乐鑫技术交流
直播中
申换换
8年用户 1578经验值
私信 关注
[问答]
请问一下MQTT_topic_t 结构在哪里呢?
这是我的代码:
代码:
int mqtt_publish(char message[])
        int msg_id = 0;
    ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
    mqtt_topic_t *mqtt_topic = get_mqtt_topic();
    msg_id = esp_mqtt_client_publish(client,mqtt_topic->topic, message, 0, 1, 0);
    ESP_LOGI(TAG, "sent publish successful, msg_id=%d", msg_id);
    return msg_id;
mqtt_topic_t 结构在哪里:
代码:
typedef struct mqtt_topic {
        char topic[200];
} mqtt_topic_t;
我正在从 HTTP 服务器发布请求中保存 MQTT 主题,如下所示:
代码:
esp_err_t echo_post_handler(httpd_req_t *req)
        nvs_handle handle;
        esp_err_t esp_err;
    char buf[200];
    int ret, remaining = req->content_len;
    if(topic_rcvd == 0){
               ESP_LOGI(TAG, "TOPIC RECVD IS 0");
    while (remaining > 0) {
        /* Read the data for the request */
        if ((ret = httpd_req_recv(req, buf,
                        MIN(remaining, sizeof(buf)))) <= 0) {
            if (ret == HTTPD_SOCK_ERR_tiMEOUT) {
                /* Retry receiving if timeout occurred */
                continue;
            return ESP_FAIL;
        /* Send back the same data */
        httpd_resp_send_chunk(req, buf, ret);
        remaining -= ret;
        /* Log data received */
        ESP_LOGI(TAG, "=========== RECEIVED DATA ==========");
        ESP_LOGI(TAG, "%.*s", ret, buf);
        ESP_LOGI(TAG, "====================================");
        http_server_send_message(HTTP_MSG_RECVD_TOPIC);
        topic_rcvd = 1;
    esp_err_t request_sent = httpd_resp_send_chunk(req, NULL, 0);
    // End response
            esp_err = nvs_open(mqtt_client, NVS_READWRITE, &handle);
            if (esp_err != ESP_OK)
                        printf("Error in Saving (%s) n", esp_err_to_name(esp_err));
                        return esp_err;
                //Set TOPIC
                esp_err = nvs_set_blob(handle, "topic", buf, 200);
                        printf("Error setting SSID (%s) n", esp_err_to_name(esp_err));
                        return esp_err;
                esp_err = nvs_commit(handle);
                        printf("Error setting TOPIC to NVS (%s) n", esp_err_to_name(esp_err));
                        return esp_err;
                nvs_close(handle);
                ESP_LOGI(TAG, "SAVED TOPIC %s", buf);
    return ESP_OK;
像这样从内存中加载 MQTT 主题:
代码:
bool load_mqtt_topic(void){
        nvs_handle handle;
        esp_err_t esp_err;
        ESP_LOGI(TAG, "Loading MQTT Client from Flash");
        if (nvs_open(mqtt_client, NVS_READONLY, &handle) == ESP_OK)
                mqtt_topic_t *topic = get_mqtt_topic();
                if(topic == NULL)
                        topic = (char*)malloc(sizeof(mqtt_topic_t));
                memset(topic, 0x00, sizeof(mqtt_topic_t));
                size_t mqtt_size = sizeof(mqtt_topic_t);
                uint8_t *mqtt_buff = (uint8_t*)malloc(sizeof(mqtt_topic_t));
                memset(mqtt_buff, 0x00, sizeof(mqtt_topic_t));
                //LOAD SSID
                esp_err = nvs_get_blob(handle, "topic", mqtt_buff, &mqtt_size);
                if(esp_err != ESP_OK)
                        free(mqtt_buff);
                        printf("NO MQTT CLIENT FOUND n");
                        return false;
                memcpy(topic, mqtt_buff, mqtt_size);
                free(mqtt_buff);
                nvs_close(handle);
                printf("TOPIC %s", topic->topic);
                return topic->topic[0] != '';
        else
                return false;
当我在按下按钮时调用 mqtt_publish 消息时:
代码:
                                ESP_LOGI(TAG, "Button Press");
                                printf("Message Published: %d", mqtt_publish("false"));
该函数返回以下内容:
E (15511) MQTT_CLIENT: 无法创建发布消息
I (15514) MQTT_EXAMPLE: 发送发布成功,msg_id=-1
如果我将 mqtt_publish 更改为:
代码:
msg_id = esp_mqtt_client_publish(client,"Trial Topic", message, 0, 1, 0);
然后它工作正常。所以似乎是 mqtt_topic->topic 导致了这个问题。
可能是 mqtt_topic->topic 变量不是字符串,但我不知道如何解决这个问题。将不胜感激任何帮助。
回帖(1)
李伟
2023-3-2 13:52:26
在发布之前打印主题值怎么样?
您还应该检查 strlen,因为可能有一些不可打印的字符。
举报
更多回帖
