我在多维数据集中设置了一个项目。SPI+DMA。当 mcu 从堆栈发送数据时,DMA 工作正常并且活动在引脚上可见。但是,如果将 bss 中的数据数组分配为静态或全局数据,则引脚上不会发生任何事情。程序正常运行,正确的状态被输入到 DMA 寄存器中。但是在 SPI 寄存器中没有可见的活动。为什么 DMA 不发送静态数据?
- /* USER CODE BEGIN Header */
- * @file : main.c
- * @brief : Main program body
- * @attention
© Copyright (c) 2021 STMicroelectronics.- * All rights reserved.
- * This software component is licensed by ST under BSD 3-Clause license,
- * the "License"; You may not use this file except in compliance with the
- * License. You may obtain a copy of the License at:
- * opensource.org/licenses/BSD-3-Clause
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- SPI_HandleTypeDef hspi2;
- DMA_HandleTypeDef hdma_spi2_tx;
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_DMA_Init(void);
- static void MX_SPI2_Init(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- //static uint8_t data[6]; //not works
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_DMA_Init();
- MX_SPI2_Init();
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- uint8_t data[6]; //works fine
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- HAL_Delay(1000);
- HAL_SPI_Transmit_DMA(&hspi2, data, sizeof(data));
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- * @brief SPI2 Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN SPI2_Init 0 */
- /* USER CODE END SPI2_Init 0 */
- /* USER CODE BEGIN SPI2_Init 1 */
- /* USER CODE END SPI2_Init 1 */
- /* SPI2 parameter configuration*/
- hspi2.Instance = SPI2;
- hspi2.Init.Mode = SPI_MODE_MASTER;
- hspi2.Init.Direction = SPI_DIRECTION_1LINE;
- hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
- hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
- hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
- hspi2.Init.NSS = SPI_NSS_SOFT;
- hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
- hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
- hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
- hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
- hspi2.Init.CRCPolynomial = 10;
- if (HAL_SPI_Init(&hspi2) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN SPI2_Init 2 */
- /* USER CODE END SPI2_Init 2 */
- * Enable DMA controller clock
- /* DMA controller clock enable */
- __HAL_RCC_DMA1_CLK_ENABLE();
- /* DMA interrupt init */
- /* DMA1_Channel5_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(DMA1_Channel5_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(DMA1_Channel5_IRQn);
- * @brief GPIO Initialization Function
- * @param None
- * @retval None
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOC_CLK_ENABLE();
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief Period elapsed callback in non blocking mode
- * @note This function is called when TIM2 interrupt took place, inside
- * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
- * a global variable "uwTick" used as application time base.
- * @param htim : TIM handle
- * @retval None
- void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
- /* USER CODE BEGIN Callback 0 */
- /* USER CODE END Callback 0 */
- if (htim->Instance == TIM2) {
- HAL_IncTick();
- /* USER CODE BEGIN Callback 1 */
- /* USER CODE END Callback 1 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- __disable_irq();
- while (1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
