乐鑫技术交流
直播中
吴湛
10年用户 1016经验值
擅长:可编程逻辑
私信 关注
[问答]
ESP停止解析JSON,堆内存越来越小的原因?
您好,
我正在尝试使用 twitter api 库或任何其他社交媒体 api 来接收统计信息。
一开始一切似乎都很好,但在某些时候它停止接收 json 消息。它发生在不同的请求中,而不仅仅是推特(Facebook 等)。
我已经检查过是否存在 RAM 问题,似乎每次有请求时,堆 RAM 都会变得越来越小,以至于它不再解析。我还检查了 ESP 是否已断开连接但它保持连接。
我也尝试过使用 StaticjsonBuffer 并清除 jsonbuffer 但它没有改变。
这是我的代码:
代码:全选#include
*  An Example of getting data back from the TwitterAPI            *
*  https://github.com/witnessmenow/arduino-twitter-api            *
*  Written by Brian Lough                                         *
#include
#include
//------- Replace the following! ------
char ssid[] = "ssss";       // your network SSID (name)
char password[] = "kkkkk";  // your network key
// Normally we would use these to generate the bearer token but its not working yet :/
// Use steps on the readme to generate the Bearer Token
#define BEARER_TOKEN "zzzzz"
//Using curl to get bearer token
// curl -u "$CONSUMER_KEY:$CONSUMER_SECRET"
//    --data 'grant_type=client_credentials'
//    'https://api.twitter.com/oauth2/token'
WiFiClientSecure client;
TwitterApi api(client);
unsigned long api_mtbs = 5000; //mean time between api requests
unsigned long api_lasttime = 0;   //last time api request has been done
bool firstTime = true;
//Inputs
String screenName = "xxx";
bool haveBearerToken = false;
void setup() {
  Serial.begin(115200);
  // Set WiFi to station mode and disconnect from an AP if it was Previously
  // connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  // Attempt to connect to Wifi network:
  Serial.print("Connecting Wifi: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
    delay(500);
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  IPAddress ip = WiFi.localIP();
  Serial.println(ip);
  Serial.printf("Internal Total heap %d, internal Free Heap %dn",ESP.getHeapSize(),ESP.getFreeHeap());
  Serial.printf("SPIRam Total heap %d, SPIRam Free Heap %dn",ESP.getPsramSize(),ESP.getFreePsram());
  api.setBearerToken(BEARER_TOKEN);
  haveBearerToken = true;
  getTwitterStats(screenName);
//   uint8_t* ps=(byte *)ps_malloc(900000);
void getTwitterStats(String name) {
  Serial.println("Getting twitter stats for " + name);
  String responseString = api.getUserStatistics(name);
    Serial.println(responseString);
    DynamicJsonBuffer jsonBuffer;
    JsonObject& response = jsonBuffer.parseObject(responseString);
    if (response.success()) {
      Serial.println("parsed Json");
      // Use Arduino Json to parse the data
      int followerCount = response["followers_count"];
      Serial.println(followerCount);
    } else {
      Serial.println("Failed to parse Json");
void loop() {
  if(haveBearerToken){
    if ((millis() > api_lasttime + api_mtbs))  {
      api_lasttime = millis();
      if (WiFi.status() == WL_CONNECTED) {
        Serial.println("Still connected");
这是我在串行监视器中得到的:
代码:全选Connecting Wifi: sssss
WiFi connected
IP address:
192.168.1.xxx
Internal Total heap 337244, internal Free Heap 282376
SPIRam Total heap 4194116, SPIRam Free Heap 4190924
Getting twitter stats for xxxx
{"......very long Json......."}
parsed Json
219
Internal Total heap 336328, internal Free Heap 234060
SPIRam Total heap 4194100, SPIRam Free Heap 4190788
ps=0x3f801288
Internal Total heap 336900, internal Free Heap 247180
SPIRam Total heap 4194084, SPIRam Free Heap 3290772
Still connected
parsed Json
219
Internal Total heap 336148, internal Free Heap 199752
Still connected
Internal Total heap 336764, internal Free Heap 213076
Still connected
parsed Json
219
Internal Total heap 336040, internal Free Heap 165672
Still connected
Internal Total heap 335664, internal Free Heap 63468
Still connected
Internal Total heap 336192, internal Free Heap 76104
Still connected
Internal Total heap 336196, internal Free Heap 76096
Still connected
Internal Total heap 336156, internal Free Heap 75676
Still connected
Getting twitter stats for xxxxx
Internal Total heap 336160, internal Free Heap 75668
Still connected
按照Arduino JSON小助手的说法,JSON报文的大小是:
ESP32/ESP8266 1464+1994 = 3458 Bytes
真不知道还能做什么。Arduino 的 instagram 库工作正常,但它使用 JsonStreamingParser.h。是否可以改用该库?它会改变结果吗?
看起来一旦内部空闲堆 RAM 达到 7000 左右,它就不再工作了。
我也每 5 秒调用一次该函数。我试图增加时间,但似乎在某些时候发生了同样的事情。Free Heap RAM 似乎也增加了一点。
谢谢
更多回帖
