乐鑫技术交流
直播中
王芳
8年用户 1481经验值
私信 关注
[问答]
esp32s2利用nvs存储blob出现乱码是怎么回事?如何解决?
我想利用NVS存储WiFi列表,定义了结构体如下:
typedef struct _wifi_conf wifi_conf_struct;
struct _wifi_conf
        char *ssid;
        char *password;
typedef struct  _wifi_conf_node_t wifi_conf_node_t;
        wifi_conf_struct item;
        wifi_conf_node_t *p;
typedef struct _wifi_conf_link_t wifi_conf_link_t;
        wifi_conf_node_t *np;
        int length;
NVS存储函数:
esp_err_t nvs_write_data_to_flash_in_main(wifi_conf_link_t *wifi_conf_list_link)
    //ESP_ERROR_CHECK(nvs_flash_erase());
    nvs_handle handle;
    size_t wifi_conf_size = 0;
    int list_cont = wifi_conf_list_link->length;
    struct _wifi_conf_node_t *tmp = wifi_conf_list_link->np;
    struct _wifi_conf wifi_conf_list[list_cont];
    int i = 0;
    while (i < list_cont)
        wifi_conf_list = tmp->item;
        wifi_conf_size = wifi_conf_size + sizeof(tmp->item);
        tmp = tmp->p;
        i++;
    ESP_ERROR_CHECK(nvs_open(NVS_CUSTOMER, NVS_READWRITE, &handle));
    ESP_ERROR_CHECK(nvs_set_i32(handle, DATA_KEY_2, list_cont));
    ESP_ERROR_CHECK(nvs_set_blob(handle, DATA_KEY_1, wifi_conf_list, wifi_conf_size));
    ESP_ERROR_CHECK(nvs_commit(handle));
    // free(wifi_conf_list);
    // free(tmp);
    printf("NVS_WRITE:存储wifi信息完毕n");
    nvs_close(handle);
    return ESP_OK;
NVS读取函数:
struct _wifi_conf_link_t nvs_read_data_from_flash_in_main(void)
struct _wifi_conf_link_t wifi_conf_list_link_read = {NULL, 0};
    nvs_handle handle;
    int32_t value = 0;
    esp_err_t err = nvs_open(NVS_CUSTOMER, NVS_READWRITE, &handle);
    if (err != ESP_OK)
        printf("Error (%s) opening NVS handle!n", esp_err_to_name(err));
    else
        printf("Donen");
        // Read
        printf("Reading restart counter from NVS ... ");
        err = nvs_get_i32(handle, DATA_KEY_2, &value);
        switch (err)
        case ESP_OK:
            printf("Donen");
            printf("Restart counter = %dn", value);
            break;
        case ESP_ERR_NVS_NOT_FOUND:
            printf("The value is not initialized yet!n");
            break;
        default:
            printf("Error (%s) reading!n", esp_err_to_name(err));
    if (value == 0)
        return wifi_conf_list_link_read;
    struct _wifi_conf wifi_conf_list[value];
    size_t required_size = 0; // value will default to 0, if not set yet in NVS
    nvs_get_blob(handle, DATA_KEY_1, NULL, &required_size);
    ESP_ERROR_CHECK(nvs_get_blob(handle, DATA_KEY_1, &wifi_conf_list, &required_size));
    nvs_close(handle);
    for (int i = 0; i < value; i++)
        wifi_conf_link_add(&wifi_conf_list_link_read, wifi_conf_list);
        //printf("%srn",wifi_conf_list.ssid);
问题来了:
    wifi_conf_struct tmp = {"yangyanghome24", "abcd1234"};//重点
    wifi_conf_link_del_all(&m_wifi_conf_link_main);
    wifi_conf_link_add(&m_wifi_conf_link_main, tmp);
    nvs_write_data_to_flash(&m_wifi_conf_link_main);
重启后,NVS读取正常,但是:
                        const char* pwd_selected_const = lv_textarea_get_text(textarea_pswd);
                        int nLen = strlen(pwd_selected_const);
                        char* pCh = (char*)malloc(sizeof(pwd_selected_const));
                        memcpy(pCh, pwd_selected_const, nLen + 1);
wifi_conf_struct scan_seleced_wifi_conf = {"splite_ssid_",pCh};//重点
重启后,读取出现乱码!!求帮助,困扰好长时间了。
更多回帖
