NXP MCU 技术论坛
直播中
陈秀英
7年用户 1219经验值
私信 关注
[问答]
UUU下载android10镜像问题求解
U-Boot SPL 2020.04 (Feb 09 2023 - 02:07:24 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from USB SDP
SDP: initialize...
SDP: handle requests...
Downloading file of size 961248 to 0x40400000... done
Jumping to header at 0x40400000
Header Tag is not an IMX image
Found header at 0x40429da0
NOTICE:  BL31: v2.2(release):android-11.0.0_1.2.0-rc2-0-gcb435ee78
NOTICE:  BL31: Built : 02:08:18, Feb  9 2023
U-Boot 2020.04 (Feb 09 2023 - 02:07:24 +0000)
CPU:   i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 38C
Reset cause: POR
Model: NXP i.MX8MM EVK board
DRAM:  2 GiB
tcpc_init: Can't find device id=0x52
setup_typec: tcpc port2 init failed, err=-19
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port1 init failed, err=-19
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... MMC: no card present
*** Warning - No block device, using default environment
In:    serial
Out:   serial
Err:   serial
BuildInfo:
  - ATF cb435ee
  - U-Boot 2020.04
Detect USB boot. Will enter fastboot mode!
Net:   Could not get PHY for FEC0: addr 0
No ethernet found.
Fastboot: Normal
Boot from USB for uuu
Hit any key to stop autoboot:  0
flash target is MMC:1
MMC card init failed!
** Block device MMC 1 not supported
flash target is MMC:2
switch to partitions #0, OK
mmc2(part 0) is current device
MMC erase: dev # 2, block # 8192, count 8 ...
Caution! Your devices Erase group is 0x400
The erase range would be change to 0x2000~0x23ff
8 blocks erased: OK
Starting download of 2736144 bytes
downloading of 2736144 bytes finished
writing to partition 'bootloader0'
Initializing 'bootloader0'
switch to partitions #1, OK
mmc2(part 1) is current device
Writing 'bootloader0'
MMC write: dev # 2, block # 66, count 5345 ... 5345 blocks written: OK
Writing 'bootloader0' DONE!
Starting download of 34304 bytes
downloading of 34304 bytes finished
writing to partition 'gpt'
Initializing 'gpt'
Writing 'gpt'
MMC write: dev # 2, block # 0, count 34 ... 34 blocks written: OK
Writing 'gpt' DONE!
flash backup gpt image successfully
The device is already unlocked
SATA isn't buildin
Starting download of 4194304 bytes
downloading of 4194304 bytes finished
writing to partition 'dtbo_a'
Initializing 'dtbo_a'
Writing 'dtbo_a'
MMC write: dev # 2, block # 16384, count 8192 ... 8192 blocks written: OK
Writing 'dtbo_a' DONE!
Starting download of 67108864 bytes
downloading of 67108864 bytes finished
writing to partition 'boot_a'
Initializing 'boot_a'
Writing 'boot_a'
MMC write: dev # 2, block # 32768, count 131072 ... 131072 blocks written: OK
Writing 'boot_a' DONE!
Starting download of 4096 bytes
downloading of 4096 bytes finished
writing to partition 'vbmeta_a'
Initializing 'vbmeta_a'
Writing 'vbmeta_a'
MMC write: dev # 2, block # 27250688, count 8 ... 8 blocks written: OK
Writing 'vbmeta_a' DONE!
Starting download of 16765036 bytes
downloading of 16765036 bytes finished
writing to partition 'super'
sparse flash target is mmc:2
writing to partition 'super' for sparse, buffer size 16765036
Flashing sparse image at offset 311296
Flashing Sparse Image
........ wrote 16777216 bytes to 'super'
Starting download of 16764980 bytes
downloading of 16764980 bytes finished
writing to partition 'super' for sparse, buffer size 16764980
........ wrote 16764928 bytes to 'super'
Starting download of 3252276 bytes
downloading of 3252276 bytes finished
writing to partition 'super' for sparse, buffer size 3252276
........ wrote 3252224 bytes to 'super'
Starting download of 52 bytes
downloading of 52 bytes finished
writing to partition 'super' for sparse, buffer size 52
........ wrote 0 bytes to 'super'
将 0 个字节写入“super”!!!
请检查一下,谢谢。
更多回帖
