张飞硬件学习小组
直播中
ygpotsyyz
6年用户 322经验值
擅长:可编程逻辑
私信 关注
[硬件电路]
PC电路运算速度性能测试基准程序
!*********************************************************72
Program main
!c gprof_test, illustrate the use of the GPROF program
!                                    performance monitor
  Double Precision a(1001, 1000), b(1000), x(1000)
  Double Precision time(6), cray, ops, total, norma, normx
  Double Precision resid, residn, eps, epslon
  Integer ipvt(1000)
  lda = 1001
!     this program was updated on 10/12/92 to correct a
!     problem with the random number generator. The previous
!     random number generator had a short period and produced
!     singular matrices occasionally.
  Call timestamp()
  Write (*, '(a)') ' '
  n = 1000
  cray = .056
  Write (6, 1)
  1 format('$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$'//&
  '新年好! 兔年吉祥!'/&
                '玉兔报喜,福星献瑞!'/&
                     '虎挟雄风辞旧岁,玉兔呈祥月中来!'//&
      '注意防疫,加油!'/&
        'Protect yourself well from the COVID19-Pandemics!'/&
             'Merry Christmas & Happy New Year!'//&
             'Wish you good health & prosperous!'//&
             'SINOMACH'//&
             'PotsyYZ, 周勇, GoldbergJr.JohnBkt'/&
             '广州    20221214'/&
' Please send the results of this run to:'//&
  ' Jack J. Dongarra'/&
  ' Computer Science Department'/&
  ' University of Tennessee'/&
  ' Knoxville, Tennessee 37996-1300'//&
  ' Fax: 615-974-8296'//&
  ' Internet: dongarra@cs.utk.edu' /)
  ops = (2.0D0*dfloat(n)**3)/3.0D0 + 2.0D0*dfloat(n)**2
  Call matgen(a, lda, n, b, norma)
!        you should replace the call to dgefa and dgesl
!        by calls to your linear equation solver.
  t1 = second()
  Call dgefa(a, lda, n, ipvt, info)
  time(1) = second() - t1
  t1 = second()
  Call dgesl(a, lda, n, ipvt, b, 0)
  time(2) = second() - t1
  total = time(1) + time(2)
!     compute a residual to verify results.
  Do i = 1, n
    x(i) = b(i)
  End Do
  Do i = 1, n
    b(i) = -b(i)
  End Do
  Call dmxpy(n, b, n, lda, x, a)
  resid = 0.0
  normx = 0.0
  Do i = 1, n
    resid = dmax1(resid, dabs(b(i)))
    normx = dmax1(normx, dabs(x(i)))
  End Do
  eps = epslon(1.0D0)
  residn = resid/(n*norma*normx*eps)
  Write (6, 40)
  Write (6, 50) residn, resid, eps, x(1), x(n)
  Write (6, 60) n
  Write (6, 70)
  70 format(6 x, 'factor', 5 x, 'solve', 6 x, 'total', 5 x, 'mflops', 7 x,&
  'unit',6x,'ratio')
  time(3)=total
  time(4)=ops/(1.0D6*total)
  time(5)=2.0D0/time(4)
  time(6)=total/cray
  Write(6,80) lda
  Write(6,110)(time(i),i=1,6)
  Write(6,*) ' end of tests -- this version dated 10/12/92'
  Write(*,'(a)') ' '
  Call timestamp()
  Stop
  40 Format('     norm. resid      resid           machep',&
  '         x(1)          x(n)')
  50 Format(1P5E16.8)
  60 Format(//'    times are reported for matrices of order ',I5)
  80 Format(' times for array with leading dimension of',I4)
  110 Format(6(1PE11.3))
End Program main
Subroutine matgen(a,lda,n,b,norma)
  Integer lda, n, init(4), i, j
  Double Precision a(lda,1), b(1), norma, random_value
  init(1)=1
  init(2)=2
  init(3)=3
  init(4)=1325
  norma=0.0
  Do j=1, n
    Do i=1, n
      a(i,j)=random_value(init)-.5
      norma=dmax1(dabs(a(i,j)),norma)
    End Do
  End Do
  Do i=1, n
    b(i)=0.0
  End Do
  Do j=1, n
    Do i=1, n
      b(i)=b(i)+a(i,j)
    End Do
  End Do
  Return
End Subroutine matgen
Subroutine dgefa(a,lda,n,ipvt,info)
  Integer lda, n, ipvt(1), info
!     dgefa factors a double precision matrix by gaussian elimination.
!     dgefa is usually called by dgeco, but it can be called
!     directly with a saving in time if  rcond  is not needed.
