瑞萨单片机论坛
直播中
花开月夜时
3年用户 448经验值
擅长:可编程逻辑
私信 关注
[资料]
【RA4M2设计挑战赛】+驱动温湿度传感器
软件要求:fsp_v4.2.0、keil5
1.生成基本程序
选择是否使用实时系统,本次不使用
完后后,见下图
2.更改时钟源
3.配置串口
修改debug参数
返回配置串口
4.配置I2C
5.生成基础程序
6.连接模块与开发板
7.建立 inc 文件夹存放.h文件
keil5中建立hs3003.c、hs3003.h、uart.c、uart.h
.h文件存放在inc中,.c文件存放在src中
建立.h编译路径
.c添加进keil
hs3003.c
#include "hs3003.h"
#include "stdio.h"
/* See Developer Assistance in the project */
void g_comms_i2c_bus0_quick_setup(void);
void g_hs300x_sensor0_quick_setup(void);
void start_demo(void);
static void demo_err(void);
static volatile hs3003_callback_status_t  hs3003_callback_status;
    fsp_err_t err;
    err = R_SCI_I2C_Open(&hs3003_i2c_ctrl, &hs3003_i2c_cfg);
    assert(FSP_SUCCESS == err);
void hs3003_i2c_callback(i2c_master_callback_args_t * p_args)
	  if (HS3003_CALLBACK_STATUS_SUCCESS == p_args->event)
        hs3003_callback_status = HS3003_CALLBACK_STATUS_SUCCESS;
    else
        hs3003_callback_status = HS3003_CALLBACK_STATUS_REPEAT;
void start_hs3003(void)
	fsp_err_t err;
	uint8_t r_buf[4] = {0};
	uint16_t humi, temp;
	float tmp_f = 0.0;
	uint8_t data[2] = {0x00,0x00};
	demo_sequence_t sequence = DEMO_SEQUENCE_1;
	g_comms_i2c_bus0_quick_setup();
	while(1)
		err = R_SCI_I2C_Write(&hs3003_i2c_ctrl,data,1,0);
		R_BSP_SoftwareDelay(40000,BSP_DELAY_UNITS_MICROSECONDS);
		err = R_SCI_I2C_Read(&hs3003_i2c_ctrl,&r_buf,4,1);
		if(err == FSP_SUCCESS)
//        printf("0x%X,0x%X,0x%X,0x%X\n", r_buf[0], r_buf[1], r_buf[2], r_buf[3]);
//        printf("state:%x\n", r_buf[0] & RM_HS300X_MASK_STATUS_0XC0);
        if ((r_buf[0] & RM_HS300X_MASK_STATUS_0XC0) != RM_HS300X_DATA_STATUS_VALID)
            printf("ת»»Ê±¼ä²»¶ß");
        humi = (r_buf[0] & RM_HS300X_MASK_HUMIDITY_UPPER_0X3F) << 8 | r_buf[1];
        temp = (r_buf[2] << 8 | (r_buf[3] & RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC)) >> 2;
        tmp_f = (float)humi;
        tmp_f = (tmp_f * RM_HS300X_CALC_HUMD_VALUE_100) / RM_HS300X_CALC_STATIC_VALUE;
				printf("ʪ¶È: %.2f\n",tmp_f );
        tmp_f = (float)temp;
        tmp_f = ((tmp_f * RM_HS300X_CALC_TEMP_C_VALUE_165) / RM_HS300X_CALC_STATIC_VALUE) - RM_HS300X_CALC_TEMP_C_VALUE_40;
				printf("ζÈ: %.2f\n", tmp_f);
    else {
        printf("¶ÁÈ¡´«¸ÐÆ÷³ö´í!\n");
		R_BSP_SoftwareDelay(1000000,BSP_DELAY_UNITS_MICROSECONDS);
hs3003.h
#ifndef __HS3003_H
#define __HS3003_H
#include "hal_data.h"
/* Sequence */
typedef enum e_demo_sequence
    DEMO_SEQUENCE_1 = (1),
    DEMO_SEQUENCE_2,
    DEMO_SEQUENCE_3,
    DEMO_SEQUENCE_4,
    DEMO_SEQUENCE_5,
    DEMO_SEQUENCE_6,
} demo_sequence_t;
/* Callback status */
typedef enum e_hs3003_callback_status
    HS3003_CALLBACK_STATUS_WAIT = (0),
    HS3003_CALLBACK_STATUS_SUCCESS,
    HS3003_CALLBACK_STATUS_REPEAT,
} hs3003_callback_status_t;
#define SENSOR_TEMP_RANGE_MAX (80)
#define SENSOR_TEMP_RANGE_MIN (-10)
#define SENSOR_HUMI_RANGE_MAX (100)
#define SENSOR_HUMI_RANGE_MIN (0)
/* Definitions of Mask Data for A/D data */
#define RM_HS300X_MASK_HUMIDITY_UPPER_0X3F       (0x3F)
#define RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC    (0xFC)
#define RM_HS300X_MASK_STATUS_0XC0               (0xC0)
/* Definitions for Status Bits of A/D Data */
#define RM_HS300X_DATA_STATUS_VALID              (0x00) // Status-bit: Valid data
/* Definitions for Calculation */
#define RM_HS300X_CALC_STATIC_VALUE              (16383.0F)
#define RM_HS300X_CALC_HUMD_VALUE_100            (100.0F)
#define RM_HS300X_CALC_TEMP_C_VALUE_165          (165.0F)
