ST意法半导体
直播中
王玉兰
8年用户 1386经验值
私信 关注
[问答]
缺少EXTI IR处理程序代码怎么解决?
我正在使用 EXti1 中断并像这样定义 EXTI1 处理程序:
  • void EXTI1_IRQHandler(void)
  •   __HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_1);
  •   if (GPIOA->IDR & 0x0100 {
  •     EXTI->PR = 1;
  •     (void) EXTI->PR;
  •     NVIC_ClearPendingIRQ(EXTI0_IRQn);
  •     NVIC_EnableIRQ(EXTI0_IRQn);
  •     fun1();
  •   } else {
  •     NVIC_DisableIRQ(EXTI0_IRQn);
  •     EXTI->PR = 1;
  •     (void) EXTI->PR; // wait for hardware
当我查看生成的列表文件时,我发现了这段汇编代码:
  • 000001d4 :
  •     while (__HAL_RTC_ALARM_GET_FLAG(hrtc, RTC_FLAG_ALRAWF) == RESET);
  • 1d4:        4bab              ldr        r3, [pc, #684]        ; (484 <_Min_Heap_Size+0x84>)
  • 1d6:        2102              movs        r1, #2
  •       if (count-- == 0U)
  • 1d8:        4aab              ldr        r2, [pc, #684]        ; (488 <_Min_Heap_Size+0x88>)
  • 1da:        b5f0              push        {r4, r5, r6, r7, lr}
  • 1dc:        6159              str        r1, [r3, #20]
  • 1de:        6912              ldr        r2, [r2, #16]
  • 1e0:        0792              lsls        r2, r2, #30
  • 1e2:        d525              bpl.n        230
  •     hrtc->Instance->ALRMAR = (uint32_t)tmpreg;
  • 1e4:        4aa9              ldr        r2, [pc, #676]        ; (48c <_Min_Heap_Size+0x8c>)
  •     hrtc->Instance->ALRMASSR = subsecondtmpreg;
  • 1e6:        2040              movs        r0, #64        ; 0x40
  •     __HAL_RTC_ALARMA_ENABLE(hrtc);
  • 1e8:        2401              movs        r4, #1
  • 1ea:        4ea9              ldr        r6, [pc, #676]        ; (490 <_Min_Heap_Size+0x90>)
  • 1ec:        2500              movs        r5, #0
  • 1ee:        615c              str        r4, [r3, #20]
  •     __HAL_RTC_ALARM_ENABLE_IT(hrtc,RTC_IT_ALRA);
  • 1f0:        695b              ldr        r3, [r3, #20]
  • 1f2:        f8c2 0180         str.w        r0, [r2, #384]        ; 0x180
  • 1f6:        6010              str        r0, [r2, #0]
  • 1f8:        6932              ldr        r2, [r6, #16]
  •   while(Value >= 10)
  • 1fa:        4ba6              ldr        r3, [pc, #664]        ; (494 <_Min_Heap_Size+0x94>)
  • 1fc:        f402 4060         and.w        r0, r2, #57344        ; 0xe000
  • 200:        601a              str        r2, [r3, #0]
  • 202:        f5b0 4f80         cmp.w        r0, #16384        ; 0x4000
  • 206:        671d              str        r5, [r3, #112]        ; 0x70
  • 208:        d025              beq.n        256
  • 20a:        f5b0 5f00         cmp.w        r0, #8192        ; 0x2000
  • 20e:        d062              beq.n        2d6
  •       return HAL_ERROR;
  • 210:        f5b0 4fc0         cmp.w        r0, #24576        ; 0x6000
  •       hsd->State = HAL_SD_STATE_READY;
  • 214:        d040              beq.n        298
  •       __HAL_SD_CLEAR_FLAG(hsd, SDMMC_STATIC_FLAGS);
  • 216:        f5b0 4f20         cmp.w        r0, #40960        ; 0xa000
  •       hsd->ErrorCode |= HAL_SD_ERROR_DATA_CRC_FAIL;
  • 21a:        da61              bge.n        2e0
  • 21c:        f5b0 4f00         cmp.w        r0, #32768        ; 0x8000
  • 220:        f000 80c5         beq.w        3ae
  • 224:        4a9c              ldr        r2, [pc, #624]        ; (498 <_Min_Heap_Size+0x98>)
  •       hsd->Context = SD_CONTEXT_NONE;
  • 226:        4b9d              ldr        r3, [pc, #628]        ; (49c <_Min_Heap_Size+0x9c>)
  •       return HAL_ERROR;
  • 228:        6811              ldr        r1, [r2, #0]
  • 22a:        400b              ands        r3, r1
  • 22c:        6013              str        r3, [r2, #0]
  • 22e:        bdf0              pop        {r4, r5, r6, r7, pc}
  •       return HAL_ERROR;
  • 230:        4c99              ldr        r4, [pc, #612]        ; (498 <_Min_Heap_Size+0x98>)
  •       hsd->ErrorCode |= HAL_SD_ERROR_RX_OVERRUN;
  • 232:        2040              movs        r0, #64        ; 0x40
  • 234:        4a99              ldr        r2, [pc, #612]        ; (49c <_Min_Heap_Size+0x9c>)
  • 236:        6825              ldr        r5, [r4, #0]
  • 238:        4994              ldr        r1, [pc, #592]        ; (48c <_Min_Heap_Size+0x8c>)
  • 23a:        402a              ands        r2, r5
  • 23c:        6022              str        r2, [r4, #0]
  • 23e:        f8c1 0080         str.w        r0, [r1, #128]        ; 0x80
  •     __HAL_SD_CLEAR_FLAG(hsd, SDMMC_STATIC_DATA_FLAGS);
  • 242:        f3bf 8f4f         dsb        sy
  • 246:        f3bf 8f6f         isb        sy
  • 24a:        2201              movs        r2, #1
  • 24c:        615a              str        r2, [r3, #20]
  • 24e:        695b              ldr        r3, [r3, #20]
  •     return HAL_OK;
  • 250:        f8c1 0180         str.w        r0, [r1, #384]        ; 0x180
  • 254:        bdf0              pop        {r4, r5, r6, r7, pc}
  • 256:        6858              ldr        r0, [r3, #4]
  • // fun2(!) follows
这根本不是我的经纪人。是否有一些样板代码负责上下文切换?进一步看,似乎 EXTI2 和 EXTI3 处理程序不包含此样板代码。
那么显示的代码实际上是我的 EXTI1 处理程序吗,即使显示的源代码行不匹配?
回帖(1)
刘悌耀
2022-12-28 15:37:34
你知道吗?当我仔细查看生成的程序集源代码,或者更确切地说是生成的注释时,我注意到程序集确实匹配我的处理程序,但 C 源代码行不匹配!
所以这毕竟是一个错误,尽管不是在代码生成中。gcc 是这里的罪魁祸首还是其他工具?也许我应该切换到 CubeIDE,因为 TrueSTUDIO 不再更新了。
举报
更多回帖
