menuconfig 虽然能弹出来了 其他正常, 就方向键不好使,其实esc, s 空格都问题
环境 windows 10
idf.py menuconfig
Execu
ting action: menuconfig
Running ninja in directory d:codeesp32projbuild
Executing "ninja menuconfig"...
[0/1] Re-running CMake...
-- ccache will be used for faster recompilation
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
-- Project sdkconfig file D:/code/esp32/proj/sdkconfig
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- App "proj" version: 1
-- Adding linker script D:/code/esp32/proj/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script D:/tools/esp/esp-idf/components/esp_system/ld/esp32s3/sections.ld.in
-- Adding linker script D:/tools/esp/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.ld
-- Adding linker script D:/tools/esp/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.api.ld
-- Adding linker script D:/tools/esp/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.libgcc.ld
-- Adding linker script D:/tools/esp/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.newlib.ld
-- Adding linker script D:/tools/esp/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.version.ld
-- Adding linker script D:/tools/esp/esp-idf/components/soc/esp32s3/ld/esp32s3.peripherals.ld
-- Components: app_trace app_update asio bootloader bootloader_support bt cbor cmock coap console cxx driver efuse esp-tls esp32s3 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_ipc esp_lcd esp_local_ctrl esp_netif
esp_phy esp_pm esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos hal heap idf_test ieee802154 jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl openthread partition_table perfmon
protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter tinyusb ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: D:/tools/esp/esp-idf/components/app_trace D:/tools/esp/esp-idf/components/app_update D:/tools/esp/esp-idf/components/asio D:/tools/esp/esp-idf/components/bootloader D:/tools/esp/esp-idf/components/bootloader_support D:/tools/esp/esp-idf/components/bt D:/tools/esp/esp-idf/components/cbor D:/tools/esp/esp-idf/components/cmock D:/tools/esp/esp-idf/components/coap D:/tools/esp/esp-idf/components/console D:/tools/esp/esp-idf/components/cxx D:/tools/esp/esp-idf/components/driver D:/tools/esp/esp-idf/components/efuse D:/tools/esp/esp-idf/components/esp-tls D:/tools/esp/esp-idf/components/esp32s3 D:/tools/esp/esp-idf/components/esp_adc_cal D:/tools/esp/esp-idf/components/esp_common D:/tools/esp/esp-idf/components/esp_eth D:/tools/esp/esp-idf/components/esp_event D:/tools/esp/esp-idf/components/esp_gdbstub D:/tools/esp/esp-idf/components/esp_hid D:/tools/esp/esp-idf/components/esp_http_client D:/tools/esp/esp-idf/components/esp_http_server D:/tools/esp/esp-idf/components/esp_https_ota D:/tools/esp/esp-idf/components/esp_https_server D:/tools/esp/esp-idf/components/esp_hw_support D:/tools/esp/esp-idf/components/esp_ipc D:/tools/esp/esp-idf/components/esp_lcd D:/tools/esp/esp-idf/components/esp_local_ctrl D:/tools/esp/esp-idf/components/esp_netif D:/tools/esp/esp-idf/components/esp_phy D:/tools/esp/esp-idf/components/esp_pm D:/tools/esp/esp-idf/components/esp_ringbuf D:/tools/esp/esp-idf/components/esp_rom D:/tools/esp/esp-idf/components/esp_serial_slave_link D:/tools/esp/esp-idf/components/esp_system D:/tools/esp/esp-idf/components/esp_timer D:/tools/esp/esp-idf/components/esp_websocket_client D:/tools/esp/esp-idf/components/esp_wifi D:/tools/esp/esp-idf/components/espcoredump D:/tools/esp/esp-idf/components/esptool_py D:/tools/esp/esp-idf/components/expat D:/tools/esp/esp-idf/components/fatfs D:/tools/esp/esp-idf/components/freemodbus D:/tools/esp/esp-idf/components/freertos D:/tools/esp/esp-idf/components/hal D:/tools/esp/esp-idf/components/heap D:/tools/esp/esp-idf/components/idf_test D:/tools/esp/esp-idf/components/ieee802154 D:/tools/esp/esp-idf/components/jsmn D:/tools/esp/esp-idf/components/json D:/tools/esp/esp-idf/components/libsodium D:/tools/esp/esp-idf/components/log D:/tools/esp/esp-idf/components/lwip D:/code/esp32/proj/main D:/tools/esp/esp-idf/components/mbedtls D:/tools/esp/esp-idf/components/mdns D:/tools/esp/esp-idf/components/mqtt D:/tools/esp/esp-idf/components/newlib D:/tools/esp/esp-idf/components/nghttp D:/tools/esp/esp-idf/components/nvs_flash D:/tools/esp/esp-idf/components/openssl D:/tools/esp/esp-idf/components/openthread D:/tools/esp/esp-idf/components/partition_table D:/tools/esp/esp-idf/components/perfmon D:/tools/esp/esp-idf/components/protobuf-c D:/tools/esp/esp-idf/components/protocomm D:/tools/esp/esp-idf/components/pthread D:/tools/esp/esp-idf/components/sdmmc D:/tools/esp/esp-idf/components/soc D:/tools/esp/esp-idf/components/spi_flash D:/tools/esp/esp-idf/components/spiffs D:/tools/esp/esp-idf/components/tcp_transport D:/tools/esp/esp-idf/components/tcpip_adapter D:/tools/esp/esp-idf/components/tinyusb D:/tools/esp/esp-idf/components/ulp D:/tools/esp/esp-idf/components/unity D:/tools/esp/esp-idf/components/usb D:/tools/esp/esp-idf/components/vfs D:/tools/esp/esp-idf/components/wear_levelling D:/tools/esp/esp-idf/components/wifi_provisioning D:/tools/esp/esp-idf/components/wpa_supplicant D:/tools/esp/esp-idf/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: D:/code/esp32/proj/build
[0/1] cmd.exe /C "cd /D D:codeesp32projbuild && D:tools.espressifpython_envidf4.4_py3.8_envScriptspython.exe D:/tools/esp/esp-idf/tools/kconfig...ihub/sdkconfig --env-file D:/code/esp32/proj/build/config.env --env IDF_TARGET=esp32s3 --env IDF_ENV_
FPGA= --output config D:/code/esp32/proj/sdkconfig"D:/tools/esp/esp-idf/Kconfig:14: warning: IDF_ENV_FPGA has 'option env="IDF_ENV_FPGA"', but the environment variable IDF_ENV_FPGA is not set
Loaded configuration 'D:/code/esp32/proj/sdkconfig'
No changes to save (for 'D:/code/esp32/proj/sdkconfig')
