乐鑫技术交流
直播中
李玉兰
7年用户 1499经验值
私信 关注
[问答]
在初始化ST7789并口驱动时,一直卡死了在了队列接收中怎么解决?
在初始化ST7789并口驱动时,一直卡死了在了队列接收中:ESP_LOGI("i2s_write_data","xQueueReceive start1") 和ESP_LOGI("i2s_write_data","xQueueReceive end1")之间的  xQueueReceive(i2s_lcd_obj->event_queue, (void *)&event, portMAX_DELAY)中
代码如下:
static void i2s_write_data(i2s_lcd_obj_t *i2s_lcd_obj, uint8_t *data, size_t len)
    int event  = 0;
    int x = 0, y = 0, left = 0, cnt = 0;
    if (len <= 0) {
        ESP_LOGE(TAG, "wrong len!");
        return;
    lcd_dma_set_int(i2s_lcd_obj);
    uint32_t half_buffer_size = i2s_lcd_obj->dma_half_buffer_size;
    cnt = len / half_buffer_size;
    // Start signal
    xQueueSend(i2s_lcd_obj->event_queue, &event, 0);
    // Process a complete piece of data, ping-pong operation
    for (x = 0; x < cnt; x++) {
        uint8_t *out = (uint8_t*)i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt].buf;
        uint8_t *in = data;
        if (i2s_lcd_obj->swap_data) {
            uint8_t *out1 = out + 1;
            uint8_t *in1 = in + 1;
            for (y = 0; y < half_buffer_size;) {
                out1[y] = in[y];
                out[y] = in1[y];
                y += 2;
                out1[y] = in[y];
                out[y] = in1[y];
                y += 2;
        } else {
            memcpy(out, in, half_buffer_size);
        data += half_buffer_size;
        xQueueReceive(i2s_lcd_obj->event_queue, (void *)&event, portMAX_DELAY);
        lcd_i2s_start(i2s_lcd_obj->i2s_dev, ((uint32_t)&i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt]) & 0xfffff, half_buffer_size);
    left = len % half_buffer_size;
    // Process remaining incomplete segment data
    if (left) {
        uint8_t *in  = data;
        cnt = left - left % 2;
        if (cnt) {
                for (y = 0; y < cnt; y+=2) {
                    out[y+1] = in[y+0];
                    out[y+0] = in[y+1];
            } else {
                memcpy(out, in, cnt);
        if (left % 2) {
            out[cnt] = in[cnt];
        lcd_dma_set_left(i2s_lcd_obj, x, left);
        lcd_i2s_start(i2s_lcd_obj->i2s_dev, ((uint32_t)&i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt]) & 0xfffff, left);
    ESP_LOGI("i2s_write_data","xQueueReceive start1");
    ESP_LOGI("i2s_write_data","xQueueReceive end1");
有没有遇到这种情况的啊?
更多回帖
