乐鑫技术交流
直播中
徐生财
10年用户 851经验值
擅长:MEMS/传感技术
私信 关注
[问答]
IDF master为什么突然用不了?
PS C:Usersxn551espidf2esp-idfexamplesget-startedhello_world> idf.py monitor
The following Python requirements are not satisfied:
python-socketio<5
gdbgui==0.13.2.0
To install the missing packages, please run "install.bat"
Diagnostic information:
    IDF_PYTHON_ENV_PATH: C:Usersxn551.espressifpython_envidf5.0_py3.9_env
    Python interpreter used: C:Usersxn551.espressifpython_envidf5.0_py3.9_envScriptspython.exe
Skipping the download of C:Usersxn551.espressifespidf.constraints.v5.0.txt because it was downloaded recently. If you believe that this is causing you trouble then remove it manually and re-run your install script.
Constraint file: C:Usersxn551.espressifespidf.constraints.v5.0.txt
Requirement files:
- C:Usersxn551espidf2esp-idfrequirements.core.txt
Python being checked: C:Usersxn551.espressifpython_envidf5.0_py3.9_envScriptspython.exe
ESP-IDF v5.0-dev-1389-g5dcd630444-dirty
IDF master, 几天前还好好的,s3,32,c3正常编译烧写,今天编译突然报错,4.3.1也用不了,现在只有2.1能用,请问是什么原因,写文章要用,急,谢谢!
更多回帖