#define RM_HS300X_CALC_TEMP_C_VALUE_40           (40.0F)
#define RM_HS300X_CALC_DECIMAL_VALUE_100         (100.0F)
#define HS300X_ADR  0x44                        // look at datasheet
#define HS300X_TEMP_MULTY           0.010071415 // look at datasheet
#define HS300X_TEMP_MIN             40          // look at datasheet
#define HS300X_HUMD_MULTY           0.006163516 // look at datasheet
#define HS300X_MAX_ITERATION        100
#define HS300X_DELAY_MEASUREMENT    35          // typical on datasheet 16.90 ms, rounded up a little (35ms = 1 try)
#define HS300X_DELAY_ITERATION      1
#define HS300X_STALE_DATA           2
#define HS300X_OK                   1
#define HS300X_ERROR_SENSOR_BUSY    0
#define HS300X_ERROR_COLLISION_I2C  -1
void start_hs3003(void);
#endif
uart.c
#include "uart.h"
/* µ÷ÊÔ´®¿Ú UART4 ³õʼ»¯ */
void uart_init(void)
	fsp_err_t err = FSP_SUCCESS;
	err = R_SCI_UART_Open (&g_uart0_ctrl, &g_uart0_cfg);
/* ·¢ËÍÍê³É±êÖ¾ */
volatile bool uart_send_complete_flag = false;
/* ´®¿ÚÖжϻص÷ */
void g_uart0_callback (uart_callback_args_t * p_args)
	switch (p_args->event)
		case UART_EVENT_RX_CHAR:
		/* °Ñ´®¿Ú½ÓÊÕµ½µÄÊý¾Ý·¢ËÍ»ØÈ¥ */
		R_SCI_UART_Write(&g_uart0_ctrl, (uint8_t *)&(p_args->data), 1);
		break;
		case UART_EVENT_TX_COMPLETE:
		uart_send_complete_flag = true;
		break;
		default:
		break;
/* Öض¨Ïò printf Êä³ö */
#if defined __GNUC__ && !defined __clang__
int _write(int fd, char *pBuffer, int size); //·ÀÖ¹±àÒ뾯¸æ
	(void)fd;
	R_SCI_UART_Write(&g_uart0_ctrl, (uint8_t *)pBuffer, (uint32_t)size);
	while(uart_send_complete_flag == false);
	return size;
#else
int fputc(int ch, FILE *f)
	(void)f;
	R_SCI_UART_Write(&g_uart0_ctrl, (uint8_t *)&ch, 1);
	return ch;
#endif
uart.h
#ifndef __BSP_UART_H__
#define __BSP_UART_H__
#include "stdio.h"
void uart_init(void);
#endif
hal_entry.c
#include "uart.h"
#include "hs3003.h"
FSP_CPP_HEADER
void R_BSP_WarmStart(bsp_warm_start_event_t event);
FSP_CPP_FOOTER
 * main() is generated by the RA Configuration editor and is used to generate threads if an RTOS is used.  This function
 * is called by main() when no RTOS is used.
void hal_entry(void)
    /* TODO: add your own code here */
		uart_init();
		start_hs3003();
#if BSP_TZ_SECURE_BUILD
    /* Enter non-secure code */
    R_BSP_NonSecureEnter();
#endif
 * This function is called at various points during the startup process.  This implementation uses the event that is
 * called right before main() to set up the pins.
 * @param[in]  event    Where at in the start up process the code is currently at
void R_BSP_WarmStart (bsp_warm_start_event_t event)
    if (BSP_WARM_START_RESET == event)
#if BSP_FEATURE_FLASH_LP_VERSION != 0
        /* Enable reading from data flash. */
        R_FACI_LP->DFLCTL = 1U;
        /* Would normally have to wait tDSTOP(6us) for data flash recovery. Placing the enable here, before clock and
         * C runtime initialization, should negate the need for a delay since the initialization will typically take more than 6us. */
#endif
    if (BSP_WARM_START_POST_C == event)
        /* C runtime environment and system clocks are setup. */
        /* Configure pins. */
        R_IOPORT_Open(&g_ioport_ctrl, g_ioport.p_cfg);
BSP_CMSE_NONSECURE_ENTRY void template_nonsecure_callable ();
/* Trustzone Secure Projects require at least one nonsecure callable function in order to build (Remove this if it is not required to build). */
#endif
8.下载程序
设置下载地址
设置完成后下载程序
9.运行效果
更多回帖
