乐鑫技术交流
直播中
刘洋
10年用户 1072经验值
擅长:可编程逻辑 嵌入式技术
私信 关注
[问答]
aliyun mqtt例程接入提示错误信息NVS Flash初始化fctry失败是怎么回事?
错误信息如下:
I (3759) event: sta ip: 192.168.31.189, mask: 255.255.255.0, gw: 192.168.31.1
E (3769) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
E (3779) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
mqtt_main|124 :: mqtt example
E (3789) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
E (3799) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
[err] IOT_MQTT_Construct(395): Invalid product key, abort!
mqtt_main|227 :: MQTT construct failed
E (3819) FreeRTOS: FreeRTOS Task "mqtt_example" should not return, Aborting now!
abort() was called at PC 0x4008d1ff on core 1
0x4008d1ff: vPortTaskWrapper at D:/msys32/home/Administrator/esp/esp-idf/components/freertos/port.c:403
ELF file SHA256: f9c1359151487bb8ff8464aa8eb7edc45334155a65d2b46a6aacb7e9737a2209
Backtrace: 0x40086fe8:0x3ffc9250 0x40087235:0x3ffc9270 0x4008d1ff:0x3ffc9290
0x40086fe8: invoke_abort at D:/msys32/home/Administrator/esp/esp-idf/components/esp32/panic.c:715
0x40087235: abort at D:/msys32/home/Administrator/esp/esp-idf/components/esp32/panic.c:715
例程链接https://github.com/espressif/esp-aliyun ... tt_example
信息提示连接wifi成功,但是提示错误信息NVS Flash 初始化fctry失败,要我检查是否flash过fctry分区,但是我已经按照readme中进行分区写操作了,求大大们教教!
更多回帖
