I (3759) event: sta ip: 192.168.31.189, mask: 255.255.255.0, gw: 192.168.31.1
E (3769) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
E (3779) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
mqtt_main|124 :: mqtt example
E (3789) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
E (3799) wrapper_product: NVS Flash init fctry failed, Please check that you have flashed fctry partition!!!
[err] IOT_MQTT_Construct(395): Invalid product key, abort!
mqtt_main|227 :: MQTT construct failed
E (3819) FreeRTOS: FreeRTOS Task "mqtt_example" should not return, Aborting now!
abort() was called at PC 0x4008d1ff on core 1
0x4008d1ff: vPortTaskWrapper at D:/msys32/home/Administrator/esp/esp-idf/components/freertos/port.c:403
ELF file SHA256: f9c1359151487bb8ff8464aa8eb7edc45334155a65d2b46a6aacb7e9737a2209
Backtrace: 0x40086fe8:0x3ffc9250 0x40087235:0x3ffc9270 0x4008d1ff:0x3ffc9290
0x40086fe8: invoke_abort at D:/msys32/home/Administrator/esp/esp-idf/components/esp32/panic.c:715
0x40087235: abort at D:/msys32/home/Administrator/esp/esp-idf/components/esp32/panic.c:715
更多回帖