!     (time for dgeco) = (1 + 9/n)*(time for dgefa) .
!     on entry
!        a       double precision(lda, n)
!                the matrix to be factored.
!        lda     integer
!                the leading dimension of the array  a .
!        n       integer
!                the order of the matrix  a .
!     on return
!        a       an upper triangular matrix and the multipliers
!                which were used to obtain it.
!                the factorization can be written  a = l*u  where
!                l  is a product of permutation and unit lower
!                triangular matrices and  u  is upper triangular.
!        ipvt    integer(n)
!                an integer vector of pivot indices.
!        info    integer
!                = 0  normal value.
!                = k  if  u(k,k) .eq. 0.0 .  this is not an error
!                     condition for this subroutine, but it does
!                     indicate that dgesl or dgedi will divide by zero
!                     if called.  use  rcond  in dgeco for a reliable
!                     indication of singularity.
!     linpack. this version dated 08/14/78 .
!     cleve moler, university of new mexico, argonne national lab.
!     subroutines and functions
!     blas daxpy,dscal,idamax
!     internal variables
  Double Precision t
  Integer idamax, j, k, kp1, l, nm1
!     gaussian elimination with partial pivoting
  info=0
  nm1=n-1
  If(nm1<1) Goto 70
  Do k=1, nm1
    kp1=k+1
!        find l = pivot index
    l=idamax(n-k+1,a(k,k),1)+k-1
    ipvt(k)=l
!        zero pivot implies this column already triangularized
    If(a(l,k)==0.0D0) Goto 40
!           interchange if necessary
    If(l==k) Goto 10
    t=a(l,k)
    a(l,k)=a(k,k)
    a(k,k)=t
    10 Continue
!           compute multipliers
    t=-1.0D0/a(k,k)
    Call dscal(n-k,t,a(k+1,k),1)
!           row elimination with column indexing
    Do j=kp1, n
       t=a(l,j)
      If(l==k) Goto 20
      a(l,j)=a(k,j)
      a(k,j)=t
      20 Continue
      Call daxpy(n-k,t,a(k+1,k),1,a(k+1,j),1)
    End Do
    Goto 50
    40 Continue
    info=k
    50 Continue
  End Do
  70 Continue
  ipvt(n)=n
  If(a(n,n)==0.0D0) info=n
  Return
End Subroutine dgefa
Subroutine dgesl(a,lda,n,ipvt,b,job)
  Integer lda, n, ipvt(1), job
!     dgesl solves the double precision system
!     a * x = b  or  trans(a) * x = b
!     using the factors computed by dgeco or dgefa.
!     on entry
!                the output from dgeco or dgefa.
!        lda     integer
!        n       integer
!        ipvt    integer(n)
!                the pivot vector from dgeco or dgefa.
!        b       double precision(n)
!                the right hand side vector.
!        job     integer
!                = 0         to solve  a*x = b ,
!                = nonzero   to solve  trans(a)*x = b  where
!                            trans(a)  is the transpose.
!     on return
!        b       the solution vector  x .
!     error condition
!        a division by zero will occur if the input factor contains a
!        zero on the diagonal.  technically this indicates singularity
!        but it is often caused by improper arguments or improper
!        setting of lda .  it will not occur if the subroutines are
!        called correctly and if dgeco has set rcond .gt. 0.0
!        or dgefa has set info .eq. 0 .
!     to compute  inverse(a) * c  where  c  is a matrix
!     with  p  columns
!           call dgeco(a,lda,n,ipvt,rcond,z)
!           if (rcond is too small) go to ...
!           do 10 j = 1, p
!              call dgesl(a,lda,n,ipvt,c(1,j),0)
!        10 continue
!     blas daxpy,ddot
  Double Precision ddot, t
  Integer k, kb, l, nm1
  nm1=n-1
  If(job/=0) Goto 50
!        job = 0 , solve  a * x = b
!        first solve  l*y = b
  If(nm1<1) Goto 30
  Do k=1, nm1
    l=ipvt(k)
    t=b(l)
    If(l==k) Goto 10
    b(l)=b(k)
    b(k)=t
    10 Continue
    Call daxpy(n-k,t,a(k+1,k),1,b(k+1),1)
  End Do
  30 Continue
!        now solve  u*x = y
  Do kb=1, n
    k=n+1-kb
    b(k)=b(k)/a(k,k)
    t=-b(k)
    Call daxpy(k-1,t,a(1,k),1,b(1),1)
  End Do
  Goto 100
  50 Continue
!        job = nonzero, solve  trans(a) * x = b
!        first solve  trans(u)*y = b
  Do k=1, n
    t=ddot(k-1,a(1,k),1,b(1),1)
    b(k)=(b(k)-t)/a(k,k)
  End Do
!        now solve trans(l)*x = y
  If(nm1<1) Goto 90
  Do kb=1, nm1
    k=n-kb
    b(k)=b(k)+ddot(n-k,a(k+1,k),1,b(k+1),1)
    l=ipvt(k)
    If(l==k) Goto 70
    t=b(l)
    b(l)=b(k)
    b(k)=t
    70 Continue
  End Do
  90 Continue
  100 Continue
  Return
End Subroutine dgesl
Subroutine daxpy(n,da,dx,incx,dy,incy)
!     constant times a vector plus a vector.
