乐鑫技术交流
直播中
张虎豹
8年用户 1669经验值
私信 关注
[问答]
在使用esp-idf-v4.4的库及esp32-c3-s32模组的情况下,遇到twai功能的两个GPIO2/GPIO3无数据波形如何解决?
在使用esp-idf-v4.4的库及esp32-c3-s32模组的情况下,遇到twai功能的两个GPIO2/GPIO3无数据波形的情况,有朋友遇到过吗?如何解决
void app_main(void)
    twai_message_t message;
    esp_err_t err;
    //Initialize configuration structures using macro initializers
    twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(TX_GPIO_NUM, RX_GPIO_NUM, TWAI_MODE_NORMAL);
    twai_timing_config_t t_config = TWAI_TIMING_CONFIG_500KBITS();
    twai_filter_config_t f_config = TWAI_FILTER_CONFIG_ACCEPT_ALL();
    //Install TWAI driver
    if (twai_driver_install(&g_config, &t_config, &f_config) == ESP_OK)
        ESP_LOGI(EXAMPLE_TAG, "Driver installedn");
    else
        ESP_LOGI(EXAMPLE_TAG, "Failed to install drivern");
        return;
    //Start TWAI driver
    if (twai_start() == ESP_OK)
        ESP_LOGI(EXAMPLE_TAG, "Driver startedn");
    else
        ESP_LOGI(EXAMPLE_TAG, "Failed to start drivern");
        return;
    message.identifier = 0xAAAA;
    message.extd = 1;
    message.data_length_code = 8;
    for (int i = 0; i < 8; i++)
        message.data = 0x0A;
    while(1)
        //Queue message for transmission
        err = twai_transmit(&message, portMAX_DELAY);
        if (err == ESP_OK)
            ESP_LOGI(EXAMPLE_TAG,"Message queued for transmissionn");
        else
            ESP_LOGI(EXAMPLE_TAG,"Failed to queue message for transmissionn");
            twai_clear_transmit_queue();
        vTaskDelay(pdMS_TO_TICKS(10000));
    vTaskDelete(NULL);
更多回帖
