乐鑫技术交流
直播中
北冥有熊
9年用户 993经验值
擅长:131594
私信 关注
[问答]
http库中nest_api的https问题如何解决?
我正在尝试使用 http.get() 从我的恒温器获取数据,但我总是收到错误 307(重定向)。我开始认为它与我尝试连接的 https 网址有关。
有没有人遇到过类似的问题,或者知道如何解决下面的问题?
在此先感谢
这是我的代码,在最后一部分中,您可以看到我正在尝试建立的与服务器的连接:
代码:全选#include
#include
#include
#include
#define USE_SERIAL Serial
String accessurl = "https://api.home.nest.com/oauth2/access_token";
MDNSResponder mdns;
// My Network cred.
const char* ssid = "Blanked out";
const char* password = "Blanked out";
int gpio13Led = 13;
int gpio12Relay = 12;
void setup(void){
// preparing GPIOs
pinMode(gpio13Led, OUTPUT);
digitalWrite(gpio13Led, HIGH);
pinMode(gpio12Relay, OUTPUT);
digitalWrite(gpio12Relay, HIGH);
Serial.begin(115200);
delay(5000);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
void loop(void){
Serial.println("Wifi Up - Test Start!");
delay(10000);
if((WiFi.status() != WL_CONNECTED)) {
Serial.println("wifi down");
return;
HTTPClient http;
//Here I gave the footprint along with the url. But I'm not sure if it works.
http.begin("https://developer-api.nest.com/", "87:CB:F2:E6:44:C0:AA:F2:4C:28:B2:97:85:70:18:92:45:1B:A4:57");
//http.addHeader("Cache-Control", "no-cache", true, true);
//http.addHeader("Postman-Token", "419da1fa-6070-3338-c215-8be740891136", true, true);
http.addHeader("Authorization", "Bearer c.blanked out", true, true);
http.addHeader("Host", "developer-api.nest.com", true, true);
http.addHeader("Content-Type", "application/json", false, true);
int httpCode = http.GET();
Serial.println("request sent: n");
Serial.println(httpCode); //Doesn't seem to work? I never see any outprint.
if (httpCode == HTTP_CODE_OK) {
   String payload = http.getString();
   Serial.printf("[HTTP] GET response: %s", payload.c_str());
} else {
   String loc = http.header("Location");
   Serial.printf("[HTTP] GE returned %d. kapot, error: %s; response: %s, new location: %sn", httpCode, http.errorToString(httpCode).c_str(), payload.c_str(), loc.c_str());
http.end();
更多回帖