!     uses unrolled loops for increments equal to one.
!     jack dongarra, linpack, 3/11/78.
  Double Precision dx(1), dy(1), da
  Integer i, incx, incy, ix, iy, m, mp1, n
  If(n<=0) Return
  If(da==0.0D0) Return
  If(incx==1 .And. incy==1) Goto 20
!        code for unequal increments or equal increments
!          not equal to 1
  ix=1
  iy=1
  If(incx<0) ix=(-n+1)*incx+1
  If(incy<0) iy=(-n+1)*incy+1
  Do i=1, n
    dy(iy)=dy(iy)+da*dx(ix)
    ix=ix+incx
    iy=iy+incy
  End Do
  Return
!        code for both increments equal to 1
!        clean-up loop
  20 m=mod(n,4)
  If(m==0) Goto 40
  Do i=1, m
    dy(i)=dy(i)+da*dx(i)
  End Do
  If(n<4) Return
  40 mp1=m+1
  Do i=mp1, n, 4
    dy(i+1)=dy(i+1)+da*dx(i+1)
    dy(i+2)=dy(i+2)+da*dx(i+2)
    dy(i+3)=dy(i+3)+da*dx(i+3)
  End Do
  Return
End Subroutine daxpy
Double Precision Function ddot(n,dx,incx,dy,incy)
!     forms the dot product of two vectors.
  Double Precision dx(1), dy(1), dtemp
  ddot=0.0D0
  dtemp=0.0D0
  If(n<=0) Return
!          not equal to 1
  ix=1
  iy=1
  Do i=1, n
    dtemp=dtemp+dx(ix)*dy(iy)
    ix=ix+incx
    iy=iy+incy
  End Do
  ddot=dtemp
  Return
!        clean-up loop
  20 m=mod(n,5)
  If(m==0) Goto 40
  Do i=1, m
    dtemp=dtemp+dx(i)*dy(i)
  End Do
  If(n<5) Goto 60
  40 mp1=m+1
  Do i=mp1, n, 5
    dtemp=dtemp+dx(i)*dy(i)+dx(i+1)*dy(i+1)+dx(i+2)*dy(i+2)+dx(i+3)*dy(i+3)&
    +dx(i+4)*dy(i+4)
  End Do
  60 ddot=dtemp
  Return
End Function ddot
Subroutine dscal(n,da,dx,incx)
!     scales a vector by a constant.
!     uses unrolled loops for increment equal to one.
  Double Precision da, dx(1)
  Integer i, incx, m, mp1, n, nincx
  If(n<=0) Return
  If(incx==1) Goto 20
!        code for increment not equal to 1
  nincx=n*incx
  Do i=1, nincx, incx
    dx(i)=da*dx(i)
  End Do
  Return
!        code for increment equal to 1
!        clean-up loop
  20 m=mod(n,5)
  If(m==0) Goto 40
  Do i=1, m
    dx(i)=da*dx(i)
  End Do
  If(n<5) Return
  40 mp1=m+1
  Do i=mp1, n, 5
    dx(i)=da*dx(i)
    dx(i+1)=da*dx(i+1)
    dx(i+2)=da*dx(i+2)
    dx(i+3)=da*dx(i+3)
    dx(i+4)=da*dx(i+4)
  End Do
  Return
End Subroutine dscal
Integer Function idamax(n,dx,incx)
!     finds the index of element having max. dabsolute value.
  Double Precision dx(1), dmax
  Integer i, incx, ix, n
  idamax=0
  If(n<1) Return
  idamax=1
  If(n==1) Return
  If(incx==1) Goto 20
  ix=1
  dmax=dabs(dx(1))
  ix=ix+incx
  Do i=2, n
    If(dabs(dx(ix))<=dmax) Goto 5
    idamax=i
    dmax=dabs(dx(ix))
    5 ix=ix+incx
  End Do
  Return
  20 dmax=dabs(dx(1))
  Do i=2, n
    If(dabs(dx(i))<=dmax) Goto 30
    idamax=i
    dmax=dabs(dx(i))
  30 End Do
  Return
End Function idamax
Double Precision Function epslon(x)
  Double Precision x
!     estimate unit roundoff in quantities of size x.
