ST意法半导体
直播中
孔朱磊
8年用户 1043经验值
私信 关注
[问答]
在IAR EWARM中怎样去启用库动态分配功能呢
  • #include "ESP8266.h"
  • #include "ESP8266Config.h"
  • bool Wifi_SendRaw(uint8_t *data,uint16_t len)
  •         if(len <= _WIFI_TX_SIZE)
  •                 // Send the information in data through the UART of the ESP8266
  •                 memcpy(Wifi.TxBuffer,data,len);
  •                 if(HAL_UART_Transmit(&_WIFI_USART,data,len,900) == HAL_OK)
  •                         return true;
  •                 else
  •                         return false;
  •         else
  •                 return false;
  • bool Wifi_SendString(char *data)
  •         return Wifi_SendRaw((uint8_t*)data,strlen(data));
  • bool Wifi_SendStringAndWait(char *data,uint16_t DelayUs)
  •         if(Wifi_SendRaw((uint8_t*)data,strlen(data))==false)
  •                 return false;
  •         DWT_Delay_us(DelayUs);
  •         return true;
  • bool Wifi_WaitForString(uint32_t TimeOut_ms,uint8_t *result,uint8_t CountOfParameter,...)
  •          * It uses the CountOfParameter and the Parameters after that to compare with the
  •          * information that it was received in the UART RX. If the parameter is in the
  •          * received string the functions return a true value and the position of the
  •          * parameter (according to the position in the function)
  •          * Ex:
  •          * Wifi_WaitForString(_WIFI_WAIT_TIME_LOW,&result,2,"OK","ERROR")
  •          * If the ESP8266 return a AT+OK after the last command, the function is going to
  •          * return a true value and the result number would be 1.
  •         if(result == NULL)
  •                 return false;
  •         if(CountOfParameter == 0)
  •                 return false;
  •         *result=0;
  •         va_list tag;
  •                 va_start (tag,CountOfParameter);
  •                 char *arg[CountOfParameter];
  •                 for(uint8_t i=0; i                        arg = va_arg (tag, char *);
  •         va_end (tag);
  •         for(uint32_t t=0 ; t
  •                 DWT_Delay_us(20000);
  •                 for(uint8_t        mx=0 ; mx
  •                         if(strstr((char*)Wifi.RxBuffer,arg[mx])!=NULL)
  •                                 *result = mx+1;
  •                                 return true;
  •         // timeout
  •         return false;
  • bool Wifi_ReturnString(char *result,uint8_t WantWhichOne,char *SplitterChars)
  •                 return false;
  •         if(WantWhichOne==0)
  •                 return false;
  •         char *str = (char*)Wifi.RxBuffer;
  •         str = strtok (str,SplitterChars);
  •         if(str == NULL)
  •                 strcpy(result,"");
  •                 return false;
  •         while (str != NULL)
  •     str = strtok (NULL,SplitterChars);
  •                 if(str != NULL)
  •                         WantWhichOne--;
  •                         strcpy(result,str);
  •                         return true;
  •         return false;
  • bool Wifi_ReturnStrings(char *InputString,char *SplitterChars,uint8_t CountOfParameter,...)
  •                 return false;
  •         va_list tag;
  •                         arg = va_arg (tag, char *);
  •         va_end (tag);
  •         char *str;
  •         str = strtok (InputString,SplitterChars);
  •         if(str == NULL)
  •                 return false;
  •         uint8_t i=0;
  •                 if(str != NULL)
  •                         CountOfParameter--;
  •                 strcpy(arg,str);
  •                 i++;
  •                 if(CountOfParameter==0)
  •                         return true;
  •         return false;
回帖(1)
刘建国
2022-12-21 14:19:11
当您报告问题时,指出所有细节总是有帮助的:您使用的是什么 STM32,什么编译器等。
从屏幕复制“Error[Pe028]”我想你正在使用 IAR EWARM 开发环境。
“char *arg[CountOfParameter];”这一行 是可变长度数组的声明。数组大小将仅在运行时已知,并将由编译器提供的支持库动态分配。
在 IAR EWARM 中,要启用此功能,您必须在项目选项的 C/C++ 编译器配置中选中“标准 C”/“允许 VLA”。
举报
更多回帖
