有时,网络服务器会卡在新客户端上,并且不会断开连接。
代码:
全选#include
#include
Servo servo1;
int pinservo = D2;
int pulsomin = 1000;
int pulsomax = 2000;
const char* ssid = "Manuela";
const char* password = "manuel34068833";
int ledPin = D4;
WiFiServer server(80);
void setup() {
Serial.begin(115200);
delay(10);
servo1.attach(pinservo,pulsomin,pulsomax);
servo1.write(50);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL : ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
void loop() {
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(100);
// Read the first line of the request
String request = client.readStringUntil('r');
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("Abrir") != -1) {
digitalWrite(ledPin, HIGH);
value = HIGH;
servo1.write(39);
delay(400);
servo1.write(50);
if (request.indexOf("AbrirYcerrar") != -1){
value = LOW;
servo1.write(39);
delay(400);
servo1.write(50);
delay(55000);
servo1.write(39);
delay(400);
servo1.write(50);
// Return the response
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("");
client.println("");
client.println("");
client.println("
client.println("Clickea ACA Para abrir el porton
client.println("");
delay(100);
Serial.println("Client disconnected");
Serial.println("");