  Double Precision a, b, c, eps
!     this program should function properly on all systems
!     satisfying the following two assumptions,
!        1.  the base used in representing dfloating point
!            numbers is not a power of three.
!        2.  the quantity  a  in statement 10 is represented to
!            the accuracy used in dfloating point variables
!            that are stored in memory.
!     the statement number 10 and the go to 10 are intended to
!     force optimizing compilers to generate code satisfying
!     assumption 2.
!     under these assumptions, it should be true that,
!            a  is not exactly equal to four-thirds,
!            b  has a zero for its last bit or digit,
!            c  is not exactly equal to one,
!            eps  measures the separation of 1.0 from
!                 the next larger dfloating point number.
!     the developers of eispack would appreciate being informed
!     about any systems where these assumptions do not hold.
!     this routine is one of the auxiliary routines used by eispack iii
!     to avoid machine dependencies.
!     this version dated 4/6/83.
  a=4.0D0/3.0D0
  10 b=a-1.0D0
  c=b+b+b
  eps=dabs(c-1.0D0)
  If(eps==0.0D0) Goto 10
  epslon=eps*dabs(x)
  Return
End Function epslon
Subroutine mm(a,lda,n1,n3,b,ldb,n2,c,ldc)
  Double Precision a(lda,*), b(ldb,*), c(ldc,*)
!   purpose:
!     multiply matrix b times matrix c and store the result in matrix a.
!   parameters:
!     a double precision(lda,n3), matrix of n1 rows and n3 columns
!     lda integer, leading dimension of array a
!     n1 integer, number of rows in matrices a and b
!     n3 integer, number of columns in matrices a and c
!     b double precision(ldb,n2), matrix of n1 rows and n2 columns
!     ldb integer, leading dimension of array b
!     n2 integer, number of columns in matrix b, and number of rows in
!         matrix c
!     c double precision(ldc,n3), matrix of n2 rows and n3 columns
!     ldc integer, leading dimension of array c
  Do j=1, n3
    Do i=1, n1
      a(i,j)=0.0
    End Do
    Call dmxpy(n2,a(1,j),n1,ldb,c(1,j),b)
  End Do
  Return
End Subroutine mm
Subroutine dmxpy(n1,y,n2,ldm,x,m)
  Double Precision y(*), x(*), m(ldm,*)
!   purpose:
!     multiply matrix m times vector x and add the result to vector y.
!   parameters:
!     n1 integer, number of elements in vector y, and number of rows in
!         matrix m
!     y double precision(n1), vector of length n1 to which is added
!         the product m*x
!     n2 integer, number of elements in vector x, and number of columns
!         in matrix m
!     ldm integer, leading dimension of array m
!     x double precision(n2), vector of length n2
!     m double precision(ldm,n2), matrix of n1 rows and n2 columns
!   cleanup odd vector
  j=mod(n2,2)
  If(j>=1) Then
    Do i=1, n1
      y(i)=(y(i))+x(j)*m(i,j)
    End Do
  End If
!   cleanup odd group of two vectors
  j=mod(n2,4)
  If(j>=2) Then
    Do i=1, n1
      y(i)=((y(i))+x(j-1)*m(i,j-1))+x(j)*m(i,j)
    End Do
  End If
!   cleanup odd group of four vectors
  j=mod(n2,8)
  If(j>=4) Then
    Do i=1, n1
      y(i)=((((y(i))+x(j-3)*m(i,j-3))+x(j-2)*m(i,j-2))+x(j-1)*m(i,j-1))+&
      x(j)*m(i,j)
    End Do
  End If
!   cleanup odd group of eight vectors
  j=mod(n2,16)
  If(j>=8) Then
    Do i=1, n1
      y(i)=((((((((y(i))+x(j-7)*m(i,j-7))+x(j-6)*m(i,j-6))+x(j-5)*m(i,j-5))+&
      x(j-4)*m(i,j-4))+x(j-3)*m(i,j-3))+x(j-2)*m(i,j-2))+x(j-1)*m(i,j-1))+&
      x(j)*m(i,j)
    End Do
  End If
!   main loop - groups of sixteen vectors
  jmin=j+16
  Do j=jmin, n2, 16
    Do i=1, n1
      y(i)=((((((((((((((((y(i))&
      +x(j-15)*m(i,j-15))+x(j-14)*m(i,j-14))&
      +x(j-13)*m(i,j-13))+x(j-12)*m(i,j-12))&
      +x(j-11)*m(i,j-11))+x(j-10)*m(i,j-10))&
      +x(j-9)*m(i,j-9))+x(j-8)*m(i,j-8))&
      +x(j-7)*m(i,j-7))+x(j-6)*m(i,j-6))&
      +x(j-5)*m(i,j-5))+x(j-4)*m(i,j-4))&
      +x(j-3)*m(i,j-3))+x(j-2)*m(i,j-2))&
    End Do
  End Do
  Return
End Subroutine dmxpy
Double Precision Function random_value(iseed)
!     modified from the LAPACK auxiliary routine 10/12/92 JD
!  -- LAPACK auxiliary routine (version 1.0) --
!     Univ. of Tennessee, Univ. of California Berkeley, NAG Ltd.,
!     Courant Institute, Argonne National Lab, and Rice University
!     February 29, 1992
!     .. Array Arguments ..
