NXP MCU 技术论坛
直播中
蔡鼎瑾
9年用户 1115经验值
私信 关注
[问答]
LS1046A u-boot不稳定是怎么回事?
嗨,我正在启动我们自己的董事会。
U-boot 不稳定,每次都卡在不同的地方。
这是3个卡住的日志
1.卡在DRAM INFO
U-Boot 2020.04-脏(2022 年 11 月 1 日 - 18:09:02 +0900)
SoC:LS1046AE Rev1.0 (0x87070010)
时钟配置:
CPU0(A72):1600 MHz CPU1(A72):1600 MHz CPU2(A72):1600 MHz
CPU3(A72):1600 MHz
总线:600 MHz DDR:1600 MT/s FMAN: 900 MHz
Reset Configuration Word (RCW):
00000000: 0c100010 12000000 00000000 00000000
00000010: 10405577 40a00016 40000000 c1000000
00000020: 00200000 00000000 00000000 0003affc
00000030: 20004504 04201101 00000096 00000001
Model: LS1046A FRWY Board
Board: LS1046AFRWY, Rev: B, boot from QSPI
SD1_CLK1 = 100.00MHZ,SD1_CLK2 = 100.00MHZ
DRAM:7.9 GiB(DDR4,64 位,CL=11,ECC 关闭)2.坚持“同步中止”处理程序
U-Boot 2020.04-dirty (Nov 01 2022 - 18:09:02 +0900)
时钟配置:
CPU0(A72):1600 MHz CPU1(A72):1600 MHz CPU2(A72): 1600 MHz
CPU3(A72):1600 MHz
Bus: 600 MHz DDR: 1600 MT/s FMAN: 900 MHz
型号:LS1046A FRWY 电路板电路板:LS1046AFRWY,修订版:B,从 QSPI SD1_CLK1 = 100.00MHZ,SD1_CLK2 = 100.00MHZ
启动DRAM:7.9 GiB(DDR4,SERDES CL11 关闭)使用协议 1 : 4160 (0x1040)
使用 SERDES2 协议:21879 (0x5577)
NAND:fsl_ifc_chip_init:地址不匹配任何芯片选择
0 MiB
MMC:FSL_SDHC:0
EEPROM:读取失败。
In: serial
Out: serial
Err: serial
Net: Invalid SerDes protocol 0x1040 for LS1046AFRWY
unrecognized JEDEC id bytes: ef, 60, 18
"Synchronous Abort" handler, esr 0x96000004
elr: 000000008204a6a4 lr : 000000008204a68c (reloc)
elr: 00000000fbd786a4 lr : 00000000fbd7868c
x0 : f2a12001d2808001 x1 : 0000000000001070
x2 : 00000000fbdc8000 x3 : 0000000000001071
x4 : 00000000fbc2b880 x5 : 00000000fbc2bd60
x6 : 00000000fbdc83f0 x7 : 00000000fbdc8400
x8 : 00000000fbc43ad0 x9 : 0000000000000008
x10: 0000000000000010 x11: 00000000fbc26f8c
x12: 0000000000001238 x13: 0000000000001174
x14: 00000000fbc26fdc x15: 0000000000000002
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000fbc29dc0 x19: 00000000fbc33ad0
x20: f2a12001d2808001 x21: 0000000001a00000
x22: 0000000000000000 x23: 0000000000000000
x24: 0000000000000000 x25: 0000000000000000
x26: 0000000000000000 x27:0000000000000000
x28:0000000000000000 x29:00000000fbc27200
代码:90000200 91089c00 9400b6f5 17ffffd7 (f940settingc400)
重置 CPU ...
重置3. 卡在案例 2 的同一个地方,但使用不同的同步处理程序。
这应该被视为 DDR 设置问题吗?
更多回帖
