乐鑫技术交流
直播中
百合子
9年用户 984经验值
擅长:控制/MCU
私信 关注
[问答]
WeMos D1 mini和旋转编码器KY-040一起使用,不起作用的原因是什么?
我正在尝试采用下面的草图与我的 WeMos D1 mini 和众所周知的旋转编码器 KY-040 一起使用,但由于某种原因它不起作用,但相同的草图在 Arduino Uno 上运行良好(与不同的引脚分配)。
有人能告诉我草图有什么问题吗?
谢谢你!
代码:全选const int PinA = 14; // Used for generating interrupts using CLK signal
const int PinB = 12; // Used for reading DT signal
const int PinSW = 13; // Used for the push button switch
int lCnt = 0; // Keep track of last rotary value
volatile int vPos = 0; // Updated by the ISR (Interrupt Service Routine)
void isr_event ()  {
  static unsigned long lIsrTmr = 0; // Last Interrupt time
  unsigned long IsrTmr = millis(); // Interrupt time
  // If interrupts come faster than 5ms, assume it's a bounce and ignore
  if (IsrTmr - lIsrTmr > 5) {
    if (digitalRead(PinB) == LOW)
      vPos++ ; // Could be +5 or +10
    else {
      vPos-- ; // Could be -5 or -10
    // Restrict value from 0 to +100
    vPos = min(10, max(0, vPos));
    // Keep track of when we were here last (no more than every 5ms)
    lIsrTmr = IsrTmr;
void setup()
  Serial.begin(9600);
  // Rotary pulses are INPUTs
  pinMode(PinA, INPUT);
  pinMode(PinB, INPUT);
  pinMode(PinSW, INPUT_PULLUP); // Switch is floating so use the in-built PULLUP so we don't need a resistor
  attachInterrupt(digitalPinToInterrupt(PinA), isr_event, LOW); // Attach the routine to service the interrupts
  Serial.println(F("Starting..."));  // Ready to go!
void loop()
  // Is someone pressing the rotary switch?
  if ((!digitalRead(PinSW))) {
    vPos = 0;
    while (!digitalRead(PinSW))
      delay(10);
  // If the current rotary switch position has changed then update everything
  if (vPos != lCnt) {
    // Write out to serial monitor the value and direction
    Serial.println(vPos);
    // Keep track of this new value
    lCnt = vPos ;
更多回帖