  Integer iseed(4)
!  Purpose
!  DLARAN returns a random real number from a uniform (0,1)
!  distribution.
!  Arguments
!  ISEED   (input/output) INTEGER array, dimension (4)
!          On entry, the seed of the random number generator; the array
!          elements must be between 0 and 4095, and ISEED(4) must be
!          odd.
!          On exit, the seed is updated.
!  Further Details
!  This routine uses a multiplicative congruential method with modulus
!  2**48 and multiplier 33952834046453 (see G.S.Fishman,
!  'Multiplicative congruential random number generators with modulus
!  2**b: an exhaustive analysis for b = 32 and a partial analysis for
!  b = 48', Math. Comp. 189, pp 331-344, 1990).
!  48-bit integers are stored in 4 integer array elements with 12 bits
!  per element. Hence the routine is portable across machines with
!  integers of 32 bits or more.
!     .. Parameters ..
  Integer m1, m2, m3, m4
  Parameter(m1=494,m2=322,m3=2508,m4=2549)
  Double Precision one
  Parameter(one=1.0D+0)
  Integer ipw2
  Double Precision r
  Parameter(ipw2=4096,r=one/ipw2)
!     .. Local Scalars ..
  Integer it1, it2, it3, it4
!     .. Intrinsic Functions ..
  Intrinsic dble, mod
!     .. Executable Statements ..
!     multiply the seed by the multiplier modulo 2**48
  it4=iseed(4)*m4
  it3=it4/ipw2
  it4=it4-ipw2*it3
  it3=it3+iseed(3)*m4+iseed(4)*m3
  it2=it3/ipw2
  it3=it3-ipw2*it2
  it2=it2+iseed(2)*m4+iseed(3)*m3+iseed(4)*m2
  it1=it2/ipw2
  it2=it2-ipw2*it1
  it1=it1+iseed(1)*m4+iseed(2)*m3+iseed(3)*m2+iseed(4)*m1
  it1=mod(it1,ipw2)
!     return updated seed
  iseed(1)=it1
  iseed(2)=it2
  iseed(3)=it3
  iseed(4)=it4
!     convert 48-bit integer to a real number in the interval (0,1)
  random_value=r*(dble(it1)+r*(dble(it2)+r*(dble(it3)+r*(dble(it4)))))
  Return
!     End of RAN
End Function random_value
Subroutine timestamp()
!*********************************************************************72
!c TIMESTAMP prints out the current YMDHMS date as a timestamp.
!  Parameters:
!    None
  Implicit None
  Character*(8) ampm
  Integer d
  Character*(8) date
  Integer h
  Integer m
  Integer mm
  Character*(9) month(12)
  Integer n
  Integer s
  Character*(10) time
  Integer y
  Save month
  Data month/'January  ', 'February ', 'March    ', 'April    ', 'May      ', &
  'June     ', 'July     ', 'August   ', 'September', 'October  ', &
  'November ', 'December '/
  Call date_and_time(date,time)
  Read(date,'(i4,i2,i2)') y, m, d
  Read(time,'(i2,i2,i2,1x,i3)') h, n, s, mm
  If(h<12) Then
    ampm='AM'
  Else If(h==12) Then
    If(n==0 .And. s==0) Then
      ampm='Noon'
    Else
      ampm='PM'
    End If
  Else
    h=h-12
    If(h<12) Then
      ampm='PM'
    Else If(h==12) Then
        ampm='Midnight'
      Else
        ampm='AM'
      End If
    End If
  End If
  Write(*,'(i2,1x,a,1x,i4,2x,i2,a1,i2.2,a1,i2.2,a1,i3.3,1x,a)') d,&
  month(m), y, h, ':', n, ':', s, '.', mm, ampm
  Return
End Subroutine timestamp
更多回帖
