乐鑫技术交流
直播中
张宇
8年用户 1755经验值
私信 关注
[问答]
ESP8266如何连接到PLC?
你好呀!
我有一个带有以太网屏蔽 (W5100) 的 Arduino UNO,代码如下,用于从我的 PLC 读取数据
代码:全选#include
#include
#include "Settimino.h"
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //MAC
IPAddress ip(192,168,127,14); // Local Address
IPAddress PLC(192,168,127,110);   // PLC Address
S7Client Client;
void setup()
    Serial.begin(9600);
     while (!Serial) {
      ; // wait for serial port to connect. Needed for Leonardo only
    // Start the Ethernet Library
    Ethernet.begin(mac, ip);
    delay(200);
    Serial.println(Ethernet.localIP());
bool Connect()
    int Result=Client.ConnectTo(PLC,
                                  0,  // Rack (see the doc.)
                                  0); // Slot (see the doc.)
    Serial.print("Connecting to ");Serial.println(PLC);
    if (Result==0)
      Serial.print("Connected ! PDU Length = ");
      Serial.println(Client.GetPDULength());
    else
      Serial.println("Connection error");
    return Result==0;
void CheckError(int ErrNo)
  Serial.print("Error No. 0x");
  Serial.println(ErrNo, HEX);
  // Checks if it's a Severe Error => we need to disconnect
  if (ErrNo & 0x00FF)
    Serial.println("SEVERE ERROR, disconnecting.");
    Client.Disconnect();
byte Empfangen(int Zeile)     //einzelne Bytes empfangen
  int Result;
  byte Receive;
  // Verbinden
  while (!Client.Connected)
    if (!Connect())
      delay(500);
  Result=Client.ReadArea(S7AreaDB, //DB Zugriff
                         53,        // DB Number = 53
                         Zeile,        // Start ab Byte x
                         1,     // Anzahl der Bytes
                         &Receive);  // Ziel
  if (Result==0)
    return Receive;
  else
    CheckError(Result);
void loop()
  Serial.print("Daten aus SPS: ");
  Serial.println(Empfangen(20));   //Lese Byte aus DB Zeile 20
  Serial.println("");
  delay(500);
更多回帖
