ST意法半导体
直播中
mintsy
9年用户 1573经验值
擅长:MEMS/传感技术
私信 关注
[问答]
如何多次更改SDADC的增益?
我想在 MCU STM32F373VBTx 运行时更改 SDADC 增益。
那行得通,但只有一次。
首先,在 SDADC 初始化时,STM32 CubeMX 设置预定义增益。
其次,我通过从变量中读取值来设置增益。这样可行。
但是当我第三次这样做时,什么也没有发生。嗯……为什么?
这是我需要等待的事情,直到我能获得收益吗?
还有一个问题。校准函数HAL_SDADC_CalibrationStart是否找到了完美的偏移量,所以我不需要手动更改它?
  • void STM32_PLC_Analog_Input_Set_Gain_Offset(uint8_t sdadc, uint8_t configuration_index, uint8_t gain, uint16_t SDADC_offset) {
  •         /* Initial selection */
  •         SDADC_HandleTypeDef *hsdadc;
  •         int16_t *DMA_address;
  •         uint8_t DMA_length;
  •         uint8_t SDADC_gain;
  •         switch(sdadc){
  •         case 1:
  •                 hsdadc = handler_sdadc1;
  •                 DMA_length = 9;
  •                 DMA_address = SDADC1_Single;
  •                 break;
  •         case 2:
  •                 hsdadc = handler_sdadc2;
  •                 DMA_length = 3;
  •                 DMA_address = SDADC2_Single;
  •                 break;
  •         case 3:
  •                 hsdadc = handler_sdadc3;
  •                 DMA_length = 5;
  •                 DMA_address = SDADC3_Differential;
  •                 break;
  •         default:
  •                 DMA_length = 9;
  •                 break;
  •         /* Set gain and offset */
  •         switch(gain){
  •         case 0:
  •                 SDADC_gain = 0b111;
  •                 break;
  •         case 1:
  •                 SDADC_gain = 0b0;
  •                 break;
  •         case 2:
  •                 SDADC_gain = 0b1;
  •                 break;
  •         case 3:
  •                 SDADC_gain = 0b10;
  •                 break;
  •         case 4:
  •                 SDADC_gain = 0b11;
  •                 break;
  •         case 5:
  •                 SDADC_gain = 0b100;
  •                 break;
  •         case 6:
  •                 SDADC_gain = 0b101;
  •                 break;
  •         default:
  •                 SDADC_gain = 0b0;
  •                 break;
  •         /* Stop SDADC with DMA */
  •         if(HAL_SDADC_InjectedStop_DMA(hsdadc) != HAL_OK)
  •                 Error_Handler();
  •         /* 1: Enter init-mode for the control register */
  •         hsdadc->Instance->CR1 |= SDADC_CR1_INIT;
  •         uint32_t tickstart = HAL_GetTick();
  •         bool isAtInitMode = true;
  •         /* Wait for INITRDY bit on SDADC_ISR */
  •         while ((hsdadc->Instance->ISR & SDADC_ISR_INITRDY) == (uint32_t) RESET) {
  •                 if ((HAL_GetTick() - tickstart) > 200) {
  •                         isAtInitMode = false;
  •         /* 2: If init mode, then set gain and offset registers */
  •         if(isAtInitMode){
  •                 switch(configuration_index){
  •                 case SDADC_CONF_INDEX_0:
  •                         hsdadc->Instance->CONF0R |= SDADC_gain << 20; /* Bits 22:20 GAIN0[2:0]: */
  •                         hsdadc->Instance->CONF0R |= SDADC_offset;     /* Bits 11:0 OFFSET0[11:0]: */
  •                         break;
  •                 case SDADC_CONF_INDEX_1:
  •                         hsdadc->Instance->CONF1R |= SDADC_gain << 20;
  •                     hsdadc->Instance->CONF1R |= SDADC_offset;
  •                         break;
  •                 case SDADC_CONF_INDEX_2:
  •                         hsdadc->Instance->CONF2R |= SDADC_gain << 20;
  •                         hsdadc->Instance->CONF2R |= SDADC_offset;
  •                         break;
  •         /* 3: Leave init-mode for the control register */
  •         hsdadc->Instance->CR1 &= ~(SDADC_CR1_INIT);
  •         /* Start ADC again */
  •         if (HAL_SDADC_CalibrationStart(hsdadc, SDADC_CALIBRATION_SEQ_3) != HAL_OK)
  •                 Error_Handler();
  •         if (HAL_SDADC_PollForCalibEvent(hsdadc, HAL_MAX_DELAY) != HAL_OK)
  •                 Error_Handler();
  •         if(HAL_SDADC_InjectedStart_DMA(hsdadc, (uint32_t*)DMA_address, DMA_length) != HAL_OK)
  •                 Error_Handler();
回帖(1)
李雷
2022-12-28 09:25:11
GAIN 位在哪里清零?
举报
更多回帖
