嵌入式技术论坛
直播中
发生的方式
9年用户 1325经验值
擅长:处理器/DSP
私信 关注
[问答]
怎么解决littlefs挂载第二个分区失败的问题呢?
首先是FAL能正常启动,根目录的分区也挂载正常。
[D/FAL] (fal_flash_init:61) Flash device |                coreboard | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish.
[D/FAL] (fal_flash_init:61) Flash device |                norflash0 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish.
[I/FAL] ==================== FAL partition table ====================
[I/FAL] | name       | flash_dev |   offset   |    length  |
[I/FAL] -------------------------------------------------------------
[I/FAL] | bootloader | coreboard | 0x00000000 | 0x00008000 |
[I/FAL] | app        | coreboard | 0x00008000 | 0x007f8000 |
[I/FAL] | littlefs   | coreboard | 0x00800000 | 0x00200000 |
[I/FAL] | download   | coreboard | 0x00a00000 | 0x00200000 |
[I/FAL] | fatfs      | coreboard | 0x00c00000 | 0x00300000 |
[I/FAL] | easyflash  | coreboard | 0x00f00000 | 0x00100000 |
[I/FAL] | file       | norflash0 | 0x00000000 | 0x01000000 |
[I/FAL] =============================================================
[I/FAL] RT-Thread Flash Abstraction Layer (V0.5.0) initialize success.
[I/FAL] The FAL MTD NOR device (littlefs) created successfully
[I/littlefs.sample] para initialized!
[I/FAL] The FAL MTD NOR device (download) created successfully
[E/littlefs.sample] Failed to initialize download!
[Flash] (packagesEasyFlash-v4.1.0srcef_env.c:1818) ENV start address is 0x00000000, size is 8192 bytes.
[Flash] EasyFlash V4.1.0 is initialize success.
[Flash] You can get the latest version on
挂载第一个分区后,新建目录,用于挂载download分区,但是挂载失败
int result = 0;
    #ifdef PKG_USING_FAL
        // 初始化 fal
        fal_init();
    #else
        return;
    #endif
    #ifdef PKG_USING_LITTLEFS
    #define LITTLEFS_PARTITION_NAME  "littlefs"
    struct rt_device *mtd_dev = RT_NULL;
    // 创建 mtd 设备
    mtd_dev = fal_mtd_nor_device_create(LITTLEFS_PARTITION_NAME);
    if (!mtd_dev)
        LOG_E("Can't create a mtd device on '%s' partition.", LITTLEFS_PARTITION_NAME);
    else
        // 挂载littlefs
        // 参数: 块设备名、文件系统挂载点路径,挂载文件系统类型,读写标志位,文件系统的私有数据
        if (dfs_mount(LITTLEFS_PARTITION_NAME, "/", "lfs", 0, 0) == 0)
            LOG_I("para initialized!");
        else
            /* 格式化文件系统 */
            dfs_mkfs("lfs", LITTLEFS_PARTITION_NAME);
            /* 挂载 littlefs */
                LOG_I("%s initialized!",LITTLEFS_PARTITION_NAME);
            else
                LOG_E("Failed to initialize %s!",LITTLEFS_PARTITION_NAME);
                result = -1;
    if(result == 0)
        #define LITTLEFS_PARTITION_NAME2 "download"
        mtd_dev = fal_mtd_nor_device_create(LITTLEFS_PARTITION_NAME2);
        if (!mtd_dev)
            LOG_E("Can't create a mtd device on '%s' partition.", LITTLEFS_PARTITION_NAME2);
        else
            if(opendir("/c") == RT_NULL)
               mkdir("c",0);
            if (dfs_mount(LITTLEFS_PARTITION_NAME2, "/c", "lfs", 0, 0) == 0)
                LOG_I("%s Filesystem initialized!",LITTLEFS_PARTITION_NAME2);
            else
                dfs_mkfs("lfs", LITTLEFS_PARTITION_NAME2);
                else
                    LOG_E("Failed to initialize %s!",LITTLEFS_PARTITION_NAME2);
    #endif
    #ifdef PKG_USING_EASYFLASH
    /* easyflash init */
        easyflash_init();
    #endif
mtd设备是正常创建的,
device           type         ref count
download MTD Device           0
littlefs MTD Device           1
norflash Block Device         0
adc1     Miscellaneous Device 0
pwm2     Miscellaneous Device 0
pwm1     Miscellaneous Device 0
刚开始使用文件系统,求大佬指导下,问题在哪。。
回帖(3)
万航渡路
2023-3-7 14:01:26
你单独挂载“download”分区试试可以用吗?
如果不可以就是“download”分区有问题,如果可以就可能是不能去挂载两个分区
举报
发生的方式
2023-3-7 14:01:33
先挂载download的话就可以,就是第二个挂不上去
举报
发生的方式
2023-3-7 14:01:39
原因找到了,是因为挂两个 lfs, RT_DEF_LFS_DRIVERS 的值为 1,导致挂两个 lfs 挂不上去。改成2就好了
举报
更多回帖
