ST意法半导体
登录
直播中
陈勇
8年用户
1341经验值
私信
[问答]
触摸LCD时线条显示在远离触摸位置的地方是什么问题?
开启该帖子的消息推送
HAL库
LCD液晶屏
TFT
我成功地使用了一个 HAL 库来驱动一个 TFT ili9341 LCD,并尝试通过触摸 LCD 在 LCD 上画一条线,代码非常准确,然后我用寄存器重写了代码。现在触摸不准确,当我触摸 LCD 时,线条显示在远离触摸位置的位置,我附上了代码。可能是什么问题?引脚定义为最大频率。
#include "ILI9341_Touchscreen.h"
#include "
STM32
f10x.h"
#include "main.h"
//Internal Touchpad command, do not call directly
uint16_t TP_Read(void)
uint8_t i = 16;
uint16_t value = 0;
while(i > 0x00)
value <<= 1;
TP_CLK_PORT->BSRR=TP_CLK_PIN;
TP_CLK_PORT->BRR=TP_CLK_PIN;
if ((TP_MISO_PORT->IDR&TP_MISO_PIN)!=0)
value++;
i--;
return value;
void TP_Write(uint8_t value)
uint8_t i = 0x08;
while(i > 0)
if((value & 0x80) != 0x00)
TP_MOSI_PORT->BSRR=TP_MOSI_PIN;
else
TP_MOSI_PORT->BRR=TP_MOSI_PIN;
value <<= 1;
i--;
//Read coordinates of touchscreen press. Posi
ti
on[0] = X, Position[1] = Y
uint8_t TP_Read_Coordinates(uint16_t Coordinates[2])
TP_CS_PORT->BSRR=TP_CS_PIN;
uint32_t avg_x, avg_y = 0;
uint16_t rawx, rawy = 0;
uint32_t calculating_x, calculating_y = 0;
uint32_t samples = NO_OF_POSITION_SAMPLES;
uint32_t counted_samples = 0;
TP_CS_PORT->BRR=TP_CS_PIN;
while((samples > 0)&&((TP_IRQ_PORT->IDR)& TP_IRQ_PIN) == 0)
TP_Write(CMD_RDY);
rawy = TP_Read();
avg_y += rawy;
calculating_y += rawy;
TP_Write(CMD_RDX);
rawx = TP_Read();
avg_x += rawx;
calculating_x += rawx;
samples--;
counted_samples++;
if((counted_samples == NO_OF_POSITION_SAMPLES)&&((TP_IRQ_PORT->IDR)&TP_IRQ_PIN) == 0)
calculating_x /= counted_samples;
calculating_y /= counted_samples;
rawx = calculating_x;
rawy = calculating_y;
rawx *= -1;
rawy *= -1;
//CONVERTING 16bit Value to Screen coordinates
// 65535/273 = 240!
// 65535/204 = 320!
Coordinates[0] = ((240 - (rawx/X_TRANSLATION)) - X_OFFSET)*X_MAGNITUDE;
Coordinates[1] = ((rawy/Y_TRANSLATION)- Y_OFFSET)*Y_MAGNITUDE;
return TOUCHPAD_DATA_OK;
else
Coordinates[0] = 0;
Coordinates[1] = 0;
return TOUCHPAD_DATA_NOISY;
//Check if Touchpad was pressed. Returns TOUCHPAD_PRESSED (1) or TOUCHPAD_NOT_PRESSED (0)
uint8_t TP_Touchpad_Pressed(void)
if((TP_IRQ_PORT->IDR&TP_IRQ_PIN) == 0)
return TOUCHPAD_PRESSED;
else
return TOUCHPAD_NOT_PRESSED;
回帖
(1)
李妍
2023-1-5 09:51:05
我定义了一个虚拟变量 a 并在两者之间写了 a++
和
现在工作正常!我的问题解决了。我认为它运行不佳的原因是我违反了基于数据表的 200ns tCH 规范。HAL 代码工作的原因可能是因为 HAL 代码指令需要更长的时间来运行。
和
举报
更多回帖
rotate(-90deg);
回复
相关问答
HAL库
LCD液晶屏
TFT
触摸
屏出现异常
2019-07-03
2033
为什么手指
触摸
不能被
触摸
元素感知?
2019-08-20
1119
请问有
LCD
触摸
屏接口电路图吗?
2019-10-30
1949
微雪的7寸带
触摸
HDMI
显示
屏的
触摸
使用不了是为什么?
2022-01-13
2026
tsc2007
触摸
屏校准后发现其鼠标无法正确点击是
什么问题
2022-01-11
1041
如何使用Harmony和
触摸
屏
LCD
2020-05-05
2178
触摸
屏有哪些类型?
2019-09-04
2098
微雪的3.5寸
LCD
的
触摸
屏问题
2017-05-25
6713
串口接收到的数据如何
显示
在
触摸
屏上
2019-03-01
6473
LCD
电容
触摸
屏,
触摸
屏幕时,总是会有异常坐标,这是为何?
2021-07-02
2029
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
