ST意法半导体
登录
直播中
张秀兰
8年用户
1341经验值
私信
[问答]
stm32439VITx板的ADC问题求解
开启该帖子的消息推送
adc
HSI
大家好。
我有一个自定义的
STM32
439VITx 板,运行频率为 60MHz,HSI 时钟:
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
/** Ini
ti
alizes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 64;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
信号由放大器驱动到 1K/1M 电阻分压器,馈入 ADC1 通道 10,我需要每十秒左右读取一次:
void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV6;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = DISABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
我已经尝试了几乎所有我能想到的方法来让它工作,并且我已经将代码简化为一个简单的测试用例:
static void test_adc() {
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_ADC1_Init();
HAL_ADC_Start(&hadc1);
while(true) {
HAL_Delay(1000);
if(HAL_ADC_PollForConversion(&hadc1, 100) == HAL_OK) {
static const float Vref = 3.3f;
static const float R14 = 1000.0f;
static const float R15 = 1000000.0f;
const float adc = HAL_ADC_GetValue(&hadc1);
const float vadc = adc * Vref / 4096.0f;
const float vin = vadc * (R14 + R15) / R15;
__NOP();
HAL_ADC_Stop(&hadc1);
输入引脚上的电压表显示 1200mV,ADC 的读数在 890 到 910 之间,调整后的读数约为 720mV。
就像我说的,我已经尝试了各种方法来获得合理的阅读,也许我缺少一些简单的东西。我的代码有什么明显的错误吗?
回帖
(1)
王军
2022-12-15 10:50:35
这不是软件问题,而主要是硬件问题。使用您的测量设置,测量不能产生任何有意义的值,至少不能产生预期的值。对于这个 ADC,您也必须考虑输入参数。
让我们总结一下:
你用放大器给分压器供电
分压器的分压系数为 1/1000 = 0.001,GND 电阻为 1Mohms
根据
数据表
,ADC 的最大(!)外部输入阻抗为 50kohms(表 74,第 159 页)
实际输入阻抗可以用等式 1 估算(表 74 下方,第 160 页)
这个星座的分压器会发生什么变化?
正确,电压崩溃。
解决方法:使用放大器将待测电压直接加到输入端,只要低于最大值即可,即去掉R15,短接R14。
通常,ADC 前面的运算放大器正是用于此目的,也用于抗混叠。
让我们总结一下:
你用放大器给分压器供电
根据
数据表
这个星座的分压器会发生什么变化?
正确,电压崩溃。
举报
更多回帖
rotate(-90deg);
回复
相关问答
adc
HSI
使用
STM32
CubeMX为
STM32
CubeIDE生成代码,然后将main.c更改为 main.cpp构建项目报错如何解决?
2023-02-07
276
如何采用
STM32
F103C8T6的通道进行
adc
采集呢
2021-12-13
7826
STM32
G071RB上的
ADC
读数问题
求解
2022-12-02
354
STM32
U5,
STM32
WB及
STM32
L4开发
板
,哪个开发
板
拥有较多数量的
ADC
2024-03-20
450
请问
ADC
的全功率带宽FPBW是怎么
求解
的?
2023-11-30
483
如何对
STM32
的
ADC
进行配置
2021-10-29
2373
STM32
F1换
ADC
基准
2017-06-17
2395
如果将
ADC
设置为12位其获得的
ADC
值代表什么?
2023-01-06
466
请问Mini
STM32
开发
板
的库函数版本写的程序怎么烧进去?
2019-03-15
2047
STM32
F429
ADC
结果超过4096
2019-03-26
5681
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
