乐鑫技术交流
直播中
英雄孤寂
13年用户 1280经验值
私信 关注
[问答]
idf.py monitor无法正常输出是怎么回事?
weilian@DESKTOP-MMQQ1CA:~/esp32s3_lvgl_480_86box_testdemo20230111$ idf.py -p /dev/ttyS19  monitor
Executing action: monitor
Running idf_monitor in directory /home/weilian/esp32s3_lvgl_480_86box_testdemo20230111
Executing "/home/weilian/.espressif/python_env/idf4.4_py3.10_env/bin/python /home/weilian/esp-idf-patch/tools/idf_monitor.py -p /dev/ttyS19 -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 /home/weilian/esp32s3_lvgl_480_86box_testdemo20230111/build/rgb_panel.elf -m '/home/weilian/.espressif/python_env/idf4.4_py3.10_env/bin/python' '/home/weilian/esp-idf-patch/tools/idf.py' '-p' '/dev/ttyS19'"...
--- idf_monitor on /dev/ttyS19 115200 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
Build:Mar 27 2021
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xa (SPI_FAST_FLASH_BOOT)
Saved PC:0x4201dfd2
0x4201dfd2: lv_color_mix_premult at /home/weilian/esp32s3_lvgl_480_86box_testdemo20230111/components/lvgl/src/draw/sw/../../misc/lv_color.h:502
(inlined by) fill_normal at /home/weilian/esp32s3_lvgl_480_86box_testdemo20230111/components/lvgl/src/draw/sw/lv_draw_sw_blend.c:257
(inlined by) lv_draw_sw_blend_basic at /home/weilian/esp32s3_lvgl_480_86box_testdemo20230111/components/lvgl/src/draw/sw/lv_draw_sw_blend.c:159
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x17c0
load:0x403c9700,len:0xe64
load:0x403cc700,len:0x2fec
entry 0x403c9980
I (24) boot: ESP-IDF 5842acfb-dirty 2nd stage bootloader
I (25) boot: compile time 19:41:54
I (25) boot: chip revision: 0
I (27) qio_mode: Enabling default flash chip QIO
I (32) boot.esp32s3: Boot SPI Speed : 80MHz
I (37) boot.esp32s3: SPI Mode       : QIO
I (42) boot.esp32s3: SPI Flash Size : 16MB
I (46) boot: Enabling RNG early entropy source...
I (52) boot: Partition Table:
I (55) boot: ## Label            Usage          Type ST Offset   Length
I (63) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (70) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (78) boot:  2 factory          factory app      00 00 00010000 00100000
I (85) boot: End of partition table
I (89) esp_image: segment 0: paddr=00010020 vaddr=3c050020 size=25c60h (154720) map
I (121) esp_image: segment 1: paddr=00035c88 vaddr=3fc98030 size=0348ch ( 13452) load
I (124) esp_image: segment 2: paddr=0003911c vaddr=40378000 size=06efch ( 28412) load
I (132) esp_image: segment 3: paddr=00040020 vaddr=42000020 size=4c030h (311344) map
I (183) esp_image: segment 4: paddr=0008c058 vaddr=4037eefc size=0912ch ( 37164) load
I (190) esp_image: segment 5: paddr=0009518c vaddr=50000000 size=00010h (    16) load
I (197) boot: Loaded app from partition at offset 0x10000
I (197) boot: Disabling RNG early entropy source...
W (211) FLASH: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version.
I (212) opi psram: vendor id : 0x0d (AP)
I (215) opi psram: dev id    : 0x02 (generation 3)
I (220) opi psram: density   : 0x03 (64 Mbit)
I (225) opi psram: good-die  : 0x01 (Pass)
I (230) opi psram: Latency   : 0x01 (Fixed)
I (235) opi psram: VCC       : 0x01 (3V)
I (239) opi psram: SRF       : 0x01 (Fast Refresh)
I (245) opi psram: BurstType : 0x01 (Hybrid Wrap)
I (250) opi psram: BurstLen  : 0x01 (32 Byte)
I (255) opi psram: Readlatency  : 0x02 (10 cycles@Fixed)
I (261) opi psram: DriveStrength: 0x00 (1/1)
W (266) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version.
到这一步就没有动静了,WLS下ubuntu20.4+idf4.4.2
更多回帖
