乐鑫技术交流
直播中
半导体开发
11年用户 920经验值
擅长:可编程逻辑
私信 关注
[问答]
使用ethernetLan8720进行以太网运行报错是怎么回事?
void EtherneTaskStart(void)
//        sem_tcp_ok = xSemaphoreCreateBinary();
    esp_netif_config_t cfg = ESP_NETIF_DEFAULT_ETH();
        esp_netif_t *eth_netif = esp_netif_new(&cfg);
        // Set default handlers to process TCP/IP stuffs
        ESP_ERROR_CHECK(esp_eth_set_default_handlers(eth_netif));
        // Register user defined event handers
        ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ESP_EVENT_ANY_ID, ð_event_handler, NULL));
        ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &got_ip_event_handler, NULL));
        eth_mac_config_t mac_config = ETH_MAC_DEFAULT_CONFIG();
        eth_phy_config_t phy_config = ETH_PHY_DEFAULT_CONFIG();
        phy_config.phy_addr = CONFIG_EXAMPLE_ETH_PHY_ADDR;
        phy_config.reset_gpio_num = CONFIG_EXAMPLE_ETH_PHY_RST_GPIO;
#if CONFIG_EXAMPLE_USE_INTERNAL_ETHERNET
        mac_config.smi_mdc_gpio_num = CONFIG_EXAMPLE_ETH_MDC_GPIO;
        mac_config.smi_mdio_gpio_num = CONFIG_EXAMPLE_ETH_MDIO_GPIO;
        esp_eth_mac_t *mac = esp_eth_mac_new_esp32(&mac_config);
#endif
        esp_eth_phy_t *phy = esp_eth_phy_new_lan8720(&phy_config);
        esp_eth_config_t config = ETH_DEFAULT_CONFIG(mac, phy);
        ESP_ERROR_CHECK(esp_eth_driver_install(&config, ð_handle));
        /* attach Ethernet driver to TCP/IP stack */
        ESP_ERROR_CHECK(esp_netif_attach(eth_netif, esp_eth_new_netif_glue(eth_handle)));
        /* start Ethernet driver state machine */
        ESP_ERROR_CHECK(esp_eth_start(eth_handle));
错误现象:
[0;31mE (224369341) emac_esp32: no mem for receive buffer[0m
更多回帖
