descrip
tion: BSP Display rotation example
dependencies:
espressif/esp_io_expander_aw9523b: "=1.0.1"
path: "../../../components/io_expander/esp_io_expander_aw9523b"
idf: ">=5"
hmi_esp32_b_v11:
version: "*"
override_path: "../../../hmi_esp32_b_v11"
-- Found Git: C:/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 11.2.0
-- The CXX compiler identification is GNU 11.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
CMake Error at C:/Espressif/frameworks/esp-idf-v5.0/tools/cmake/build.cmake:519 (message):
ERROR: Cannot parse the manifest file. Please check that
D:/esp-bsp/examples/hmi_esp32/mainidf_component.yml
is valid YAML file
