFO: *0x1080fb4 = 0x1f1c1b1e
INFO: *0x1080fb8 = 0x1d1c1e1b
INFO: *0x1080fbc = 0x1f1c1c1f
INFO: *0x1080fc0 = 0x1d1d1d1b
INFO: *0x1080fc4 = 0x1f1d1d1f
INFO: *0x1080fc8 = 0x1c1d1e1d
INFO: *0x1080fcc = 0x1f1f1e20
INFO: *0x1080fd0 = 0x1d1e201d
INFO: *0x1080fd4 = 0x1f1d191f
INFO: *0x1080fd8 = 0x1d1e1e1b
INFO: *0x1080fdc = 0x1f1c1b1e
INFO: *0x1080fe0 = 0x1c1d1d1b
INFO: *0x1080fe4 = 0x1f1d1b1d
INFO: *0x1080fe8 = 0x1d1c1b17
INFO: *0x1080fec = 0x1f201d1f
INFO: *0x1080ff0 = 0x1d20201e
INFO: *0x1080ff4 = 0x1f1e1c1f
INFO: *0x1080ff8 = 0x1d1f1e1c
INFO: *0x1080ffc = 0x1f000000
NOTICE: After programming controller: 4 GB DDR4, 64-bit, CL=15, ECC on
INFO: Time used by DDR driver 1062 ms
INFO: SoC workaround for Errata A008850 Post-Phase was applied
NOTICE: BL2: v2.4(debug):7d8a5dfde1-dirty
NOTICE: BL2: Built : 06:31:12, Oct 13 2022
INFO: bl2_arch_setup()
INFO: bl2_plat_preload_setup()
INFO: mem_access_setup(): Configuring TrustZone Controller
COMPREHENSIVE DDR MEMORY TESTING
Starting Address: 82000000
Ending Address : 82000078
0x82000000 ....................passed
0x82000008 ....................passed
0x82000010 ....................passed
0x82000018 ....................passed
0x82000020 ....................passed
0x82000028 ....................passed
0x82000030 ....................passed
0x82000038 ....................passed
0x82000040 ....................passed
0x82000048 ....................passed
0x82000050 ....................passed
0x82000058 ....................passed
0x82000060 ....................passed
0x82000068 ....................passed
0x82000070 ....................passed
0x82000078 ....................passed
INFO: BL2: Doing platform setup
INFO: BL2: Loading image id 3
INFO: load_auth_image()
INFO: load_auth_image_internal()
INFO: load_image()
INFO: io_read() - 1. pre assert
INFO: io_read() - 2. post assert
INFO: io_read() - 3. handle assignment
INFO: io_read() - 4. device read
INFO: io_read() - 5. finished
INFO: Made past finding the size of the image...
NOTICE: IMAGE DATA LOAD
NOTICE: id: 3
NOTICE: start addr: 0xfbe00000
NOTICE: size: 0xc63d
NOTICE: end addr: 0xfbe0c63d
INFO: Image id=3 loaded: 0xfbe00000 - 0xfbe0c63d
INFO: Image loaded with return value of : 0
INFO: BL2: Loading image id 5
INFO: load_image()
NOTICE: id: 5
NOTICE: start addr: 0x82000000
NOTICE: size: 0xc6ad2
NOTICE: end addr: 0x820c6ad2
INFO: Image id=5 loaded: 0x82000000 - 0x820c6ad2
INFO: BL2: Getting Parameters platform next BL process
INFO: BL2: Flushing next parameters
INFO: BL2: returning from bl2_load_images()
NOTICE: BL2: Booting BL31
INFO: Entry point address = 0xfbe00000
INFO: SPSR = 0x3cd
INFO: Argument #0 = 0x1000c3c8
INFO: Argument #1 = 0xf1e2d3c4b5a6978
INFO: Argument #2 = 0x0
INFO: Argument #3 = 0x1000c3f8
INFO: Argument #4 = 0x227f3fff
INFO: Argument #5 = 0x0
INFO: Argument #6 = 0x0
INFO: Argument #7 = 0x0
NOTICE: BL31: v2.4(debug):7d8a5dfde1-dirty
NOTICE: BL31: Built : 06:31:22, Oct 13 2022
INFO: BL31: Initialising Platform
INFO: bl31_platform_setup()
INFO: ARM GICv2 driver initialized
INFO: BL31: Initialising Helper Libraries
INFO: BL31: Initializing runtime services
INFO: BL31: cortex_a72: CPU workaround for 859971 was applied
WARNING: BL31: cortex_a72: CPU workaround for 1319367 was missing!
INFO: BL31: cortex_a72: CPU workaround for cve_2017_5715 was applied
INFO: BL31: cortex_a72: CPU workaround for cve_2018_3639 was applied
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x82000000
INFO: SPSR = 0x3c9
INFO: Argument #0 = 0x0
INFO: Argument #1 = 0x0
INFO: Argument #3 = 0x0
INFO: Argument #4 = 0x0
我不明白参数的价值。
看起来 u-boot 从 TF-A 代码中获取了有关 DDR4 的信息,所以我不明白为什么这不起作用。
此外,由于 BL2 和 BL3 正在运行(看起来它们正在从 DDR4 运行),我不明白为什么 u-boot 不能运行。
有人能指出我正确的方向吗?还有其他人遇到过这种行为吗?
